Hum and noise in the XL-7
2012-02-10 by Ricard
Here's a solution to an issue that has been mentioned here in this group and elsewhere: if the XL-7 is not securely mounted screwed together, you get hum and noise in the audio. This has sometimes been attributed to insufficient shielding, but the root cause is something completely different. As it turns out, the bottom half of the XL-7, where the main board and the power suppply are mounted, is grounded via the main board. This is as it should be. However, as it turns out, the top half is grounded via the 12V lamp BNC connector on the top. Due to a small but still significant voltage drop along the internal power supply lines, there's a small voltage difference between the metal of the top and bottom halves. That means that when they are screwed together, quite a lot of current flows in the chassis, creating a ground loop. If the two halves are not in proper contact with each other, you get a lot of current flowing in the ground wire(s) of internal power supply lines between the top and bottom halves, in effect, forming a ground loop. The solution is to isolate the BNC connector. For my part, I don't need the light anyway, so I just unsoldered the connector from the volume/headphone board where it is mounted, turned it 90� so it wouldn't make contact with the board, and put it all back together. Voila, no noise at all. I don't know if there are isolated BNC connectors out there which would fit, that would be the final solution to this problem. There are still other reasons that the top and bottom halves should be securely mounted together, but at least this eliminates the noise one gets if the connection is not 100%. /Ricard
