Anything I need to know about S/PDIF?
2012-02-14 by just john
I finally have an audio interface that offers S/PDIF, so I'm about to hook up my XL-7, once I pick up a cable.
Anything I need to know?   Any rude surprises?  Is this one of the jacks that doesn't actually work?
Re: [xl7] Anything I need to know about S/PDIF?
2012-02-14 by D F Tweedie
I'm no expert ... but when I got my PK7 I had a digital audio cable lying around ... plugged both ends in and everything worked. I've never had an issue.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
Sent: Tuesday, February 14, 2012 3:46 PM
Subject: [xl7] Anything I need to know about S/PDIF?
2012-02-15 by Mibrilane
I have my XL-7 going into my Edirol M-16DX digital mixer using S/PDIF - perfectly clean and no hiss whatsoever. Get a good RCA cable (I got a 2-meter Hosa “digital” RCA cable (shielded) for about $10 - works great), but don’t bother with the $100 cables from Monster.
Mibrilane
mibrilane@...
2012-02-15 by Tom J
I have to speak about the spdif cables from hosa, (also 1/4" and stereo rca) I have both hosa and monster. The problem with hosa is they die often. Not a problem if you have more than a couple as spares, but monster guarantees their cables, just take it back where you bought it, with the receipt, and they give you a new one. (Lifetime warranty). I have 4 dead hosa spdif (also too many to count of the other hosa). No returns just hoping one day another unit will work with them. I usally tear the others (1/4" and rca's) in half and use the good parts together.
Good luck...
Sent: Tuesday, February 14, 2012 8:02 PM
Subject: Re: [xl7] Anything I need to know about S/PDIF?
Mibrilane
mibrilane@...
2012-02-15 by Alwyn
The only issue with S/PDIF that i recall reading about was that S/PDIF only worked at 48kHz, and not 44.1kHz.
This is probably not an issue for anyone anymore, and i haven't actually tested it so i can't say if it's true or not.. but if you have some issues, check this.
[zar]
Good luck...
Mibrilane
mibrilane@...
2012-02-15 by D F Tweedie
Maybe the other way around? I know I was running my interface at 44.1k and I just plugged in the PK7.
DF
Sent: Tuesday, February 14, 2012 5:33 PM
[zar]
>Good luck...
>From: Mibrilane <mibrilane@...>
>To: xl7@yahoogroups.com
>Mibrilane
>mibrilane@...
2012-02-15 by Alwyn
I had a quick search and couldn't find a definitive answer, so i think you are correct sir!
[zar]
DF
[zar]
Good luck...
Mibrilane
mibrilane@...
Re: Anything I need to know about S/PDIF?
2012-02-15 by just john
Wow, good bunch of replies in just a couple hours!  Thanks, all.
            -- jj
> are correct sir!
> [zar]
> > DF
> > communication.
> > *From:* Alwyn <zardac@...>
> > *To:* xl7@yahoogroups.com
> > *Sent:* Tuesday, February 14, 2012 5:33 PM
> > *Subject:* Re: [xl7] Anything I need to know about S/PDIF?
> > issues, check  this.
> > [zar]
> > Good luck...
> >    *From:* Mibrilane <mibrilane@...>
> > *Sent:* Tuesday, February 14, 2012 8:02 PM
> > 2-meter Hosa "digital" RCA cable (shielded) for about $10 - works great),
> > but don't bother with the $100 cables from Monster.
> > *Mibrilane*
> > mibrilane@...
Re: [xl7] Re: Anything I need to know about S/PDIF?
2012-02-15 by Matt
My spidf out doesn't work unless I ground the ring.
-matt
-- jj
> are correct sir!
> [zar]
> > DF
> > communication.
> > *From:* Alwyn
> >; *To:* xl7@yahoogroups.com
> > issues, check this.
> > [zar]
> > On 15 February 2012 09:20, Tom J wrote:
> >; I have to speak about the spdif cables from hosa, (also 1/4" and stereo
> > Good luck...
> > *From:* Mibrilane
> > *Mibrilane*
> > mibrilane@...
