Index last updated: 2026-03-31 01:49 UTC
Grid mode note resolution / gate.
2011-08-19 by ignabarba
Hi all. In grid mode, is it possible to set the note resolution (so knobs can be used to set the note duration �or gate percentage- according to that note resolution)?
RE: [xl7] Grid mode note resolution / gate.
2011-08-19 by Andrew
It gets kind of complicated, but you can change the resolution of your grid recordings... mixing and matching them, but I don't think you can control the durations with any of the knobs... and the gate only applies to the arpeggiator. You might also try recording in step mode... it makes working with different durations quite a bit easier than grid mode. Grid mode works well for programming beats, and rhythmic things like that... it's not really intended for melodic parts with varying note durations.
> To: xl7@yahoogroups.com
> From: ignabarba@...
> Date: Fri, 19 Aug 2011 13:32:38 +0000
> Subject: [xl7] Grid mode note resolution / gate.
> Hi all. In grid mode, is it possible to set the note resolution (so knobs can be used to set the note duration –or gate percentage- according to that note resolution)?
> <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/xl7/
> <*> Your email settings:
> Individual Email | Traditional
> <*> To change settings online go to:
> http://groups.yahoo.com/group/xl7/join
> (Yahoo! ID required)
> <*> To change settings via email:
> xl7-digest@yahoogroups.com
> xl7-fullfeatured@yahoogroups.com
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
Re: [xl7] Grid mode note resolution / gate.
2011-08-19 by Matt
how do i change the amount of steps in the grid mode? currently i cant change it from 16
> From: ignabarba@...
When you're in grid mode, the Track Enable/Mute button above the 16 "grid" buttons is used to select between the 4 different resolutions available. 16th, 32nd, and 8th triplets, 16th triplets. The display still only has room for 16 positions, so if you're using a resolution other than 16th, you'll have to manually advance the cursor to the next screen to see the available positions in that measure beyond what would be numbered 16.
Date: Fri, 19 Aug 2011 12:05:18 -0700
Subject: Re: [xl7] Grid mode note resolution / gate.
> From: ignabarba@...
>; Date: Fri, 19 Aug 2011 13:32:38 +0000
Re: Grid mode note resolution / gate.
2011-08-20 by ignabarba
In Grid Recording Mode if you push the Controller Function Select (Quick Edit / Program / Volume / Pan) button you can switch between volume or gate for each note. The thing is, that gate is a percentage of a (fixed?) sixteenth note (from what I can hear).
My point is: is it possible to set a whole note, or half note, instead of a sixteenth note?
In other words: In Grid mode, can I set the duration of the notes longer that 1/16?
> From: somatt@...
> > From: ignabarba@...
> > Yahoo! Groups Links
