More Song Mode Questions
2002-03-22 by erik_magrini@Baxter.com
1. Basically it looks like there's only two tracks in Song mode, the
composer track, and another multichannel one for recording automation
moves and what not, correct?
2. If I'm in Song Mode, is the only way to select channels to record Quick
Edits via the area where you can select between Tempo, Bar Beat, and
Pattern?  It would be nice if you could use the Channel Up/Down keys for
this too.
3. Sometimes using the Channel Up/Down keys for selecting steps gives
unpredictable results.  For instance I'll press it three time to go up
three step, and it'll go back 5.  Weird, just me?
4. Is there anyway to see what pattern is assigned to a specific place in
a song while it's playing back, without pressing Pattern to go into that
mode?
Thanx!
