circuit bending a CS
2011-03-30 by James Ulibarri
2011-03-30 by Atom Smasher
On Wed, 30 Mar 2011, James Ulibarri wrote:
> this is nothing I would do considering the gibberish unusable sounds
> that bending renders. (to my ears) maybe if you're doing glitch or
> noisecore stuff i guess it would have it's place. but i have to hand it
> to this guy for the enormous nuts he displayed by doing this to a CS.
> kinda cool that he put the switches in the sides that remove.
for a tiny fraction of a second that seemed like a good idea: then i
remembered that i know how to program sounds using the provided interface
and using the provided controllers ;)
everything he's doing with his CS, i could do without drilling any holes.
...atom
________________________
http://atom.smasher.org/
"We really haven't done everything we could to protect our
customers... Our products just aren't engineered for security"
-- Brian Valentine,
Senior Vice President of Microsoft, Windows Division2011-03-31 by James Ulibarri
On Wed, 30 Mar 2011, James Ulibarri wrote:=================
...atom
-- Brian Valentine,
Re: [xl7] circuit bending a CS
2011-03-31 by Scott Solmonson
On Wed, Mar 30, 2011 at 5:10 PM, James Ulibarri <jamesulibarri@...> wrote:--anyone running a CS with MAX/MSP? that would be kinda sickFor algorithmic or generational stuff I run everything with Max/MSP, or Puredata depending on my mood/OS.For live interaction, no.
NUNQUAM NON PARATUS
oh wow. i want to learn pure data so bad for audio reactive visuals.
such as..
http://www.youtube.com/watch?v=Q0Mvj024I-0&feature=related
you're way ahead of the game than 97.9% of people on here..On Wed, Mar 30, 2011 at 9:08 PM, Scott Solmonson <scosol@...> wrote:
NUNQUAM NON PARATUS
They're essentially the same, and if your mind is already wired to understand the mechanics of programing subtractive, additive, and FM synthesis it's pretty easy to learn.My own experience is that when you move to that kind of software, the control/command structures expand greatly, but nobody wants to tweak little bits of the math in the FFT section of the PD audio realm (at least I certainly don't).So- my use is more on the control side, which means I need a very capable sound-renderer, which is why I'm on this list :)Re visuals, PD isn't well suited for anything beyond "basics"- I've created art installations in Max/MSP and then redid them in PD because I thought it would be "cleaner", but it's not. Every kind of visual programming environment like that seems to suffer from a "difficulty of recursion problem", and Jitter (companion to Max/MSP is very capable) (but Mac-only)- by comparison the PD visual packages (Framestein and GEM) are immature.On Wed, Mar 30, 2011 at 8:14 PM, James Ulibarri <jamesulibarri@...> wrote:
such as..
NUNQUAM NON PARATUS
NUNQUAM NON PARATUS
2011-03-31 by Bruno
2011/3/31 Scott Solmonson <scosol@...> > Re visuals, PD isn't well suited for anything beyond "basics"- I've created art installations in Max/MSP and then redid them in PD because I thought it would be "cleaner", but it's not. Every kind of visual programming environment like that seems to suffer from a "difficulty of recursion problem", and Jitter (companion to Max/MSP is very capable) (but Mac-only)- by comparison the PD visual packages (Framestein and GEM) are immature. What about Impromptu? As long as someone doesn't mind programming in Scheme... http://impromptu.moso.com.au/
