Bruno ... I racked my command station at the top of a similar rack. That way you don't have to lose any rack spaces as you can get to the inputs on CS from the top easily.
Mine didn't have that top cross rod shown in the picture of this Adam 21-Space Adjustable Angle Rack Stand ... but I don't think you need it , once you have screwed in the CS.
I am using mine primarily as a sound module ... so I don't mind not having the pads at the bottom of the angled section of the rack.
That unit looks pretty good. I bought a cheaper one, but had to get those expensive SKB screw and nut kits ... since it didn't have the drilled/ tapped screw openings in the frame.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
To: xl7 <xl7@yahoogroups.com>
Sent: Sunday, May 6, 2012 11:52 AM
Subject: [xl7] Rack mounting XL7
Hi guys,
I'm wondering if:
a) my rack is weird
b) my XL-7 is weird
c) all XL-7s are weird
I mounted my XL-7 in a rack and everything is nice and dandy, except
that XL-7 occupies a bit too much space. It's mounted in an adjustable
angled rack (similar to this one:
http://img.etonals.com/p/large/MC_ARS55.jpg), at the bottom of the
adjustable frame. All units above it have to be shifted a bit up,
which is not nice and costed me a hell of effort to fit it there, and
made me wondering if something went wrong in the E-mu factory.
Pointer: it's *very* early model, which came with printed manual
revision A and CD-ROM with revision A in PDF. I still have an MP-7
(which I'm planning to sell), which seems to be of some later sort,
but I'm not sure if I want to disassemble my rack and try to fit it
there. Also, I actually wanted to get XL-7 (I prefer yellow to
purple), so using MP-7 would not be an option.
I was thinking at some point about shoving the bottom side of the
case, but that was only a momentary lapse of weakness. I wouldn't harm
my beautie :-)
Erm... so, any experiences to share from fellow rack-mounted-CS owners?
Bruno
