MP7 freezing
2011-07-13 by Bruno
Hi guys, Recently my MP7 crashed - in a sense it stopped to react to whatever I was doing on panel, while still playing what it was supposed to play. Soft power off didn't work, so I switched it off and then on again, and then it worked flawlessly. However today it did the same, except it didn't power on correctly. If I remember correctly, it was starting, showing the three dots, then I was able to hear a short "bzzp", the cursor was an underscore blinking, all the LEDs were lit - and it stayed in this state. I said "if I remember correctly", because when I wanted to look at it again to write down everything, it went up just OK. Any ideas what it can be? A hint: my Volume potentiometer is broken, so it only works in two states: 0 and MAX (anything between 0 & MAX yields MAX). Can it be the reason? A bit worried, Bruno
