MIDI Clock Timing Discrepancies
2002-03-25 by lightfingerxl7
I am triggering a Korg ER-1 with a MIDI clock from the XL-7. I am
noticing a lag in the ER-1 where there wasn't one before. Any
suggestions?
Thanks, Lightfinger2002-04-01 by erik_magrini@Baxter.com
Hmm, make sure you thin out any CC stuff you've got recorded in the
pattern. I've never had any problems syncing my ER-1 to the XL-7 though,
it's usually pretty tight.
"lightfingerxl7" <lightfinger@...>
03/25/02 02:27 PM
Please respond to xl7
cc: Subject: [xl7] MIDI Clock Timing Discrepancies
suggestions?
Thanks, Lightfinger
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/2002-04-02 by coscon23
i had the same problem today... luckily i remembered someone on this group mentioning midi outB is better with wordclock than midi outA.... and yes... no problems with syncing after using outB for the electribe. --- In xl7@y..., erik_magrini@B... wrote: > Hmm, make sure you thin out any CC stuff you've got recorded in the > pattern. I've never had any problems syncing my ER-1 to the XL-7 though, > it's usually pretty tight. > > rEalm > > > > > > "lightfingerxl7" <lightfinger@h...> > 03/25/02 02:27 PM > Please respond to xl7 > > > To: xl7@y... > cc: > Subject: [xl7] MIDI Clock Timing Discrepancies > > > I am triggering a Korg ER-1 with a MIDI clock from the XL-7. I am > noticing a lag in the ER-1 where there wasn't one before. Any > suggestions? > Thanks, Lightfinger > > > > To unsubscribe from this group, send an email to: > xl7-unsubscribe@y... > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2002-04-02 by erik_magrini@Baxter.com
BTW, that's midi clock, not word clock. :) I wish the xl-7's had word clock! rEalm i had the same problem today... luckily i remembered someone on this group mentioning midi outB is better with wordclock than midi outA.... and yes... no problems with syncing after using outB for the electribe.
2002-04-03 by coscon23
hi realm, mmm.... pretty stupid of me... but speaking about wordclock... did you ever get any satisfying answer from event regarding your wordclock problem? as i remember it you couldn't get your xl7 digital out synced correctly to your soundcard. i've got a gina24 and have the same problem (didn't try the mp7 out yet but i can't get my old sony dat nor my new tc triple-c compressor digital outs into my gina without glitches/ticks) -sorry for the bad english but i guess you'll understand --- In xl7@y..., erik_magrini@B... wrote: > BTW, that's midi clock, not word clock. :) I wish the xl-7's had word > clock! > > rEalm > > > > i had the same problem today... luckily i remembered someone on this group > mentioning midi outB is better with wordclock than midi outA.... and > yes... no problems with syncing after using outB for the electribe.
2002-04-03 by Andre Lewis
Basically whenever you have a digital signal there is a clock sent as well. With SPDIF it can be either the soundcards or the instrument/mixer/whatever. You have to designate one of these as the master. If you tell your soundcard/mixer or whatever that the XL-7 is the master everything will be fine. The layla has this option as well as the Gina/Darla. Andre
-----Original Message----- From: coscon23 [mailto:coscon@...] Sent: Wednesday, April 03, 2002 5:25 AM To: xl7@yahoogroups.com Subject: [xl7] Re: MIDI Clock Timing Discrepancies hi realm, mmm.... pretty stupid of me... but speaking about wordclock... did you ever get any satisfying answer from event regarding your wordclock problem? as i remember it you couldn't get your xl7 digital out synced correctly to your soundcard. i've got a gina24 and have the same problem (didn't try the mp7 out yet but i can't get my old sony dat nor my new tc triple-c compressor digital outs into my gina without glitches/ticks) -sorry for the bad english but i guess you'll understand --- In xl7@y..., erik_magrini@B... wrote: > BTW, that's midi clock, not word clock. :) I wish the xl-7's had word > clock! > > rEalm > > > > i had the same problem today... luckily i remembered someone on this group > mentioning midi outB is better with wordclock than midi outA.... and > yes... no problems with syncing after using outB for the electribe. To unsubscribe from this group, send an email to: xl7-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
