Sorry, Im a speaker, not a writer :)
But�,
Here's what I have by emu.
Esi 2000 3.4 all cds.?
E�synth, 4.62 64 note poly "loaded with all emu cards banks." cds
E 5000 ultra, 4.7 64 note "same"
�Audity 2000, V.1 64 note poly
Proteus 1000, 2.26 64 note.
�Mp7 2.00,�; 128 note poly.� with"mp7 rom X rom"
�The mo phatt is 64 notes. The card that came with it, Has Different features than the mp7.�� �The banks are even Different.� Some Sounds get stuck... Some wont play?
�Triggers , Processors etc. all work different.�� The touch-strip. Kits vs. drums, Names of the knobs?"� Too many things are way different.
��I laughed at myself one day and said"why are you trying to get something that plays 64 notes. to read�something that reads 128 notes"
So basically its best to�use ,The banks of the card and unit. Or...� The� same 1000 models together, 2000 models together�etc.
At times Ive loaded in banks, and one of the knobs lights, �would be on. Or, the save button flashes?
Until you reinitialize it.� The units play odd. "noise harsh sounds spikes at times Flat"
�This is what causes that midi error fail . If anyone had that happen before.
If you Still have it. Disconnect the unit.��midi cables and �power cord. ? re plug it in.And��run the auto cycle.�� Reboot and reload the multi set ups banks etc.� Good to go.
Other tips.
�If you have a rack mount, and lost the multi set ups an arps. Go to the audity page and download the multi set up from there."Steve may have it here"
�You cant do it from the command stations "download" because they have sequences patterns.�that wont load into the rack mounts.
I also�have�a... PX 7v.25 rom in my e 5000��� It reads as ,No Presets. Meaning "No Instruments". I only get the samples.�
� So the guy with the� PX 7 problem.... I really think you have a flash card. "bonus Keep that card"
A friend of mine....�just got the 32 mg�flash rom card�last week. We are going to figure out how those work ."sound authoring"This week coming up. I will explain them here for all.
�� Hope this helps.
To: "xl7@yahoogroups.com"
Sent: Friday, May 11, 2012 9:35 PM
Subject: Re: [xl7] Are Mo' Phatt and MP-7 ROMs identical?
They play smoother, the sounds "levels" are more crisp.
Sent: Friday, May 11, 2012 2:38 PM
Sam ...
I wasn't clear what you meant by: "Level sound everything seems better."
Could you explain a little more?
Thanks.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Friday, May 11, 2012 12:08 PM
There is a few sounds that get stuck in my MP7 when I load the mo phatt bank or the mk6 bank. I think the cards work better when you load their own banks. Level sound everything seems better.
But it reads my Proteus an xl7 card. no problem.
Tweedie To: "xl7@yahoogroups.com"
Sent: Friday, May 11, 2012 1:03 PM
Phatt and MP-7
ROMs identical?
Thanks, Andrew ...
Well, I guess I'm about to find out ... I just bought a pretty inexpensive 'Mo Phatt' on line, basically to get the rack ears. Since I have a ROM in my PX-7 that displays 'MP-7,' I'll get to compare them.
I am thinking about putting an extra Beat Garden ROM in the 'Mo Phat' and selling it on without the ears.
DF
Sent: Friday, May 11, 2012 10:39 AM
Subject: RE: [xl7] Are Mo'
Phatt and MP-7
ROMs identical?
I'm pretty sure they are the same.� I found a very cheap MK-6 on
ebay awhile back and thought I'd use it, but it was way to big to fit in my setup... so I ended up yanking the ROM out and putting it in my XL-7. Anyway, in the users manual for the MK-6 it mentions that the ROM is the same as the MP-7, and that the only differences to the systems basically are trading a keyboard for a sequencer.� I do remember reading somewhere awhile back that there were 2 runs of
Phatt roms, and that the much more common More
Phatt had the same content as
Phatt, but contained many more samples than the first
Phatts did.
Date: Fri, 11 May 2012 10:24:57 -0700
Subject: [xl7] Are Mo'
Phatt and MP-7
ROMs identical?
I read that the Mo' Phatt, MP-7 and MK-6 all have the same 'pure phatt' module. Is this correct including presets and all?
I noticed that a chart I have states that the MP-7 and Mo' Phatt ROMS have different display, i.e., 'MP-7' and 'Phatt,' so it made me wonder if the content is all the same.
DF
