Tempo Changes dont in pattern mode have No Effect - FUCK!!!!!
2002-03-28 by adamhertzano
Hi YAll,...
Has Anyone noticed that once changing the Tempo on a bar basis inside
a patterns' conductor track the tempo only changes if u have pressed
the play button while the machine was in stop mode!
but if changing from a pattern to the pattern containing the
conductor track tempo changes - the tempo will not change~!
Shit.,,, !
Is this going to be fixed??????????????????????????????????????
Very much hope so!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Scott/Aaron,
apreciate your prompt reply.
Best regards
Adam
Re: Tempo Changes dont in pattern mode have No Effect - FUCK!!!!!
2002-03-28 by geekernet
yo
i think they've done this on purpose so that if you're using pattern
mode to create tunes (eg. live recoding), you can do so without
having to have all your saved patterns at the same tempo.  this
avoids any instant jumps in tempo when you change to another pattern
with a different tempo.  if you have that little led screen on tempo,
you can easily change it by holding the edit key and dialing the
wheel.
g
