steve wrote: "I tend to use motu midi express (8x8 midi router with a parallel port, not usb). I did
pick up a parallel port motu MTP AV, but when I found out a lot of the
fancy programming was only available via Macs, I stopped trying to learn the ins and outs of the MTP AV."
Wow, I really miss my MTP AV. I had to abandon it when I went from XP to Win 7 x64 since there were no 64 bit drivers.
What was it you couldn't do? I had no problems doing all kinds of setups using Clockworks on the PC.
I've hung on to the MTP AV, since it can be used stand alone.
I lucked into something else though, the Steinberg Midex 8, when some Cubase engineer decided to write 64 drivers for this discontinued product and Steinberg released the driver 'unsupported, as is.' But it works a charm.
While they (I have two) don't have the routing flexibility of the MTP AV, they do have Cubendo's 'Linear Time Base' technology, which is a buffer system working between the bespokd software and hardware to send midi data prior to when it is to be used in the sequence. This results in some of the most ... if not the most ... robust and time accurate midi timing ever.
There's always a silver lining.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Thursday, May 3, 2012 2:17 PM
Subject: [xl7] Re: Midi Clock and MOTU Midi Timepiece AV-USB
I tend to use motu midi express (8x8 midi router with a parallel port, not usb). I did pick up a parallel port motu MTP AV, but when I found out a lot of the fancy programming was only available via Macs, I stopped trying to learn the ins and outs of the MTP AV.
That being said, I think both 8x8 midi routers use MOTU's clockworks software. (Please correct me if I am wrong about the MTP AV).
To diagnose the problem (assuming I'm right about clockworks and the MTP AV), boot up clockworks and see what's going on with the routings and the filterings. Depending on the settings of the various pieces of gear, midi clock might not be doing what you want. That's where I'd start.
I don't know much about the other gear (just E-Mu and motu). Make sure you know what is capable of sending, receiving, and resending midi clock. The E-Mu can be a master or a slave--depending on your setting. It will never pass incoming midi clocks out [thru]. BTW, be careful to avoid the dreading midi clock feedback loop.
> No matter what I do, I can't get Midi clock into MidiOX from the MP-7 via the MTP-AV.
This comment (above) is what makes me wonder if the MTP AV is using routings/filtering that block the midi clocks. That's why I'd check there first.
Hope this herlps.
Steve
--- In xl7@yahoogroups.com, "siprophet0" <siprophet0@...> wrote:
> I am posting this question here and at motunation with the hopes that somebody has run into these problems.
> 1. MP-7, Akai MPD32, Novation KS-5, MOTU MTP-AV, MidiOX, Laptop
> .I wish to use the MP-7 as the clock source and tempo control
> .MP-7 Midi Out/In is plugged into the MTP-AV
> .MTP-AV is plugged into the laptop via USB
> .KS-5 Midi Out/In is plugged into the MPD32 (Acting as a Midi Interface)
> .MPD32 is plugged into the laptop via USB
> Using MidiOX, I can see note data, etc and route to and from the MP-7 and KS-5...No problems. No matter what I do, I can't get Midi clock into MidiOX from the MP-7 via the MTP-AV.
> If I take the MPD-32 out of the equation and plug it directly into the MTP-AV, no problem however, I still can't see the clock data in MidiOX. It appears that the MTP-AV will pass clock data throughout it's midi ports but not to the laptop.
> If I replace the MTP-AV with an EMU 2x2 midi interface, the clock is transmitted and can be routed via the USB and midi interfaces...all is good. Messing around with this led me to do some experimenting and hence problem #2 popped up.
> 2. MP-7, Novation KS-5, MOTU MTP-AV, MidiOX, Laptop
> .If I use MidiOX as the clock source with both the MP-7 and KS-5 connected to the laptop via the MTP-AV, the KS-5 arps clock well but the MP-7 tempo is 8 times the tempo set in MidiOX. The MTP-AV can act as an MTC master however the MP-7 doesn't seem to recognize MTC so that should be irrelevant. I checked through out the manual and every possible menu item for some sort of clock multiplier or some indication of what would cause this multiplier to the tempo. Funny thing is, the MP-7 Tempo display shows the same tempo value that MidiOX is transmitting but the pattern is playing 8x faster.
> I have several clock sources available including Live, KS-5, MP-7, Radias but ultimately, and this may sound too old school but I want the MP-7 to be the Grand Poobah in this setup
> Any ideas?
> Thank-you in advance
