I think you need to change the sequencer track to send on the
external midi port.
on the manual page 95-96
To Assign Tracks to MIDI Channels
1. Select the pattern you wish to edit.
2. Press the Pattern Edit button.
3. Scroll to the Select Track Changes screen shown below using the
data
entry control.
4. Select the desired track(s).
5. Select the desired channel for the track.
6. Select the desired destination for the track.
7. Press the Pattern Edit button again to exit the module.
Each of MP-7\u2018s 16 tracks can contain multichannel MIDI data. Because
tracks can be routed internally or externally on either of the two
MIDI
ports, the MP-7 sequencer can actually control up to 64 separate
MIDI
channels (16 internal-A, 16 internal-B, 16 MIDI port-A, 16 MIDI
port-B).
Once a track is enabled for multichannel recording you can record
into it
using the rubber keypads or external MIDI data.
To Setup a Track for Multichannel Recording
1. Select the pattern you wish to record.
Playback Setup (steps 2-7 set up the track for multi-channel play
back)
data
entry control.
4. Select the desired track.
T01 CHANNEL ASSIGN
Channel: 01A: Dest:both
T01 CHANNEL ASSIGN
5. Set the track to MultiA or MultiB.
6. Select the desired destination for the track (internal, external
or both).
Continue on to Record a Multichannel Track using the Rubber Keypads\u2026
8. Press the Controllers button and make sure \u201cKeyboard/Knob
Channel\u201d
is set to \u201cBasic\u201d. This feature automatically changes the channel of
keypad to whatever channel is shown in the preset view display.
9. Make sure the multichannel track you set up (step 4 above) is
selected.
10. Set the Pattern Length.
Ready to Record
11. Press the Preset View button.
12. Select a preset for channel 01A.
13. Press Record, then Play. Start playing!
Record Channel 2
14. Select channel 02A.
15. Select a preset for channel 02A.
16. Press Record, then Play. Start playing!
17. Continue to record channels.
On 4/13/2012 9:43 AM, alexfcobb wrote:
Hey all,
I recently got a MP7. I'm trying to use it as a MIDI
sequencer to send clock to my Waldorf Microwave. I have
connected them and when I hit the pads on the MP7 I hear
sound through the Waldorf. But when I try to play a
pattern into it I get nothing. My settings are:
MIDI:
Base Tempo: 120
Chained Patterns: Keep Constant Tempo
Rechannelize Input: Always(?)
Keyboard outputs MIDI: Transmit
Knobs Output MIDI: Transmit
Transmit MIDI Clock: Off
External Song Start/Stop: Accepted
Merge MIDI In to Out: A:Off B:Off
MIDI In Channels: 1-16:A
MIDI Enable:On on all channels
Receive Program Change: On on all channels
Any ideas what I'm doing wrong?
Thanks in advance for any help
