e-loader on win7 64
2011-06-23 by splattabreakz
Archive for xl7.
Couldn't find anything about this in the search... Is it possible to get this to work?
Also, just to add to this question, do either Proteum or Prodatum work with the USB connection or do they have to use midi? --- In xl7@...m, "splattabreakz" <s_o_m_9000@...> wrote: > > Couldn't find anything about this in the search... > > Is it possible to get this to work? >
2011-06-23 by capturedandframed
I've got mine installed fine, and it will load up (have to run as administrator during install). I just can't get windows to recognize my emu-mp7. --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@...> wrote: > > Couldn't find anything about this in the search... > > Is it possible to get this to work? >
2011-06-23 by Bruce Manning
Windows gives me an error message when the emu is plugged in via usb that says it's an unrecognized device. I haven't had a chance to try midi. Just a note also, I'm not the original poster. Thanks for the suggestion though. --- In xl7@yahoogroups.com, Bruce Manning <brujerman@...> wrote: > > Do you know what Device ID your MP7 is set at? You might set it at Device ID "0" > or "1" for e-loader to pick it up. > > > > > ________________________________ > From: capturedandframed <photorandy@...> > To: xl7@yahoogroups.com > Sent: Thu, June 23, 2011 10:48:56 AM > Subject: [xl7] Re: e-loader on win7 64 > > Â > I've got mine installed fine, and it will load up (have to run as administrator > during install). I just can't get windows to recognize my emu-mp7. > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > Couldn't find anything about this in the search... > > > > Is it possible to get this to work? > > >
This is the error message that i get when i run the installer "launchanywhere gui has stopped working" anyone got it running on win7? also, can prodatum or proteum do everything e-loader does? --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@...> wrote: > > Couldn't find anything about this in the search... > > Is it possible to get this to work? >
Yes, have you tried running the installer with administrator privileges? My eloader starts up on win 7 64. I have successfully installed it. --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@...> wrote: > > This is the error message that i get when i run the installer > > "launchanywhere gui has stopped working" > > anyone got it running on win7? > > also, can prodatum or proteum do everything e-loader does? > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > Couldn't find anything about this in the search... > > > > Is it possible to get this to work? > > >
Yeah, I have. I'm pretty sure I'm logged in as admin anyway but just to be sure I clicked run as admin... and still the same. Any idea if i'm losing out on features by not having access to the loader? --- In xl7@yahoogroups.com, "capturedandframed" <photorandy@...> wrote: > > Yes, have you tried running the installer with administrator privileges? My eloader starts up on win 7 64. I have successfully installed it. > > --- In xl7@...m, "splattabreakz" <s_o_m_9000@> wrote: > > > > This is the error message that i get when i run the installer > > > > "launchanywhere gui has stopped working" > > > > anyone got it running on win7? > > > > also, can prodatum or proteum do everything e-loader does? > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > Couldn't find anything about this in the search... > > > > > > Is it possible to get this to work? > > > > > >
Try running it in windows xp compatibility mode. If that doesn't work, try it in other comp modes. --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@...> wrote: > > Yeah, I have. I'm pretty sure I'm logged in as admin anyway but just to be sure I clicked run as admin... and still the same. > > Any idea if i'm losing out on features by not having access to the loader? > > --- In xl7@yahoogroups.com, "capturedandframed" <photorandy@> wrote: > > > > Yes, have you tried running the installer with administrator privileges? My eloader starts up on win 7 64. I have successfully installed it. > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > This is the error message that i get when i run the installer > > > > > > "launchanywhere gui has stopped working" > > > > > > anyone got it running on win7? > > > > > > also, can prodatum or proteum do everything e-loader does? > > > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > > > Couldn't find anything about this in the search... > > > > > > > > Is it possible to get this to work? > > > > > > > > > >
Try running it in windows xp compatibility mode. If that doesn't work, try it in other comp modes. I can't remember which one worked for me, but one of those did (compatibility mode or admin). --- In xl7@yahoogroups.com, "capturedandframed" <photorandy@...> wrote: > > Try running it in windows xp compatibility mode. If that doesn't work, try it in other comp modes. > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > Yeah, I have. I'm pretty sure I'm logged in as admin anyway but just to be sure I clicked run as admin... and still the same. > > > > Any idea if i'm losing out on features by not having access to the loader? > > > > --- In xl7@yahoogroups.com, "capturedandframed" <photorandy@> wrote: > > > > > > Yes, have you tried running the installer with administrator privileges? My eloader starts up on win 7 64. I have successfully installed it. > > > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > > > This is the error message that i get when i run the installer > > > > > > > > "launchanywhere gui has stopped working" > > > > > > > > anyone got it running on win7? > > > > > > > > also, can prodatum or proteum do everything e-loader does? > > > > > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > > > > > Couldn't find anything about this in the search... > > > > > > > > > > Is it possible to get this to work? > > > > > > > > > > > > > > >
>; Is it possible to get this to work?
Tried compat mode and compat mode as admin... Still no dice. Maybe safe mode? --- In xl7@yahoogroups.com, Bruce Manning <brujerman@...> wrote: > > Hi, > > I have E-loader running Windows 7, using XP compatibility mode settings. > E-loader is a stripped down tool for preset and pattern copying, > replacing. Prodatum and Proteum are much more in depth tools, allowing preset > editing, arpeggiator editing. Prodatum, has the most control and the programmer > for Prodatum was absolutely great about communicating when she was developing > the product. > > The errror you have identified below makes me believe that it might be an XP > compatibility issue. > > > ________________________________ > From: splattabreakz <s_o_m_9000@...> > To: xl7@yahoogroups.com > Sent: Thu, June 23, 2011 11:42:27 AM > Subject: [xl7] Re: e-loader on win7 64 > >  > This is the error message that i get when i run the installer > > "launchanywhere gui has stopped working" > > anyone got it running on win7? > > also, can prodatum or proteum do everything e-loader does? > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > Couldn't find anything about this in the search... > > > > Is it possible to get this to work? > > >
2011-06-24 by splattabreakz
Well, I've tried pretty much everything I can think of at this point. The closest I got was running the windows virtual xp mode. That mode allowed me to install the software and USB driver. Unfortunately I can't get my soundcard installed so there's no way to get midi hooked up. At least to my knowledge anyway. Anyone know if I can do all the e-loader stuff with prodatum or proteum? --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@...> wrote: > > Tried compat mode and compat mode as admin... Still no dice. Maybe safe mode? > > --- In xl7@yahoogroups.com, Bruce Manning <brujerman@> wrote: > > > > Hi, > > > > I have E-loader running Windows 7, using XP compatibility mode settings. > > E-loader is a stripped down tool for preset and pattern copying, > > replacing. Prodatum and Proteum are much more in depth tools, allowing preset > > editing, arpeggiator editing. Prodatum, has the most control and the programmer > > for Prodatum was absolutely great about communicating when she was developing > > the product. > > > > The errror you have identified below makes me believe that it might be an XP > > compatibility issue. > > > > > > ________________________________ > > From: splattabreakz <s_o_m_9000@> > > To: xl7@yahoogroups.com > > Sent: Thu, June 23, 2011 11:42:27 AM > > Subject: [xl7] Re: e-loader on win7 64 > > > >  > > This is the error message that i get when i run the installer > > > > "launchanywhere gui has stopped working" > > > > anyone got it running on win7? > > > > also, can prodatum or proteum do everything e-loader does? > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > Couldn't find anything about this in the search... > > > > > > Is it possible to get this to work? > > > > > >
2011-06-25 by XL-7 Group
�Well, I've tried pretty much everything I can think of at this point. The closest I got was running the windows virtual xp mode. That mode allowed me to install the software and USB driver. Unfortunately I can't get my soundcard installed so there's no way to get midi hooked up. At least to my knowledge anyway. Anyone know if I can do all the e-loader stuff with prodatum or proteum?
> --- In xl7@yahoogroups.com, Bruce Manning wrote:
> >; Hi,
> > replacing.�Prodatum and Proteum are much more in depth tools, allowing preset
>; > editing, arpeggiator editing. Prodatum, has the most control and the programmer
> > the product.
> > From: splattabreakz
> > Â
2011-06-25 by splattabreakz
Thats exactly what I did amongst other things! I'm running 64bit windows 7, anyone here got it running on 64bit? --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@...> wrote: > > > > Hi there, > i am using E-Loader on win7, it's running perfect. > Win7, have the posibility to set in the properties of each file a compatibility mode. Just click right on mouse and select properties. > Then select compatibility tab and there you are. > You can check 'Run this in compatibility mode for:' and then select WinXP, or other version. > It is very easy, > byye > > > > On 24.06.2011, at 14:26, "splattabreakz" <s_o_m_9000@...> wrote: > > Well, I've tried pretty much everything I can think of at this point. The closest I got was running the windows virtual xp mode. That mode allowed me to install the software and USB driver. Unfortunately I can't get my soundcard installed so there's no way to get midi hooked up. At least to my knowledge anyway. Anyone know if I can do all the e-loader stuff with prodatum or proteum? > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > Tried compat mode and compat mode as admin... Still no dice. Maybe safe mode? > > > > --- In xl7@yahoogroups.com, Bruce Manning <brujerman@> wrote: > > > > > > Hi, > > > > > > I have E-loader running Windows 7, using XP compatibility mode settings. > > > E-loader is a stripped down tool for preset and pattern copying, > > > replacing.Ã Prodatum and Proteum are much more in depth tools, allowing preset > > > editing, arpeggiator editing. Prodatum, has the most control and the programmer > > > for Prodatum was absolutely great about communicating when she was developing > > > the product. > > > > > > The errror you have identified below makes me believe that it might be an XP > > > compatibility issue. > > > > > > > > > ________________________________ > > > From: splattabreakz <s_o_m_9000@> > > > To: xl7@yahoogroups.com > > > Sent: Thu, June 23, 2011 11:42:27 AM > > > Subject: [xl7] Re: e-loader on win7 64 > > > > > > Ã > > > This is the error message that i get when i run the installer > > > > > > "launchanywhere gui has stopped working" > > > > > > anyone got it running on win7? > > > > > > also, can prodatum or proteum do everything e-loader does? > > > > > > --- In xl7@yahoogroups.com, "splattabreakz" <s_o_m_9000@> wrote: > > > > > > > > Couldn't find anything about this in the search... > > > > > > > > Is it possible to get this to work? > > > > > > > > > >
2014-10-11 by fantahs@...
