Archive for xl7.
MIDI Sync not working with FLStudio
2012-02-23 by malikm
I've recently dusted my gear off and started to play again.
I'm trying to get MIDI sync working.
I've set FLStudio to send sync to my MP7 have the following features set in the MP7:
MIDI:
Base Tempo: 160
Chained Patterns: Keep Constant Tempo
Rechannelize Input: Always(?)
Keyboard outputs MIDI: Transmit
Knobs Output MIDI: Transmit
Transmit MIDI Clock: Off
External Song Start/Stop: Accepted
Merge MIDI In to Out: A:Off B:Off
MIDI In Channels: 1-16:A
MIDI Enable:On on all channels
Receive Program Change: On on all channels
Program Change Preset 000bank0 I don't use this
SYSEX Device ID 1: doesn't really matter as far as i know FL doesnt deal with sysex
SYSEX packet delay: doesnt matter
SYSEX again, irrelevant
MIDI Mode: Multi Change: Accepted
Still when i start FL Studio it just JItters. until i unplug the midi input on my MP7
Could anyone help?
Re: MIDI Sync not working with FLStudio
P.S. This is only a problem when i press record in FLStudio
--- In xl7@yahoogroups.com, "malikm" <malik_martin@...> wrote:
> Hi,
> MIDI:
> Base Tempo: 160
> Could anyone help?
> Thanks
Re: [xl7] Re: MIDI Sync not working with FLStudio
2012-02-23 by Matt
Use FL as the master since the clock on the xl7 jitters by +- 2 bpm
--- In xl7@yahoogroups.com, "malikm" wrote:
> Hi,
> MIDI:
> Base Tempo: 160
> Could anyone help?
> Thanks
Thanks for the reply.
Yep. I am sending master sync and as far as i know, having MP7 set as slave. Do my settings suggest something different?
> > --- In xl7@yahoogroups.com, "malikm" <malik_martin@> wrote:
> > > Hi,
> > in the MP7:
> > > MIDI:
> > > Base Tempo: 160
> > with sysex
> > input on my MP7
> > > Could anyone help?
> > > Thanks
2012-02-23 by Matt
Please describe "jitter" in more depth
> > > Hi,
> >; > I'm trying to get MIDI sync working.
> > in the MP7:
> > > MIDI:
> > > Base Tempo: 160
> > with sysex
> > input on my MP7
> > > Could anyone help?
> > >; Thanks
if recording is enabled in FLstudio and I press play.
all you hear is the first beat of the metronome several times a seccond. the start and stop midi signals are repeatedly sent.
Here's FLStudio's debugger output:
(generic controller):  FB          Continue
Handled (first chance)  Absolute 0%
(generic controller):  FC          Stop
this is what you see a million times over
> > Thanks
> > > > > Hi,
> > set
> > > > in the MP7:
> > > > > MIDI:
> > > > > Base Tempo: 160
> > deal
> > > > with sysex
> > > > input on my MP7
> > > > > Could anyone help?
> > > > > Thanks
Re: [xl7] MIDI Sync not working with FLStudio
2012-02-23 by Matt
OK i have just looked your settings more in depth,
First off set base tempo to 0 to get it to slave
see if that resolves your issue
On Feb 23, 2012 9:07 AM, "malikm" <malik_martin@...> wrote:
MIDI:
Base Tempo: 160
Could anyone help?
2012-02-24 by malikm
oh boy..I'm embarrassed. once you scroll back past 1, Base tempo is set to external. SORRY!!!
Thanks Matt.
> > Hi,
> > in the MP7:
> > MIDI:
> > Base Tempo: 160
> > with sysex
> > input on my MP7
> > Could anyone help?
> > Thanks
2012-02-24 by Matt
Glad that helped!
Thanks Matt.
> On Feb 23, 2012 9:07 AM, "malikm" wrote:
> > Hi,
> > in the MP7:
> > MIDI:
> > Base Tempo: 160
>; > Rechannelize Input: Always(?)
> >; Merge MIDI In to Out: A:Off B:Off
> > with sysex
> > input on my MP7
> > Could anyone help?
> > Thanks
