changing presets II
changing presets II
2002-04-01 by ph.demoor@free.fr
Me again ..I just found that  it does work but only after I saved my
pattern , scrolled  to another one then returned  to the pattern on
which I worked at first ..the bothering point is that I can't hear the
changing presets straight away in edit mode ..Thanks for your help
anyway !
Re: [xl7] changing presets II
2002-04-01 by Aaron Eppolito
You can't have multiple presets at the same time on one channel.  You can
however have multiple presets selected by one track at the same time as long
as it's a multi track, and they're all on different channels.
Step 1: set track X (where X is the track you want to work on) to "MultiA"
Step 2: go to EVENT edit for track X
Step 3: press "Repeat" (insert)
Step 4: select program change
Step 5: pick channel 01
Step 6: pick a preset
Step 7: repeat steps 3-6, altering the channel in step 5 each time.
-Aaron
> anyway !
