I did. I tried Prodatum 0.41 and it worked great! Then tried again Ver 1.0 but still didn't work so i'll stick to 0.41. Many thanks!
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote:
> I recently tried a few things with Prodatum 1.0.0 based on problems someone discussed in the Yahoo P2K user group. It sounds a little like the problems you are having. Take a look over there; maybe some of what I tried will work for you.
> Steve
> --- In xl7@yahoogroups.com, "ignabarba" <ignabarba@> wrote:
> > Can anyone help me with this? The Program/Channel section works fine (pan, volume, toggle audition), as well as the mini piano, but none of the Voice sections controls (knobs, envelopes, instrument) seem to have any effect.
> > > Hi all. I cant get Prodatum to edit patches parameters on currently selected patch on my XL7. Midi activity leds blink whenever a virtual knob/button is tweaked but theres no realtime change in the sound.
> > > If I save the patch on the CS (using Prodatum's save option), the modified patch get saved on the CS as it should (only then I can hear the results of the edition).
> > > Should I change something in the Midi options of the XL7 to receive or update changes? Maybe something in Prodatum?
> > > Command Station OS Ver. 2.0, Prodatum Ver 1.0.0
