arpeggios
arpeggios
2002-03-24 by rob99brown
Is it possible to record the output notes of an arp?  I need to do
this internally - cant record into Cubase or whatever...
Rob
Re: arpeggios
2002-03-24 by emufreak1
Just make sure the option to transmit arps/riffs to the midi out
is "on".  You will then be able to capture them with your sequencer.
M2
--- In xl7@y..., "rob99brown" <rob99brown@y...> wrote:
> Hi,
> Thanks,
> Rob
Re: arpeggios
Yeah but this doesn't work with the internal sequencer....
> M2
> > Hi,
do
> > Thanks,
> > Rob
Re: [xl7] Re: arpeggios
2002-03-25 by Scott Ruda
If you really want to save the 'arpeggiated' notes into the sequencer
then you need to do that by going out of the box and then back into the
MIDI In, either using a direct connection or through an external MIDI
routing box. But normally you don't want to record the arpeggiations
into the sequence, because then when you play it back you will wind up
'apreggiating the arpeggiator', which is probably not what you want.
YMMV.
Scott
Re: arpeggios
2002-03-25 by rob99brown
Gotcha Scott,
I have a workaround (I only wanted the first 2 beat of the arp, so I
made my note-ons 2 beats long instead of 4).
Going out of the box and back in is not an option under current
conditions....
I realise that going out and back would be arping the arp, but of
course under such conditions I would switch off the arp!...  Although
arping the arp could produce some interesting results!!!
Rob
sequencer.
sequencer
MIDI
arpeggiations
up
want.
> YMMV.
> Scott
2002-03-25 by erik_magrini@Baxter.com
You can connect the MIDI Out Port to the MIDI In Port and record them that
way.  As far as I know this is the only way though...
"rob99brown" <rob99brown@...>
03/24/02 05:57 PM
Please respond to xl7
        To:     xl7@yahoogroups.com
        cc:
        Subject:        [xl7] Re: arpeggios
> M2
> > Hi,
do
> > Thanks,
> > Rob
Re: arpeggios
2002-03-26 by ezra_gold
sequencer
MIDI
arpeggiations
up
want.
> YMMV.
> Scott
That is one of my favorite tricks with the xl-7. You record an
arpegio type pattern into the sequencer then turn on the arpegiator
in the patch. By playing around with arpegiator pattern and note
lengths you can get some really neat sounding stuff. Controling
arpegio speed from a knob (thank you to whoever thought of this cord)
lets you add variations and energy where needed.
Ezra
Ezra
2002-03-26 by erik_magrini@Baxter.com
Only if you bend your cable....
Sorry, bad one I know.
Eww!  Kinky!
Re: arpeggios
2002-03-26 by rob99brown
Eww!  Kinky!
them that
> rEalm
> 03/24/02 05:57 PM
>         To:     xl7@y...
>         cc:
sequencer.
> > M2
> > > Hi,
> do
> > > Thanks,
> > > Rob
> xl7-unsubscribe@y...
Re: arpeggios
2002-03-29 by heinrich22001
Does this result in some rythmic delay stuff or whats the trick?
Heinrich
> sequencer
into
> the
> MIDI
> arpeggiations
wind
> up
> want.
> > YMMV.
> > Scott
cord)
> Ezra
> Ezra
Re: arpeggios
2002-03-30 by ezra_gold
You can use it as a rhythmic delay or a gate type effect (using the
standard arpegiator control knobs) but I have been using for
variations in my hook lines. Play or record a slow arpegio into the
sequencer. Make sure the arpegiated notes are relatively long in
duration and vary from note to note for interest. Pick another
arpegio pattern with a similar note structure and turn it on in the
patch. Now use the arpegio speed knob to start arpegiation within the
original recorded notes. By experimenting with patterns, note
lentghts, and knob twiddles you can get some really neat stuff. Your
hook can start out simple then become frenetic and "blenderized" as
you twist the knobs during the song.
I was just thinking about your suggestion to use this as a delay
effect. I have not tried this yet but I think that when using this
for delay/gate effects you can have the gate occur in a quantized
fashion even if the original note was played off beat. I will have to
play with some mutating background pads tonight. I think that it will
quantize the note on but I also think that you can change the
quantize granularity on the fly. Hmmmm a project..
Ezra
> Heinrich
> > sequencer
> into
> > the
external
> > MIDI
> > arpeggiations
> wind
> > up
> > want.
> > > YMMV.
> > > Scott
arpegiator
> cord)
> > Ezra
