I'm not one of the gurus here ... but I am a couple of steps ahead of you.
Yes, all the P1000/2000 cards and the P2500 cards will work in the Command Station.
The 5 bank cards were in the keyboard series of the P2000 engine.
From the Creative website: http://www.creative.com/emu/company/history/timeline/
PK-6 PK-6 (Pop/Rock) - 2001 (Composer 'PROM1')
XK-6 (Techno/Electronica) - 2001 (Extreme Lead 'XROM')
MK-6 (Hip-Hop) - 2001 (Pure Phatt 'MROM')
Vintage Keys (Classic Keyboards) - 2003 (Sounds of the 70s and 80s 'VROM' )
These keyboards combined the sound engine of the Proteus 2000 with a
61-note keyboard, and featured 64-voice polyphony, four internal
soundROM slots and four analog outputs.
Additionally, the Ensoniq Halo is essentially part of the this same family, branded Ensoniq, but with the P2000 engine and the Sounds of the ZR ('QROM'), which included the famous ensoniq 'Perfect Piano.'
Finally, there is the 'QROM2' ... I'm not sure whether it was only available as a ROM or not ... which contained the two other ensoniq expansion board sounds: Urban Dance Project and Real World.
I think you are correct, that only the Command Stations and Command Module (P2500) have 'patterns,' as the other units don't include a sequencer as far as I know.
BTW, I have all the ensoniq boards mounted betweem two ensoniq MR Racks (units I really like!) and two ASR-X Pros, including duplicates of the Urban Dance and Real World.
One of the great features of the Urban Dance Project is that in contains nearly 50 GM drum kits to instantly audition different sounds if you use the GM standard for your drum mapping.
I may be selling one of the ASR-X Pros with the 8 analog expansion board and either the Urban Dance or Real World cards. If anyone is interested, let me know and I'll keep you in mind to check back before I flog it on Craig's or eBay.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Tuesday, May 29, 2012 11:47 AM
Subject: [xl7] Re: Substitute Rack for ROM?
Trying to figure this all out as well...
I got an MP7 Command Station off eBay, it had a ROM in it that shows up in the display as "MROM" after you scroll past the "User" banks, which I think is from the keyboard version. The presets all sound fine, but if I use eLoader (horrible software) to put the MP7 patterns onto the box, the patterns will not play. I assume it is because my box has the "MROM" card in it instead of the genuine "MP7" card. The cards may be very similar, except there may be an extra bank on one and some presets are different. Anyway as I said, the presets all sound great, it is just the patterns that won't play.
I put an "XL7" card into it. When I use eLoader to put the XL7 patterns on the box, those play just fine. I assume if my XTREME card would have displayed as "XROM" instead, then I probably would have had the same problem with patterns, since there are minor differences between "XL7" and "XROM" cards.
I put a "ZR" card into it. The presets sound nice, although the GM bank is sort of wimpy, but the other 3 banks are nice. I assume there is no such thing as patterns for the ZR card.
To sum up: I think you can put any Proteus2000 family card in and the presets will sound nice, but if you want the patterns, then make sure it is specifically the "XL7" or "MP7" or "PX7" cards that the patterns go with. Or if you use a card from P2500 or one of the keyboards, then you need to find the patterns specifically for that card. If I ever find the patterns that go with "MROM", then I will load them up and see if they work. Hope this helps.
--- In xl7@yahoogroups.com, "vivaknievel" <jammesluckett@...> wrote:
> Thank you! I was a bit confused, thinking that ROMs out of the rack units had to be converted in order to be used in the Command Station. I see now, that it's only when you need the extra banks. That's amazing news, to these ears. :) - J
> --- In xl7@yahoogroups.com, Mariusz P <elektrofunkenstein@> wrote:
> > Hi Jammes,
> > yes, the roms are interchangeble. I use 4 different roms in my PX-7 CS with
> > no compromise: PHATT (Mo'Phatt), XROM1 (XL-7), PROM (P2500/PK-6) and PX-7.
> > Plus, if you find or have sb do conversion for MP-7 you can use rare 5banks
> > keyboard (MK-6 and XK-6) versions of Phatt and Xlead roms.
> > Good luck!
> > M.
