Yes, it does clarify things a bit. I will try again later. Question, if it does
not play in the bank I loaded in how do I erase or remove it?
I appreciate it steve.
jt
Sent: Tue, April 19, 2011 5:30:27 PM
Subject: [xl7] Re: New Member Question about e-loader
Hi. I have been busy lately and have not had a chance to fire up my e-loader 1.1
to try to see whats going on there.
As for the factory demo songs and patterns, if you have the P2500 ROM installed,
the P2500 patterns should work. If you load them to the pattern bank 0, the
songs should also work, because (if I remember correctly), the songs >>point
to<< the >>patterns<< in pattern bank 0.
With the P2500 ROM, you might be interested in the 8 banks of the P2K Composer
ROM which were converted to work with the P2500 (or a CS with the P2500 ROM). I
believe they are in the files section.
Yes, without the specific ROM for which the presets are designed, they will not
make any sound. That's because the presets (aka patches) point to ROM samples
(or multisamples) in specific ROMS. (E-Mu calls these ROM instuments.)
The CS should have space for 4 ROMS.
I hope this helps clarify things.
Steve
--- In xl7@yahoogroups.com, Kings Queensofshowbiz <kingsqueensofshowbiz@...>
wrote:
> When I fixed the pcb board awhile back, I noticed it had a proteus 2500 rom
> installed. I don't know if this came with the MP-7 CS or someone installed it
> because the CS is second hand, and did not work at all when I bought it. What I
> was trying to download is preset banks ( Mo'Phatt preset banks) from Emu
> support, the MpToMp7 preset banks 0-3. The factory pattern and songs download I
> already have in the CS and did not need to reinstall them.
> So, I don't have the Mo' Phatt rom installed thats why the presets will not
> play? How many different ROM's can be installed in the CS? The Mp-7 should
> automatically come with a Mp-7 ROM installed?
> On the Midi Tracker (pg. 15) E-Loader Operation Manual, The Bank Select MSB,
>LSB
> (program change # MSB.LSB.PC) will not display.
> I have the Midi connection using M audio (midisport uno) that displays in
> eloader and (emu USB midi device #0) display in midi setup. The upgrade to 2.0
> is fine and I assume I am using E-Loader 1.1 because I downloaded it from Emu
> support.
> jt
> From: steve_the_composer <smw-mail@...>
> To: xl7@yahoogroups.com
> Sent: Fri, April 15, 2011 8:05:13 PM
> Glad to hear that worked. If you have downloaded the factory patterns and songs
> for the MP-7, they should work with the MP-7 ROM without any tweaking. If you
> download factory patterns and songs for a ROM you don't have installed, they
> won't play. Each track has pointers to the correct presets (bank MSB/LSB and
> program change number).
> I assume you have the MP-7 ROM installed. Were you able to successfully load
>the
> MP-7 factory songs and patterns in? and if so, do those play correctly?
> BTW, I assume you have e-loader 1.1. Also, I assume you have full midi duplex
> and that e-loader shows your device correctly in the midi settings--especially
> since you were able to upgrade to OS2.0.
> I will have to take a look at the midi monitor window another time. I know
> there's a filter that let's you choose which data it displays, but I haven't
> used it recently. What data do you want to see?
> Steve
> --- In xl7@yahoogroups.com, Kings Queensofshowbiz <kingsqueensofshowbiz@>
> wrote:
> > Hey, Thanks Steve that did the trick. I was finally able to open the file. I
> > have downloaded E loader 1.0 and installed the upgrade to MP-7 the new
>version
> > successfully to 2.0 from 1.31. The only issues or minor ones 1.) I have been
> > trying to figure out the presets for download on the Emu support page. I have
> > tried to download whats offered on that page to the patterns section of E
> > loader, but they will not play once downloaded. I don't know what bank
>section
> > they should go in, songs or patterns. I don't see any preset download section
> >in
> > the manual at all, only songs and patterns info ie.. SMF files (sequences)
> > upload and download. 2.) The Midi Tracker window of E loader does not show
> >the
> > channel info MSB, LSB etc..... I really appreciate all of you guys help. I am
> >a
> > film student thats required to design and score soundtracks for the movies
>that
> > I create any little advice goes a long way.
> > Thank you for your support once again.
> > R/
> > Jt (sirvesta)
