Digital unlock! :(
Digital unlock! :(
2011-11-14 by Matt
Whenever I try to sample or record from digital coax spdif output I can get roland sampler to lock then I record but after a little (45 seconds) while it says digital unlock and stops recording. recording digital coax works fine vs-1680 -> sampler and vs-840 -> sampler but sampler complains about command station -> sampler.
So... I think the issue is definitely the emu. Anyone else have this problem?
Also when slaved to Roland vs-1680 on MIDI at 140bpm it says anywhere from 141-147 on the emu.
I think these issues are related maybe?
why is the clock so jumpy? Does everyone's cs clock act jumpy? Is there a timing crystal I can have a tech replace? I love this machine other than wonky clock.
Re: Digital unlock! :(
2011-12-10 by retroillumination
I had what I think is the same issue, and I found a way around it. Messing about with digital audio one day, I connected the XL-7's digital out to a TC triple C compressor. And there were loads of 'drop outs', brief silence every few seconds where the triple C could not lock to the Emu's clock. It seemed to get a whole lot worse depending on where I positioned the cable. I found that by connecting a single, standard jack lead between any one of the Emu's analog outs and any one of the triple C's analog inputs completely took care of that problem - the triple C locked perfectly to the Emu's clock from that point. Sounds good too :)
I can only conclude that there must have been too much interference on the original digital connection, maybe the analog link gave the two machines a common ground, or something? The cable I was using for the digital connection probably didn't help, it was just a battered old phono lead.... but anyway, just try running an extra cable from Emu to any of the analog ins on the sampler.
Cheers
Matt
> problem?
> 141-147 on the emu.
> wonky clock.
2011-12-14 by steve_the_composer
I don't know if its related, but a few years ago someone wrote about a fix for the E-Mu's digital connection. I will see if I can find that thread.
--- In xl7@yahoogroups.com, "retroillumination" <retroillumination@...> wrote:
> Hi,
> Cheers
> Matt
> > problem?
> > 141-147 on the emu.
> > wonky clock.
Re: [xl7] Re: Digital unlock! :(
2011-12-14 by Matt
I think I read that it had to do with grounding the ring on the digital out to the case where the chassis joins.
--- In xl7@yahoogroups.com, "retroillumination" wrote:
> Hi,
> I had what I think is the same issue, and I found a way around it. Messing about with digital audio one day, I connected the XL-7's digital out to a TC triple C compressor. And there were loads of 'drop outs';, brief silence every few seconds where the triple C could not lock to the Emu's clock. It seemed to get a whole lot worse depending on where I positioned the cable. I found that by connecting a single, standard jack lead between any one of the Emu's analog outs and any one of the triple C's analog inputs completely took care of that problem - the triple C locked perfectly to the Emu's clock from that point. Sounds good too :)
> Cheers
> Matt
> > problem?
> > 141-147 on the emu.
> > why is the clock so jumpy? Does everyone';s cs clock act jumpy? Is there a
> > wonky clock.
2011-12-14 by Matt
I haven't tried this yet I have just been doing analog in the meantime.
> Hi,
> Cheers
> Matt
> > problem?
> > 141-147 on the emu.
>; > why is the clock so jumpy? Does everyone's cs clock act jumpy? Is there a
> > wonky clock.
2011-12-14 by Dumeril
I'm guessing the analog audio connection provided the proper grounding needing by the digital connection.
D7
> --- In xl7@yahoogroups.com, "retroillumination" <retroillumination@> wrote:
> > Hi,
> > Cheers
> > Matt
> > > problem?
> > > 141-147 on the emu.
> > > wonky clock.
2011-12-15 by simon wilkinson
Sent: Wednesday, 14 December 2011, 15:30
Subject: [xl7] Re: Digital unlock! :(
D7
> > Hi,
> > Cheers
> > Matt
> > > problem?
> > > 141-147 on the emu.
> > > wonky clock.
I'm under the impression the connector/digital output board is faulty/unstable. I only get this problem when using the audition mode.
2011-12-16 by steve_the_composer
That sounds like what I was remembering.
2011-12-16 by Matt
i haven't tried it yet honestly I have been too busy having fun with my ESI which is not turbo so I can't spidf.
