Using Command Centre as Midi Controller for Reason/Ableton
2012-04-23 by tado2099
Archive for xl7.
It should be possible since its all MIDI, but is it a case of just plugging in?. Howabout, switching instruments with Reason and the MP7. Also I know you can step sequence on the MP7 but do the buttons do the same thing on Redrum step sequencer? Thanks
2012-04-24 by D F Tweedie
2012-04-24 by steve_the_composer
I have never used Reason, so I cannot suggest anything there. The idea of using midi learn is an excellent one; I just don't know how its implemented in Reason. I doubt you can use all of the buttons on the Command Station to do the same things they do on the Command Station in Reason (e.g., step record). I have used the 16 knobs on my P2500 to control other gear--basically by sending CCs and mapping to the parameters I wanted to change in the external gear. Also, the trigger buttons can be set up to send specific notes. They can be set up to be sent externally via midi. So, if Reason has midi learn which can do different functions, perhaps you can use the trigger buttions based on the different notes. Of course, if it could do that, you could also map a keyboard to Reason's functions. Command Stations have what's called Remote Control Sysex mode, but I would be exteremly surprised if Reason could map E-Mu sysex commands to its own functions. In short, I'd expect that the E-Mu's knobs and the triggers could be used for any software with midi learn. If the software resonds to basic midi transport commands (start, stop, continue), those could probably be used, too. There is no practical way of using the Command Station's encoder to send out program change messages to Reason. I hope this helps. Its about all I can think of. Maybe there's someone else here who uses Reason that can help. Steve --- In xl7@yahoogroups.com, "tado2099" <welovetado@...> wrote: > > It should be possible since its all MIDI, but is it a case of just plugging in?. > > Howabout, switching instruments with Reason and the MP7. > > Also I know you can step sequence on the MP7 but do the buttons do the same thing on Redrum step sequencer? > > Thanks >
2012-04-24 by Matt
Can you use the footswitch for sending program change?
Also, the trigger buttons can be set up to send specific notes. They can be set up to be sent externally via midi. So, if Reason has midi learn which can do different functions, perhaps you can use the trigger buttions based on the different notes. Of course, if it could do that, you could also map a keyboard to Reason';s functions.
Steve
> Thanks
Re: Using Command Centre as Midi Controller for Reason/Ableton
2012-04-25 by steve_the_composer
Hmmmmmm. Under controllers, the footswitch jacks on the P2500 (and I assume the command stations) can be set to Preset+ and Preset-. Lemme see if that can be used to transmit a patch change to external gear. I tried all combinations I could think of and I could not get a foot pedal plugged into footswitch jack 1 to send a patch change externally--just internally. Maybe there is a way, but I couldn't figure it out. Steve --- In xl7@yahoogroups.com, Matt <somatt@...> wrote: > > Can you use the footswitch for sending program change?
