xl-7 sounds editor
2011-03-09 by XL-7 Group
Hellou guys, Can you please give a link to that xl7 presets editor. The latest good version. Did you guys had any trubles with it? I remember that I tryed to use it, but still in a beta version, and I got some of the saved xl7 presets reset. Thanks
2011-03-10 by steve_the_composer
I wrote a lengthy reply, but it didn't get posted. The bottom line: http://www.emigr8.me.uk/music/tools/proteum.htm The last I checked, the other one still had major problems. Hope this helps. Steve --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@...> wrote: > > > Hellou guys, > Can you please give a link to that xl7 presets editor. The latest good version. > Did you guys had any trubles with it? I remember that I tryed to use it, but still in a beta version, and I got some of the saved xl7 presets reset. > Thanks >
2011-03-10 by XL-7 Group
Thanks Steve, Did you use it, did you had any problems with the proteum editor? Thanks On 10.03.2011, at 02:37, "steve_the_composer" <smw-mail@prodigy.net> wrote: I wrote a lengthy reply, but it didn't get posted. The bottom line: http://www.emigr8.me.uk/music/tools/proteum.htm The last I checked, the other one still had major problems. Hope this helps. Steve --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@...> wrote: > > > Hellou guys, > Can you please give a link to that xl7 presets editor. The latest good version. > Did you guys had any trubles with it? I remember that I tryed to use it, but still in a beta version, and I got some of the saved xl7 presets reset. > Thanks >
2011-03-13 by steve_the_composer
I don't use the editors very much, but over the past few days I have been using them a little. I did not had problems with Proteum. In fact, I don't recall any having problems with it over the years--other than when I was doing some testing of new features being worked on a few years ago. I also used Prodatum yesterday without it crashing. I believe it may still have a very nasty design problem when it boots--wiping out the last state settings that were in effect at power down. (Under OS2.0 The CS/P2500 saves some last state info and restores it upon power up.) I will run some tests shortly to see if this still happens. Steve --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@...> wrote: > > > > Thanks Steve, > Did you use it, did you had any problems with the proteum editor? > Thanks > > On 10.03.2011, at 02:37, "steve_the_composer" <smw-mail@...> wrote: > > I wrote a lengthy reply, but it didn't get posted. The bottom line: > > http://www.emigr8.me.uk/music/tools/proteum.htm > > The last I checked, the other one still had major problems. > > Hope this helps. > Steve > > --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@> wrote: > > > > > > Hellou guys, > > Can you please give a link to that xl7 presets editor. The latest good version. > > Did you guys had any trubles with it? I remember that I tryed to use it, but still in a beta version, and I got some of the saved xl7 presets reset. > > Thanks > > >
As promised, I did some quick tests and was not able to duplicate the wipe out problem in Prodatum. So I went back and found the write-up on this issue. http://launch.groups.yahoo.com/group/xl7/message/20136 I am not sure I will be able to duplicate these tests this weekend on the latest version of Prodatum. However, I did notice yesterday and today that after changing the virtual Master Volume knob, sound stops on my P2500 until such time that I change the Master Volume by hand. I am not sure what';s going on there, or if it is unique to my setup. Finally, I did test channel switching (selecting each of the channels) to see if that would trigger a crash. On Prodatum 0.38, a crash was triggered once followed by 3 succesful tests. On Prodatum 0.41, I was able to select each of the channels 3 times with no crash. Steve --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote: > > I don't use the editors very much, but over the past few days I have been using them a little. I did not had problems with Proteum. In fact, I don't recall any having problems with it over the years--other than when I was doing some testing of new features being worked on a few years ago. > > I also used Prodatum yesterday without it crashing. I believe it may still have a very nasty design problem when it boots--wiping out the last state settings that were in effect at power down. (Under OS2.0 The CS/P2500 saves some last state info and restores it upon power up.) I will run some tests shortly to see if this still happens. > > Steve >
2011-03-16 by stimresp
Hi - thanks for the info. I made an heroic attempt last week to compile the Prodatum 0.41 source for Win7. I failed. Instructions here if there are any coders about - http://prodatum.sourceforge.net/doc/build.html Life goes on - I'll stick with Proteum for now - it's more stable and I'm familiar with it's quirks at this stage :) --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote: > > As promised, I did some quick tests and was not able to duplicate the wipe out problem in Prodatum. So I went back and found the write-up on this issue. > > http://launch.groups.yahoo.com/group/xl7/message/20136 > > I am not sure I will be able to duplicate these tests this weekend on the latest version of Prodatum. > > However, I did notice yesterday and today that after changing the virtual Master Volume knob, sound stops on my P2500 until such time that I change the Master Volume by hand. I am not sure what';s going on there, or if it is unique to my setup. > > Finally, I did test channel switching (selecting each of the channels) to see if that would trigger a crash. On Prodatum 0.38, a crash was triggered once followed by 3 succesful tests. On Prodatum 0.41, I was able to select each of the channels 3 times with no crash. > > Steve > > > > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote: > > > > I don't use the editors very much, but over the past few days I have been using them a little. I did not had problems with Proteum. In fact, I don't recall any having problems with it over the years--other than when I was doing some testing of new features being worked on a few years ago. > > > > I also used Prodatum yesterday without it crashing. I believe it may still have a very nasty design problem when it boots--wiping out the last state settings that were in effect at power down. (Under OS2.0 The CS/P2500 saves some last state info and restores it upon power up.) I will run some tests shortly to see if this still happens. > > > > Steve > > >
2011-03-22 by laszlozizics
i try that 2 but didnt like it.. and buggy here.... this is the best way but im not a programmer so i cant create the editor http://ctrlr.org/ i use blofeld ctrl eidot and it is rock!!! brillinat... vst and standalone editors available... mybe a collab for the CS editor would be great... --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote: > > I wrote a lengthy reply, but it didn't get posted. The bottom line: > > http://www.emigr8.me.uk/music/tools/proteum.htm > > The last I checked, the other one still had major problems. > > Hope this helps. > Steve > > --- In xl7@yahoogroups.com, XL-7 Group <dacian_victor@> wrote: > > > > > > Hellou guys, > > Can you please give a link to that xl7 presets editor. The latest good version. > > Did you guys had any trubles with it? I remember that I tryed to use it, but still in a beta version, and I got some of the saved xl7 presets reset. > > Thanks > > >
