Index last updated: 2026-03-31 01:49 UTC
EMU Blank ROM Circuit Boards?
2012-11-02 by K2500X
Has someone finally figured out how to 'make' these ROM boards in the aftermarket? Check this out...
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160913882450
Re: [xl7] EMU Blank ROM Circuit Boards?
2012-11-02 by Nathan Steele
I saw those the other day, looks like factory leftovers or something. seems you would have to install the chips, and then who knows if the proper sampler would burn them.......
Seems like a risky proposition to me, I suppose you could contact the seller for details, if he has any.
2012-11-04 by D F Tweedie
From the seller: "HI these boards have no memory chips attached these are the standard
boards designed for emu that were for the production of the sound roms
depending on the memory chips you get determines whether they can be
flashed in an emulator or not."
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Friday, November 2, 2012 2:31 PM
Subject: [xl7] EMU Blank ROM Circuit Boards?
