This is intriguing. Its been years since I recorded music on the E-Mu sequencer intended for external gear. I seem to remember having to get the midi wiring and the rechannelize settings just right. I might play around with this when I get a chance.
When you say it plays back fine, but will not record correctly, that sounds familiar--until I got the wiring and settings worked out.
Good advice: In live performances, avoid looping midi data back into your controllers. (Is that a correlary of Murphy's Law?) ;-)
Steve
--- In xl7@yahoogroups.com, "bobsvitilla" <bobsvitilla@...> wrote:
> Maybe it is in my settings, but I find in order to record data for external gear using the command station controls I have to assign a silent dumby preset to the channel and set the channel midi out to both (internal and external). It plays back fine on ext, but will not record correctly. If you are using your external gear's interface to send midi out (with local control off) to the CS and back out to your ext gear, it may not be an issue. I try to avoid any physical midi loops for a live performance setup, so; I have rarely setup even at home in that manner.
> --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > PS: Here are a few links to related discussions:
> > XL-7 newbie question - connecting to keyboard + rack synth
> > http://launch.groups.yahoo.com/group/xl7/message/20108
> > Sequencer midi out
> > http://launch.groups.yahoo.com/group/xl7/message/19580
> > Problems using the CS to sequence external synths
> > http://launch.groups.yahoo.com/group/xl7/message/20016
> > I know there are others related to using the E-Mu as a controller for external gear. If I find them, I will post there here.
> > There are other things you can do, such as embed sysex commands in a pattern directed towards you external gear.
> > Hope this helps.
> > Steve
> > Steve
> > --- In xl7@yahoogroups.com, "lutherblisset63" <lutherblisset63@> wrote:
> > > Hi,
> > > Finally upgraded to os 2.0, which to turned out to be an issue with the cable drivers. New cable with drivers built and it worked without trouble.
> > > I have one question for now. I'm mainly driving external synths with the xl-7 and one thing that takes time is having to set the midi to external and set the instrument to the default (nothing) on each new track.
> > > Is it possible to set a default for the patterns to cover this? I figured I would make a template pattern and copy it as required. This is still not very efficient. Any ideas?
> > > I notice there is software for editing the xl-7 - prodatum. Maybe I can load all the patterns with the template, then I'd be set.
