win7 usb driver.
2012-01-06 by laszlozizics
hello, Someone is use amu usb driver in win7? one user cant go thru with win7 to recognize the CS in usb. thanx for your help https://www.facebook.com/emucommandstation
2012-01-10 by steve_the_composer
For years I had trouble with Win XP working with e-mu command station usb drivers. It was either XPSP2 or XPSP3 that solved the problem. I have not tried the drivers with Win 7, but from what I have seen of Win7, I doubt the e-mu usb drivers would work. Maybe someone else has been successful, though. Anyone? --- In xl7@yahoogroups.com, "laszlozizics" <fantahs@...> wrote: > > hello, > > Someone is use amu usb driver in win7? > one user cant go thru with win7 to recognize the CS in usb. > > thanx for your help > > https://www.facebook.com/emucommandstation >
2012-01-10 by D F Tweedie
Are we talking about using the E-Loader program via USB or do you mean control of the CS? I am using the E-Loader on Win 7 x64 ... or think I am? Anyway, after setting up the midi ports used to attach it to me PC, everything works that I've tried. But honestly I don't know if I'm communicating exclusively through the midi ports or if the USB connection is in the equation. DF CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication. ________________________________ From: steve_the_composer <smw-mail@...> To: xl7@yahoogroups.com Sent: Tuesday, January 10, 2012 2:33 PM Subject: [xl7] Re: win7 usb driver. For years I had trouble with Win XP working with e-mu command station usb drivers. It was either XPSP2 or XPSP3 that solved the problem. I have not tried the drivers with Win 7, but from what I have seen of Win7, I doubt the e-mu usb drivers would work. Maybe someone else has been successful, though. Anyone? --- In xl7@yahoogroups.com, "laszlozizics" <fantahs@...> wrote: > > hello, > > Someone is use amu usb driver in win7? > one user cant go thru with win7 to recognize the CS in usb. > > thanx for your help > > https://www.facebook.com/emucommandstation >
2012-01-11 by steve_the_composer
That would be nice if the e-mu usb drivers work in win7 x64. I will try to make time to test. You should be able to see which port e-loader is using to communicate by looking in the MIDI drop down in e-loader and selecting MIDI Setup. In Win XP, the I/O ports using the usb drivers say something like e-mu usb #0 (I think). Midi ports should be named based on your midi card/device. Steve --- In xl7@yahoogroups.com, D F Tweedie <bienpegaito@...> wrote: > > Are we talking about using the E-Loader program via USB or do you mean control of the CS? > > I am using the E-Loader on Win 7 x64 ... or think I am? Anyway, after setting up the midi ports used to attach it to me PC, everything works that I've tried. But honestly I don't know if I'm communicating exclusively through the midi ports or if the USB connection is in the equation. > > DF > > Â > CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication. > > > ________________________________ > From: steve_the_composer <smw-mail@...> > To: xl7@yahoogroups.com > Sent: Tuesday, January 10, 2012 2:33 PM > Subject: [xl7] Re: win7 usb driver. > > > Â > For years I had trouble with Win XP working with e-mu command station usb drivers. It was either XPSP2 or XPSP3 that solved the problem. I have not tried the drivers with Win 7, but from what I have seen of Win7, I doubt the e-mu usb drivers would work. Maybe someone else has been successful, though. Anyone? > > --- In xl7@yahoogroups.com, "laszlozizics" <fantahs@> wrote: > > > > hello, > > > > Someone is use amu usb driver in win7? > > one user cant go thru with win7 to recognize the CS in usb. > > > > thanx for your help > > > > https://www.facebook.com/emucommandstation > > >
