I don't really understand the use of arps to create the separate loops effect, I'll have to try it out. This was the best
explanation for composing with uneven measures I could find:
http://launch.groups.yahoo.com/group/xl7/message/20411 --- In xl7@yahoogroups.com, "lutherblisset63" wrote:
> Thanks steve. I was hoping to use it in this way:
> You have a 4 bar bass line and you have have an 8 bar melody.
> Instead of having to duplicate the 4 bars to fit into an 8 bar pattern, you could somehow have them looping together.
> Being able to play two patterns simultaneously, or convert a pattern to a track would work nicely. :)
> I'll keeping thinking about it.
> --- In xl7@yahoogroups.com, "steve_the_composer" smw-mail@ wrote:
> > Haven't found other discussions of this. There are a number of discussions related loop points that might be useful--specifically using the extend function.
> > So, it seems you could do it using a lowest common multiple. For example, take a measure of 3 and extend it to 12 measures and take a measure of 4 and do the same.
> > I haven't tried this yet, but based on the discussions in the archives (and the mathematics), it should work.
> > Steve
> > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > > Unfortunately, I couldn't find any major discussions, but this thread touches on it: http://launch.groups.yahoo.com/group/xl7/message/14111 .
> > > If I find any other related discussions, I will post them.
> > > > Is it possible to simultaneously play tracks or patterns of differing length? You can only set the bar length for each pattern and play one pattern at a time as far as I can tell.
> > > > I did a search and found this:
> > > > > You can have patterns of different lengths playing
> > > > > alongside each other (e.g
>; > > > > a 3 bar pattern looping over a 4 bar pattern).
>; > > > > Patterns can be up to 256
> > > > > bars long....
> > > > Is this possible? Can someone elaborate?
> > > > Sorry if this has been answered before.
