Archive for xl7.
DAW w/ CS
DAW w/ CS
2011-01-30 by James Ulibarri
I'm starting to see the beauty with using a soft sequencer and dumping the song to a CS.  I think Andrew planted that seed in my head.  What's killing me is hearing all these deep progressive house trax and hearing all these amazing trax with
modulation and these killer envelopes that are absolutely tracked or clocked...  Or however you would put that term.  Simply these blissful rises you here now that increase cutoff and decay (at the same time). The ability to draw modulation envelopes to make these insane builds and just quit or dip right at the right moment when some wicked transition comes in.  Gawd, amazing.  I think it's normal to look over at your CS and wonder if the unit is going to bring you usability for the next 10 years.   Granted, there are a lot of hip hop guys out there that have no use for this kind of stuff that own CS's.  But that's not who I am talking to or trying to get feedback from.
When dumping midi files to the CS such as tracked/clocked drawn modulation is omitted I am assuming....
I am talking about say filter cutoff at measure 2.1 to 8.4 with a value of like 10 to say fully open at 127 at any point within a sequence, right down to beats/measures.  Will these kinds of events import over to type .mid files through e-loader?  If not, then I think what a damn shame.  And what a hassle to do this on the CS when it's so silky smooth on a soft sequencer.  FL studio, etc.   I think real-time tweaks on the CS is not exact enough for what I am talking about.
Re: [xl7] DAW w/ CS
2011-01-30 by Szőnyi András
> like 10 to say fully open at 127 at any point within a* *sequence, right
All data of the sequence is stored in the MIDI file,
and all parameters should be seen in a DAW.
I assume that you use Ableton Live:
in the Envelope view of a clip the modulated parameters can be edited.
Or you can select yourself any modulations by their MIDI Ctrl number.
(As I remember ususally the MIDI Ctlr number 79 and 80 mapped to the
filter cutoff and resonance of a factory patch.)
Andrew
Re: [xl7] DAW w/ CS
thanks, bro.  I will try it and let you know what happens.   Ableton and the CS could be the deadly combination.
Andrew
Re: [xl7] DAW w/ CS
There's an annoying issue with Ableton: the way it exports MIDI.
Ableton lets you export only ONE clip to MIDI, not the whole arrangement
or a whole row in the session view. With other words: no multitracks.
(Although it can import or open multitracked MIDI files fine.)
If you use other (older) DAWs, like Cubase, Logic, ProTools,
Sonar/Cakewalk, etc... they are able to export multitrack MIDI.
BTW I also use the Live because it's very fast and intuitive in many ways.
So if I want to send back edited MIDI from Ableton into the CS,
I synchronize them and simply play/record it.
Andrew
>> modulation
>> of
>> .mid
>> a
>> sequencer.
>> for
>> Andrew
Re: [xl7] DAW w/ CS
That's totally nuts man. ( In a good way).
Yeah I don't mind that it does one track at a time.   I think a multitracked file would just make things more complicated.   I love how you said you're juggling files back and forth
to the CS and Ableton.  I love the sound of that work flow.   I wonder why more people aren';t working like this.  Or maybe they are and they're just keeping it on the low.  That's cool if they are and I respect that.   I'll be trying this tonight.
2011/1/30 Szőnyi András <andras@...>
Andrew
>> modulation
>;>> is omitted I am assuming....
>> of
>> .mid
>> a
>> sequencer.
>> for
>> Andrew
Re: [xl7] DAW w/ CS
2011-01-31 by James Ulibarri
let the fun begin!
2011/1/30 James Ulibarri <jamesulibarri@...>
to the CS and Ableton.  I love the sound of that work flow.   I wonder why more people aren't working like this.  Or maybe they are and they're just keeping it on the low.  That's cool if they are and I respect that.   I'll be trying this tonight.
Andrew
>> modulation
>> of
>> .mid
>> a
>> sequencer.
>> for
>> Andrew
Re: DAW w/ CS
2011-01-31 by stimresp
I've had only limited success dumping DAW-derived patterns into the CS vi e-loader. Usually, the channel information is not retained, and sometimes the imported pattern introduced some note offsets.
However, it is possible to record a multichannel pattern/arrangement onto a multichannel (Multi-A) track on the CS (using 'first note record'), copy that track to clipboard, then 'explode' it to the individual tracks. Works for me.
I'm also using stepbeater VST to program drums. The midi-drag-drop imports directly into e-loader with channel information retained, with sometimes minor-but-correctable timing issues. see: http://launch.groups.yahoo.com/group/xl7/message/21175
cheers,
J
--- In xl7@yahoogroups.com, James Ulibarri <jamesulibarri@...> wrote:
> let the fun begin!
> > 2011/1/30 Szõnyi András <andras@...>
> >> the
> >> Andrew
> >> > On Sun, Jan 30, 2011 at 1:33 AM, Szõnyi András <andras@...<andras%40c3.hu>>
> >> >> modulation
> >> value
> >> >> of
> >> right
> >> >> .mid
> >> what
> >> >> a
> >> >> sequencer.
> >> >> for
> >> >> Andrew
Re: [xl7] DAW w/ CS
2011-01-31 by Szőnyi András
Maybe I was not clear:
If I upload a pattern to the PC using Eloader,
and after open it in Ableton, I can't export the full
pattern as a standard MIDI file, only one track of the pattern.
So the workflow I mentioned before
(Write a pattern in CS ->
Upload to the PC by Eloader ->
Edit it in Ableton ->
Export it as MIDI file ->
Download that MIDI file back to the CS by Eloader),
doesn't work for me only in that case if the pattern has one single track.
For multitracked patterns I use different DAW to export the MIDI,
or if I edit the pattern in Ableton, I can only record the tracks
one by one in the CS via MIDI.
Or can anyone export from Ableton any multitrack MIDI file?
Andrew
> 2011/1/30 Szőnyi András <andras@c3.hu>
>> Andrew
>>> On Sun, Jan 30, 2011 at 1:33 AM, Szőnyi András <andras@c3.hu<andras%40c3.hu>>
>>>> modulation
>>>> of
>> right
>>>> .mid
>> what
>>>> a
>>>> sequencer.
>>>> for
>>>> Andrew
Re: [xl7] DAW w/ CS
2011-01-31 by Matt
I had problems with stuck MIDI notes when sequencing other hardware with ableton demo so I never purchased. Anyone know about this and how to fix? I also had sync problems with tempos jumping to 0.
> and after open it in Ableton, I can9;t export the full
> Andrew
>>> Andrew
>>>> On Sun, Jan 30, 2011 at 1:33 AM, Szőnyi András <andras@...40c3.hu>>
>>>>> modulation
>>>>> of
>>;> right
>>>>> .mid
>>;>>>> files through e-loader? If not, then I think what a damn shame. And
>>> what
>>>>> a
>>>>> sequencer.
>>;>>> for
>>>>>; in the Envelope view of a clip the modulated parameters can be edited.
>>>>> Andrew
Re: [xl7] DAW w/ CS
Matt, sounds like that demo was kinda shwag.   Try another build.  What version was it.
Andrew.. ok that makes a bit more sense now.  All that Scale/Shift stuff that we talked about all last week did nothing for me.  I was so stoked to try it out and it had minimal results if any at all.  All that braniac work for nothing.   I think it would be easier to use Ableton's groove pool facility and import the midi file back to the CS.  Lots of options here.  But at this point I think I won't even mess with that either.  I am not gonna mess with it.  I have my SP1200 for beats and that takes care of me and then some.  All this stuff works great on paper, and theoretically it's supposed to do this or that.  But it's the real world results that really matter.  You just gotta just keep workin on it till it's right.  But it sounds like you got it down big time. ; That's cool!  I need to play catch up this week.
2011/1/31 Matt <somatt@...>
> Andrew
>>> Andrew
>>>>> modulation
>>>>> of
>>> right
>>>>;> .mid
>>> what
>>>>> a
>>>>> sequencer.
>>>>> for
>>>;>> filter cutoff and resonance of a factory patch.)
>>>>> Andrew
Re: [xl7] DAW w/ CS
2011-01-31 by Bruno
W dniu 31 stycznia 2011 19:14 użytkownik James Ulibarri
1. Install MIDI Yoke (a "virtual MIDI cable", which connects one
software to another).
2. Get your stuff done in Ableton.
3. Install any other MIDI sequencer that can record multitrack - I
think Smasher would do (it's free and seems interesting on its own),
but you can use anything else. I would (personally) use my old,
venerable Cakewalk 3.0 - no multitrack, but you can easily do "split
by channel" later.
4. Connect the output of Ableton to MIDI Yoke, then use it as input
for Another Sequencer (AS).
5. Set AS to be a MIDI slave - external MIDI Clock etc.
6. Set Ableton to transmit MTC (MIDI Time Code), so you can press
Record in AS and it won't start recording until you press Play in
Ableton.
7. Record MIDI in AS, export to multitrack MIDI file.
8. Upload thru Eloader and enjoy.
Yeah, there's some hassle involved. But once you get this procedure
working, it will be a no-brainer. And if you find Ableton more
powerful than CS in building patterns, I think it's worth of one day
spent on getting those things rolling.
Cheers,
Bruno
Re: [xl7] DAW w/ CS
good tips, Bruno.  Thanks!
I did get it to work on it's own without midiyoke.  Maybe not in the same way that you're explaining.   E-loader is a pain on some XP systems as everyone knows.  But it's working.
Now you and Andrew have a certain work flow in Ableton that I don't think may assist me.  I just use Ableton as a sampler with VST support.  I don't do any midi editing after the fact. I think for me that would be taking the scenic route. ie, the long way around.  Now for full blown house trax, yeah... it's critical that you can see everything on screen.  But I'm trying to figure if Ableton just does one track at a time for .mid import/export, than how does one select the target midi channel when you're doing one part at a time?  I mean I know how to dump a sequence back and forth to my PX-7 and E-loader.  But obviously I have several parts within in that pattern that I need.   So I have say this great arpeggio that I have going.  Ok in E-loader it appears that only one track (single track/single channel) midi file can be imported/exported into the CS... where do the rest of the parts go without being overwritten?  How do you seperate these track from writing over the top of them over and over and burning up your time.   See, this is what I am saying...  all this stuff "works"... Yes.  But from a speed and productivity point of view.. it's questionable.   Oh, I don't even need to think about it. I'll be honest.  It slows me down.   But it does work.
2011/1/31 Bruno <brunorc@...>
by channel" later.
Ableton.
Cheers,
Bruno
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
   Individual Email | Traditional
<*> To change settings online go to:
   http://groups.yahoo.com/group/xl7/join
   (Yahoo! ID required)
   xl7-digest@yahoogroups.com
   xl7-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
Re: DAW w/ CS
I posted a reply earlier but it seems to have been lost. Anyway, the  gist was:
Using 'first note record' and quantize off you can record multichannel data, in real time + automation, from your DAW into a single multichannel track (set to Multi-A), copy to clipboard, then 'explode to tracks'.
Don't have the CS in front of me to check, but this has worked for me.
Another possible solution is detailed here:
Cheers,
J
--- In xl7@yahoogroups.com, Bruno <brunorc@...> wrote:
> W dniu 31 stycznia 2011 19:14 u¿ytkownik James Ulibarri
> <jamesulibarri@...> napisa³:
> by channel" later.
> Ableton.
> Cheers,
> Bruno
Re: [xl7] Re: DAW w/ CS
I am going to try it in FL Studio and report back.
Cheers,
J
> napisa³:
> by channel" later.
> Ableton.
> Cheers,
> Bruno
Re: DAW w/ CS
Make sure you are in multi mode and that rechannelize is off (both in the MIDI menu).
> > was:
> > Cheers,
> > J
> > --- In xl7@yahoogroups.com <xl7%40yahoogroups.com>, Bruno <brunorc@>
> > > <jamesulibarri@> napisa³:
> > do this or that.
> > > by channel" later.
> > > Ableton.
> > > Cheers,
> > > Bruno
Oh ok, now I see why you're using MidiYoke.  The apps are fighting over the midi ports.  I ran into this in the past.  One c-blocks the other as they're jockeying for resources the whole time and one falls off.   I gotcha now.
Neat stuff, but I am not feeling the integration.  That's just me tho.  If I were to use a full blown DAW than I would just get a midi controller and leave the CS off the chain.  I think it complicates things.  Atleast at this point.   I'll probably get bored and try and jack with it later.  Right now tho, I am not feeling it.
FL Studio was worse by the way.
> > was:
> > Cheers,
> > J
> > --- In xl7@yahoogroups.com 40yahoogroups.com>, Bruno
> > > napisa³:
> > do this or that.
> > > by channel" later.
> >; > Ableton.
> > > Cheers,
> > > Bruno
For now it's just the PX-7 straight to Kontakt running under Ableton straight from the CS's sequencer, and beats coming from the SP.  All my voices are from the Emulator II+ recorded as waves.   I think I am living in the dark ages, but that's cool.  It works for me!
> > was:
> > Cheers,
> > J
> > > napisa³:
> > do this or that.
> > > by channel" later.
> > > Ableton.
> > >; 7. Record MIDI in AS, export to multitrack MIDI file.
> > > Cheers,
> > > Bruno
2011-01-31 by Bruno
2011/1/31 James Ulibarri <jamesulibarri@...>
Whatever floats your goat ;-)
Right now I'm tied to DAW if I want to sync my machines, since Unitor
is a bit gestapish in determining the MIDI clock source - the device
has to send MTC Song Start and then clock, that makes Unitor happy.
Unfortunately KS5 doesn't send Song Start, while SY77 doesn't send
MIDI Clock (afaik), and I'm still waiting for my XL7 to come (happily
owning P2K tho). But I feel more and more inclined to *play*, record
it with MIDI, and then tweak. I used to switch from synths to DAW,
back and forth, but that's just waste of time.
I would, however, wholeheartedly recommend you to dedicate one weekend
for MIDI. It can be a huge productivity booster, once you find your
paths thru it, and it can give strong foundations (as well as
finishing shine) for your live creation.
Bruno
2011-01-31 by Matt
Let's get back to the issue at hand.
Can't you just link cutoff and decay in ableton on one cc before it's routed to the vst?
On Mon, Jan 31, 2011 at 12:15 PM, James Ulibarri <jamesulibarri@...> wrote:
For now it9;s just the PX-7 straight to Kontakt running under Ableton straight from the CS's sequencer, and beats coming from the SP.  All my voices are from the Emulator II+ recorded as waves.   I think I am living in the dark ages, but that's cool.  It works for me!
> > was:
> > Cheers,
> > J
> > > napisa³:
> > do this or that.
>; > > software to another).
> > > by channel" later.
> > > Record in AS and it won';t start recording until you press Play in
> > > Ableton.
> > > Cheers,
> > > Bruno
2011-01-31 by Matt
So what's up with the ableton? why is it so awesome?  I know james will have a good answer for this.  When I first got into music it was like some type  of jive keyword if you're cool dubstepper kid u got the ableton.  That and being a desktop support tech totally turned me off of it since I don't want to be working (troubleshooting shit on the computer) when I'm supposed to be playing (making music).  But now I am starting to understand the power of the ability to view my patterns on a huge screen, and piano roll and stuff which can be a huge benefit.  These are things you can't do on the CS.
Usually when I'm recording I just do live sets into audacity or a minidisc recorder... but i've been looking into possibly trying to integrate my computer.  I have reason 5, I have a demo or renoise, I still keep hearing that if you want to be pro you need to get ableton live... which is both attractive and unattractive about it.
I have also been hearing good things about the Nuendo, pro tools, peak, cubase.  I have a little bit of experience with digital performer, but not enough to make me want to use it.  lol.
What's up DAW users give me the lowdown!  Maybe this should be a new thread.
-matt
> > was:
> >; Don't have the CS in front of me to check, but this has worked for me.
> > Cheers,
> > J
> > > napisa³:
> > > >; All this stuff works great on paper, and theoretically it's supposed to
> > do this or that.
> > > by channel" later.
> > > Ableton.
> > > Cheers,
> > > Bruno
I'm not really one to talk about DAW stuff.  But since you asked, I will give me two cents.
Matt, Ableton uses clips which are just loops, and those clips can be midi or audio and used at the same time.  Depends what you're trying to do.  As I said, I don't skim the surface of Ableton.  I use it the way that works best for me.  I don't use the internal sequencer.  I let the CS do that because I like it for the ambient dub techno I do.   Now if I were working on dub step or house or progressive stuff, I would say screw the CS and just use Fruity Loops or Logic.  Because you need to see what you're doing and the ability to draw certain events with envelopes, etc.   I mean you know how in dub step you can hear LFO wobble for a few bars and then all of suden the rate increases and drops back down to a slower wobble?  Things like that.  Ableton does track out in a linear fashion like the other software programs but it's not something I know about or care to learn.  For me the CS is just a midi looper.  The sequencer imho doesn't allow you to build entire assembled tracks like a DAW can.  I mean you can if you have to but man what a hassle.  Are you honestly going to do an intro, a few bridges, a hook, 3 break downs, a chorus, etc, etc and whatever else it takes to make a traditional pop sounding proper song all on the Command Station?  I mean maybe there are guys on the list doing this.  But I doubt it.  It just doesn't seem like a very elegant way to work.   Ableton is just a easy breezy sampler to me.  But unlike my other million samplers, this sampler supports VST plugins!  I use Ableton like a live drummer would use Ableton. I would just use Kontakt but it doesn't have VST support.  Ask 5 different guys how they use Ableton and they'll all tell you something different on how they use it.   There really is no right or wrong way to use it since it's so versatile. I think it sounds thin but I have bitched and moaned about that kind of stuff for years and I am really beating a dead horse.
-matt
> > was:
> > Cheers,
> > J
> > wrote:
> >; > W dniu 31 stycznia 2011 19:14 u¿ytkownik James Ulibarri
> > > napisa³:
> > do this or that.
> > > by channel" later.
> > > Ableton.
> > > Cheers,
>; > > Bruno
Ableton (Re: DAW w/ CS)
2011-01-31 by just john
Others will probably have a better answer, but here's another bit of useful info.
I've enjoyed Ableton Lite for a couple years since it came with my Axiom 49 keyboard, and I'd been drooling over the modeling synth bits of Ableton Suite, which is sort of a maxed-out version.
Last autumn, I decided to go for their free trial of all of Suite, and sweet it was indeed.  Besides lots of more algorithmic power, it had a ton of very good preset sounds (something Lite lacks.)
So I get to the end of the month, and the "crippling" of the software kicks in.  But get this:  What is crippled is simply the saving of project files and the exporting of MIDI and sound files.  BUT IT STILL PLAYS!  In fact, it still records tracks.  Just grab the sound files the tracks are recorded to and copy 'em somewhere else, and there you go.  Here, for instance:
  http://soundcloud.com/just-john-jj/swordfish-101214-120ish
I'd realized this may be the case before my month ran out, so I spent some time preparing template projects, which I can open with the "crippled" version of Ableton Suite and perform with.  I can also open stuff I prepare with Lite and fiddle with them temporarily with Suite.
And by the way, it ran perfectly well on a three-year-old Mac Mini.
I do believe in software companies getting paid, and my hope is to get a Mac laptop and buy Suite for it.  (Insert Homer Simpson "donuts" sort of mmmmm sound here.)
* Radio Free Entropy: http://just-john.com/jjMusic
Re: [xl7] Ableton (Re: DAW w/ CS)
2011-02-01 by Zsolt Szabó
Come on people, if you want to use Ableton Live for serious MIDI sequencing,
than it's a no-go. Just for starter: no SYSEX support - it just filters it out.
And while you could have it with Max for Live, I bet only the real hardcore
will want to take it that way.
I use Nuendo with my XL-7 without any errors or problems. MIDI interface is an
Emagic AMT-8. I have all my gears connected to the AMT filling all 8 ports,
and can decide if the computer or the XL-7 is the sequencer/clock source.
Couldn't be easier...
Nearly all sequencers today have SMF 0 and SMF 1 support.
Not to speak about how much easier is to edit in Nuendo then record
the loop in the XL-7.
I used Logic before Nuendo, while it was available on the PC. And still,
the Hyperedit is the best for drum sequencing - wish it was available in
other DAWs, too.
    Zsolt | http://adsr.hu
2011-02-01 by Matt
"Matt, Ableton uses clips which are just loops, and those clips can be midi or audio and used at the same time.  "
So i'm getting you use it as an audio looping phrase sampler and sequencing everything with the CS?  cool.
"I mean you know how in dub step you can hear LFO wobble for a few bars and then all of suden the rate increases and drops back down to a slower wobble?"
I easily do this on cs with lfo knobs right?  Or I also do this easily with lfo knobs on any analog or analog modeler right?  I have a roland sh-32 i been playing with making lazers and weird, time signature based wobbles on.  I feel like these are easily made once one knows the way lfo's work, and sound interesting but don't replace melodies and interesting drum work, and I don't know or understand why dubstep artists seem to make wobblework programming such a showcase item while ignoring other important parts of their music, but possibly it is a fad.
My friend steve uses wobble work occasionally but usually the way he does it is he plays hiss wobbly bassline loops in with a synth whenever he gets his hands on one (friends house, school, wherever) then he loops those while he loops and layers with audacity.
Maybe he is weird maybe we both are weird i don't know many e-music people so i don't know what others are doing.
"Are you honestly going to do an intro, a few bridges, a hook, 3 break downs, a chorus, etc, etc and whatever else it takes to make a traditional pop sounding proper song all on the Command Station?  I mean maybe there are guys on the list doing this.  But I doubt it.  It just doesn't seem like a very elegant way to work. "
It seems like this could be done easily with song mode on CS, sequencing external sampler hardware or software like you're using. but major benefit to computer seems to be ease of editability on daw with screen and mouse and piano roll editing being the most major, right?
I making mostly live sets right now because I am not good with creating song structure so i just say fuck it and play it out then I try to transition patterns from one to another with x mix sometimes or sometimes I can do it with mixer tricks since i'm triggering external sounds.
I think for multitracking and creating produced finished songs with a a nice interface a daw like ableton would also be super helpful too since the CS can only multitrack with midi.
*shrug* this is getting long i guess i will wrap it up.
I feel like I'm looking to add an interesting element to my tracks that I am building with the CS, that maybe they need something, but then maybe I just need more practice.
Matt, Ableton uses clips which are just loops, and those clips can be midi or audio and used at the same time.  Depends what you're trying to do.  As I said, I don';t skim the surface of Ableton.  I use it the way that works best for me.  I don't use the internal sequencer.  I let the CS do that because I like it for the ambient dub techno I do.   Now if I were working on dub step or house or progressive stuff, I would say screw the CS and just use Fruity Loops or Logic.  Because you need to see what you're doing and the ability to draw certain events with envelopes, etc.   I mean you know how in dub step you can hear LFO wobble for a few bars and then all of suden the rate increases and drops back down to a slower wobble?  Things like that.  Ableton does track out in a linear fashion like the other software programs but it's not something I know about or care to learn.  For me the CS is just a midi looper.  The sequencer imho doesn't allow you to build entire assembled tracks like a DAW can.  I mean you can if you have to but man what a hassle.  Are you honestly going to do an intro, a few bridges, a hook, 3 break downs, a chorus, etc, etc and whatever else it takes to make a traditional pop sounding proper song all on the Command Station?  I mean maybe there are guys on the list doing this.  But I doubt it.  It just doesn't seem like a very elegant way to work.   Ableton is just a easy breezy sampler to me.  But unlike my other million samplers, this sampler supports VST plugins!  I use Ableton like a live drummer would use Ableton. I would just use Kontakt but it doesn';t have VST support.  Ask 5 different guys how they use Ableton and they'll all tell you something different on how they use it.   There really is no right or wrong way to use it since it's so versatile. I think it sounds thin but I have bitched and moaned about that kind of stuff for years and I am really beating a dead horse.
-matt
> > was:
> > Cheers,
> > J
> > > napisa³:
> > do this or that.
> > > by channel" later.
>; > > 4. Connect the output of Ableton to MIDI Yoke, then use it as input
> > > Ableton.
> > > Cheers,
> > > Bruno
2011-02-01 by James Ulibarri
"So i'm getting you use it as an audio looping phrase sampler and sequencing everything with the CS?  cool."
No. Just as one-shot audio samples.  I'll email you offline.
dude it's a joke.  it's so easy
-matt
> > was:
> > Cheers,
> > J
> > > napisa³:
> > do this or that.
> > > by channel" later.
> > > Ableton.
> > > Cheers,
> > > Bruno
Matt,
make 16 midi clips and load Simpler in each clip.  then down at the bottom drag wave files into the Simpler section.  boom. done.  now set the clip's midi channel to the corresponding midi channel that CS will transmit on for each part.   for each part/clip you will have all the CS pads and transposition available like a hardware sampler or tone module for every clip.  then set your output for the right audio output depending on your interface or sound card.   it's that easy.  now you can fire off clips like no one's business.  it's just a dumb sampler really if you use it like this.  But you'll have tons of filters and effects to drag and drop in there for each clip.  I'll be the first one to say that they don't sound like hardware analog filters, but what does anymore unless you have those beasts laying around.  And no one really cares either.  It doesn't get any easier than that.  You got your hardware and you got your own wave forms loaded up in there as clips.  Or just get Kontakt.   Another super easy soft sampler.  It's stupid easy man.
It's all your own waveforms and sequences.   It's kinda all you need. It's all I am doing now and I just ad a clocked drum machine to the chain.   Why drag out more than you need to? And if you want to be a known act out there you're gonna have to slim way down on what you drag out, and dragging this stuff to airport after airport.  90% of these guys aren't even bringing that much.  They have their laptop, an Evolution controller and like a Xone 92 with audio 8 interface and clean underoos.   seriously
-matt
> > was:
> > Cheers,
> > J
> > > napisa³:
> > do this or that.
> > > by channel" later.
> >; > Ableton.
> > > Cheers,
> > > Bruno
2011-02-01 by just john
> than it's a no-go.
Hey, I use it as an instrument.
Kinda like I use the XL-7, which ALSO is a no-go for serious MIDI sequencing.
But yeah, I fantasize about Ableton Suite on a laptop.  I could hook up the keyboard and a couple small speakers and sit in the corner of a bookstore like an old guy playing guitar or accordion.
2011-02-01 by Szőnyi András
Yes, I also found note offset problem.
If the pattern length modified by the Live, the CS looses the last notes
of the loop.
Thanks for this tip. I was trying to record with Multi MIDI mode and
switched off rechannelizing with no succes because I forgot to use
Copy/Explode track after recording. :)
Thanks for this link again, but for me is all about Live and CS.
I use Live to add grooves and shuffles to the CS patterns
and redraw the modulation curves if they need.
As I see Stepbeater doesn't offer these functions.
But anyway now I know how to record multichannels by CS
I satisfied with this workflow. :)
Andrew
> cheers,
> J
>> let the fun begin!
>>> 2011/1/30 Sz?nyi András <andras@...>
>>>> the
>>>> Andrew
>>>>> On Sun, Jan 30, 2011 at 1:33 AM, Sz?nyi András <andras@...<andras%40c3.hu>>
>>>>>> modulation
>>>> value
>>>>>> of
>>>> right
>>>>>> .mid
>>>> what
>>>>>> a
>>>>>> sequencer.
>>>>>> for
>>>>>> Andrew
Re: [xl7] DAW w/ CS
Not a bad idea, but it seems to be easier/faster recording it
directly by CS. :)
Andrew
> by channel" later.
> Ableton.
k
2011-02-01 by Matt
So that's what multi is for
> of the loop.
> Andrew
>> cheers,
>> J
>>> let the fun begin!
>>>>; multitracked file would just make things more complicated. I love how you
>>>>>; On Sun, 30 Jan 2011, James Ulibarri wrote:
>;>>>>> thanks, bro. I will try it and let you know what happens. Ableton and
>>>>> the
>>>>> Andrew
>>>>>;> On Sun, Jan 30, 2011 at 1:33 AM, Sz?nyi András 40c3.hu>>
>>>>>>> modulation
>>>>> value
>>>>;>>> of
>>>>> right
>>>>>>> .mid
>>>>> what
>>>>>;>> a
>>>>>>> sequencer.
>>>>>>> for
>>;>>>>> Andrew
yeah that was fun for about 3 days and now it's almost cheating and very boring.
Back to the Emax 1 and the ASR-X.   No computers for me for a while.
2011/2/1 Matt <somatt@...>
>; introduced some note offsets.
> of the loop.
> Andrew
>> cheers,
>> J
>>> let the fun begin!
>>>>> the
>>>>> Andrew
>>>>>>> modulation
>>>>> value
>>>>>>> of
>>>>> right
>>>>>>> .mid
>>>>> what
>>>>>>> a
>>>>>>> sequencer.
>>>>>>> for
>>>>>>> Andrew
Re: DAW w/ CS
2011-02-02 by just john
> boring.
I've got a spare Emax, if you want a backup ...
2011-02-02 by Matt
I want a emax rack.
>>; yeah that was fun for about 3 days and now it's almost cheating and very
>> boring.
2011-02-02 by James Ulibarri
try and look for an Emax SE rack.  that's the one to get
On Tue, Feb 1, 2011 at 11:19 PM, Matt <somatt@gmail.com> wrote:
I want a emax rack.
>> boring.
Re: DAW w/ CS
What I have is the Emax-upgraded-to-SE keyboard.
> On Tue, Feb 1, 2011 at 11:19 PM, Matt <somatt@...> wrote:
> > I want a emax rack.
> > >> boring.
give your feedback about the difference between the engine in that thing and any CS roms.  I would like to hear it from another user of the Emax 1.
> On Tue, Feb 1, 2011 at 11:19 PM, Matt wrote:
> > I want a emax rack.
>; > On Feb 1, 2011 10:10 PM, "just john" > > >
> > >> boring.
> > >;> Back to the Emax 1 and the ASR-X. No computers for me for a while.
2011-02-02 by Matt
How big is it
>> > I want a emax rack.
>> > >> boring.
that's what she said.  :|
you mean the rack or the keyboard. i actually have both right now and i am trying to sell the keyboard version.   the rack is deep.  the keyboard is no picnic either.
http://www.gearslutz.com/board/attachments/electronic-music-instruments-electronic-music-production/196023d1286145889-spam-emax-rack-sale-emax-.jpg
warning, the LCD and floppies usually are bad on these babies.  i've swapped the floppie drives and that was easy and you can find any floppy drive out there as long as it has a jumper that can be set to zero or one.   most floppies don't have this, so you gotta hunt them down.   the LCD's fade and sometimes you can't see jack.  you can buy a new foil or swap the entire thing to a simple 16x2 but you';ll probably get some jibberish in there and i'll tell you watch chip to swap to eliminate the noise, and then you're sorted.
finding an SE rack with scsi is next to impossible.   what's even more impossible is finding a copy of sound designer for the emax 1 to run on an old Mac and the RS422 serial cable to connect the two together.   it took me a while to get it all.
you can also run EMXP to dump .waves to the unit.
On Wed, Feb 2, 2011 at 1:59 AM, Matt <somatt@...> wrote:
How big is it
>> > I want a emax rack.
>> > >> boring.
2011-02-02 by Matt
Wow um I have been playing with my roland sh32 sequenced by cs. This is a wobble and pad beast with 4 synths or triple stackable synth and huge drums.  Controls are all on the face, and all throw ccs. no menus. Totally alive synths too. Amazing 32 step multi-part arpeggiator.  Too bad it only has 1 stereo out and can't change drum kits while playing.
2011-02-03 by steve_the_composer
You haven't figured out how to do serious midi sequencing on your E-Mu Sequencer? What are you trying to do?
What mode(s) do you use and for what purpose(s)?
This suggests some questions for discussion:
(1) What mode(s) do you use?
(2) What do you use this (these) mode(s) for?
When I did multitrack recording, I used multi mode since it allowed me to have different presets on different midi channels.
Currently, for live streaming performances, I use multi mode since it allows me to have different presets on different midi channels. I use a usb/midi keyboard --> P2500 to layer sounds (including arps) on each channel. Lately I have been using the 4x4 knobs in volume mode to mix the layers.
I almost never use the other modes, except for testing things that people ask about; however, I would be interested in knowing how others use these modes.
Steve
2011-02-03 by Szőnyi András
The original thread started from that issue how can be a CS track/pattern
microshuffled, or groove quantized. I suggested to use a DAW for this
processes, and after that the DAW question narrowed to only Ableton Live
- which is very good in groove quantization (from version 8),
but very weak in MIDI export.
I don't want to convince anyone to use Ableton instead of CS for sequencing.
I just wanted to say that you don't have to realize everything in the CS,
you can upload the pattern to a computer and  make "microtunings" in a DAW.
(Not specifically Ableton - Zsolt is right: ie. Nuendo/Cubase works
much better with the CS).
Andrew
Re: What mode(s) do you use and for what purpose(s)?
2011-02-03 by stimresp
To stream multichannel midi to the CS, and have each channel play it's own preset (i.e multitimbral), then use multimode with Rechannalise off. I use this mode with the DAW. The only thing to watch is that midi will always be recorded to the track currently selected on the CS. You can record multichannel data to this and explode it later - as detailed previously.
To record quickly into a track from a master keyboard for example, just select that channel on the CS, and switch rechannelize on. This is essentially the same as Omni mode (afaik).
Alternatively, keep rechannelize off and switch the MIDI send channel on your master keyboard.
Omni or poly modes are monotimbral only.
From the manual page 153:
Omni
Responds to note information on all MIDI channels and plays the preset
currently displayed in the main screen.
Poly
Responds only to note information received on the currently selected MIDI
channel (on the preset selection screen) and plays that channel's associated
preset.
Multi
Responds to data on any combination of MIDI channels and plays the
specific preset associated with each of the MIDI channels. You must select
multi mode for multitimbral operation.
> Steve
If the tools are there - why limit yourself?
The nub CS easily integrates with your DAW of choice and so benefits from all the the extra flexibility and (visual) precision afforded, record multitude patterns to the CS and mix from there, away from the PC, or compose on the CS and record the automation via DAW. Use VST Synths/samplers in parallel, and multitrack using the tons of high quality VST FX out there. Best of all worlds really.
Alternatively, one can struggle for years with a rack full of antiques in the hope that somehow the results will be more 'authentic' or whatever.
Cheers,
j
> Andrew
2011-02-03 by just john
For sequencing, the two-line lcd interface is idiotic, compared to ANY modern software package.  I mean, even Garage Band beats it.  In Garage Band, you can even work with standard music notation!
(Yes, I know Garage Band is severely, intentionally limited in its export facilities.)
It reminds me of an argument we had on John Shirley's bbs over writing a novel on a cell phone.  Sure, it's possible, but it's an exercise in masochism.
2011-02-03 by Ian Lamb
That’s one perspective, anyway.
Other people have a different experience in that the use of a computer changes their focus and awareness such that their musical flow is interrupted. The choice to use a hardware sequencer, even one with a small LCD, is not a choice born of idiocy, but one that recognizes their valuation of their musical process, and how the use of software isn’t conducive to that process. It’s also worth considering the other aspects of the UI design of the CS, and how that may be valued more than a mouse.
I do think your perspective is valid, but it’s true in a necessarily limited context.
cheers,
Ian
2011-02-03 by Matt
I think he means making songs since it's missing a scene function
2011-02-03 by Matt
I find the macbook super distracting or me as an artist, and I feel that it is distracting for fans at a show. I try to record everything elsewhere live and put on the computer in audacity just for post production export and uploading.
Just my opinion.
> sequencing.
Re: [xl7] What mode(s) do you use and for what purpose(s)?
2011-02-03 by Atom Smasher
my boring answers... i use:
* preset edit mode for, well, editing presets.
* pattern edit mode for editing patterns (duh) and also set-up functions
(eg track/channel settings).
* grid and realtime record for recording into patterns.
what i haven't really used: step-record and song-mode.
         ...atom
  ________________________
  http://atom.smasher.org/
 	"No! Try Not -- Do, or Do Not; There is no Try..."
 		-- Yoda, The Empire Strikes Back
2011-02-03 by Matt
Song mode is cool. Just remember if you put a pattern in song step record it will reset to the saved pattern. So if u put 3 pattern steps each time it will track off or on and reset to the original pattern. To get around this just put the pattern once and record from there.
I am trying to figure out how multi poly and omni work.
> ...atom
Re: [xl7] Re: What mode(s) do you use and for what purpose(s)?
2011-02-03 by Matt
Thank you!
> Omni
> Poly
> preset.
> Multi
>> Steve
>;> --- In xl7@yahoogroups.com, Matt wrote:
>> > So that';s what multi is for
2011-02-04 by gnarphlager@lycos.com
I haven't had my XL7 long, but most of the work I've been doing has been studio/soundtrack work, so it's been locked to my computer in multi-mode, using Sonar as a sequencer and software to edit presets/effects/etc.  I love it so far and the protean drums rom is making it on to everything I do!  I've demoed a couple old school electro-industrial tunes for the film I'm doing right now, and if that shapes into a project I want to play live with, the intention is to use the XL7 for sequencing, playing the internal sounds and likely a Virus.  I bought it because you can assign "next pattern" to a footswitch, leaving room for fluid "live arrangement" and jamming out as necessary, but leaving my hands free for other things, something all the other pattern based synths I've owned or currently own (emx and ermk2, pattern triggers on a korg karma and alesis micron.  I had a mc-909, but sold that to get the xl7 and haven't looked back.  well, maybe to the effects!).
Anyway, multi-mode, and pattern over song is the way I'm working these days.
josh
www.reverbnation.com/joshloughrey
music for film
enmity and apathy
Sent: Thu, 3 Feb 2011 06:00:58 -0500 (EST)
Subject: [xl7] What mode(s) do you use and for what purpose(s)?
Steve
2011-02-04 by Atom Smasher
my current (mini-)setup - http://smasher.org/tmp/IMG_0495.JPG
using hard panning and sub-outs, the XL7 has six mono outputs. each of the
six outputs is fed into a multi-effect box (mono input), then to the mixer
(stereo, except for kicks and bass).
i should probably just turn the XL7 effects off globally, but for now
they're just not not used.
         ...atom
 	"Every successful revolt is termed a revolution,
 	 and every unsuccessful one a rebellion."
 		-- Joseph Priestly, 1791
2011-02-04 by Scott Solmonson
Does anyone else use the XMix functionality?
I ashamedly have not been as active of late as in the past, but I used
to keep a consistent sound across each of the 16 tracks, so I could
fly in different pads and hats and perc etc on the fly to make a
constantly-moving sound structure, similar to a DJ mixing-
But then again, I'm a weirdo :)
-SS
>         ...atom
NUNQUAM NON PARATUS
2011-02-04 by James Ulibarri
my PX-7 sequences my Emulator II and Emax 1 SE rack.  i work in pattern mode
Just my opinion.
> sequencing.
atom,  cool to see a vortex in your setup
-SS
>;> I had a mc-909, but sold that to get the xl7 and haven't looked back.
>         ...atom
NUNQUAM NON PARATUS
2011-02-04 by just john
Would anybody really seriously attempt to write a symphony on a Command Station?  You can only see one note at a time.  And as far as I can tell, thanks the placement of the Big Knob, the only way to do any editing ergonomically is to hold the thing in your lap.
... which I have, fondly.  That cuts down on the arm strain from twiddling it over the course of a couple hours, just to move some notes around and adjust their paramaters.  Don't get me wrong, I love this thing.  But as far as sequencing goes, it's basically a loop sequencer.  Great for djing.  Not for really abstract, non-repetitive things.  Heck, it can't even play multiple loops of different durations at the same time, which both Ableton Lite and Garage Band can do.  And Ableton Lite and Garage Band came free with hardware purchases.
For "serious" sequencing, I frequently go to my decade-old install of Digital Performer, and export MIDI from there.
Yes, your mileage will vary.  I'm a big fan of Conlon Nancarrow, who did HIS sequencing by punching holes in paper player piano rolls.  I didn't know this back in college when I was debugging computer programs by manually tweaking Hollerith cards in the same way.
> sequencing.
Re: DAW w/ CS
Physically, it's pretty darned big.  So big, it's exiled to storage until I find a much larger place to live, or (more likely) a good home for it.
Let's see ... an E-mu PDF puts it at: Dimensions: 43" x 15\u2015" x 5", 20lbs.
> How big is it
> >> On Tue, Feb 1, 2011 at 11:19 PM, Matt <somatt@> wrote:
> >> > I want a emax rack.
> very
> >> > >> boring.
2011-02-04 by Matt
i wish... but gigging with that will give me back problems  :(
Let's see ... an E-mu PDF puts it at: Dimensions: 43" x 15―" x 5", 20lbs.
> How big is it
> On Feb 1, 2011 11:34 PM, "just john" > > What I have is the Emax-upgraded-to-SE keyboard.
> >>; try and look for an Emax SE rack. that's the one to get
> >> > I want a emax rack.
> very
> >> > >> boring.
2011-02-04 by Matt
james do you use multi mode omni mode or poly mode?
Just my opinion.
> sequencing.
Re: DAW w/ CS
I hear that!
That's why my fantasy is one Axiom-49 keyboard (keys just as big and responsive as the Emax, but way lighter) and one laptop.
Also, back when the Emax was my standard keyboard, it crashed so often (as did all computers of that generation) that I'd keep a DX-100 fired up as a standby.
> > 20lbs.
> > --- In xl7@yahoogroups.com <xl7%40yahoogroups.com>, Matt <somatt@>
> > wrote:
> > > How big is it
> > > > --- In xl7@yahoogroups.com <xl7%40yahoogroups.com>, James Ulibarri
> > > >> > I want a emax rack.
> > and
> > > very
> > > >> > >> boring.
> > while.
we are still talking about the command station right?  too big? back problems?   dude, i could chuck the thing across the room with my pinky finger.    i must have missed something.  I find the unit to be pretty small actually.  Like medium small.   Not electribe or MFB gear small.
> How big is it
> >> try and look for an Emax SE rack. that9;s the one to get
> >> > I want a emax rack.
> very
> >> > >> boring.
2011-02-04 by Matt
you could do this just by multitracking each track live in song mode right?
true this is the major bummer about cs
yea i think alot of people use proteum or whatever, I said f it and bought  some roms.
most of the time I use quantize erase and scale to move notes but yea editing a symphony in this way would suck
i think we need to mess with song mode more  before we hate on this sequencer
true but that's what a samplers for right
yea james uses ableton for a sampler in this way
My music teacher at college swore by DP and Reason for all his tracks.
Totally, midi is an electronic paper player piano roll imho
> sequencing.
Re: DAW w/ CS
No, that was the Emax keyboard thing he was talking about.
The only issues with the Command Station (for me) are the official bag for it, designed to route rain water into the insides, and the light (which I use) which can sometimes a pain to re-connect.
> >> 20lbs.
> >> wrote:
> >> > How big is it
> >> > >> > I want a emax rack.
> >> and
> >> > very
> >> > >> > >> boring.
> >> while.
omni.
the old emu samplers are setup for spans for different voices across the keys for different parts off the one global midi channel.
Just my opinion.
> sequencing.
oh, ok.   yeah the emax's are total tanks.  plus it's not something you really should move around at all.   the Emax is a cheaper Emulator EII with different SSM chips.   non of these samplers should be moved.   trust me, they love to break.  if you get one Matt, sample the Emax with another sampler like the little korg and bring that out, not the vintage Emu's.    sample the sampler?  yes, that's how you get cool sounds
> >> 20lbs.
> >> --- In xl7@yahoogroups.com 40yahoogroups.com>, Matt
> >> wrote:
> >> > How big is it
> >> > > --- In xl7@yahoogroups.com 40yahoogroups.com>, James Ulibarri
> >> > >> > I want a emax rack.
> >> and
> >> > very
> >> > >> > >> boring.
> >> while.
>  some roms.
Heck, even in pattern mode, adjusting the velocity of a note, holding the knob and waiting as it replays the pattern (or temp loop) over and over until it's exactly right and then going on to the next "problem" note ...  That's totally clobbered my right arm and back after a bit.  From the photo of your setup, I bet it's as bad, unless you're standing and really leaning over it.
Emax and other old samplers ... Re: DAW w/ CS
Hey, did anybody ever write something for a PC or Mac that could read Emax diskettes in a sensible manner?  If so, one could rescue samples that way, if one still had a diskette reader.
The one thing the Emax had that I've never seen elsewhere was the "Cruise Control" setting on the arpeggiator.  If you've set it up to play over a measure, then if you hold two keys, that's two notes per measure that get played.  If you hold nine keys, that's nine notes per measure.  Not a whole lot of "normal" music applications for it, but it was damned fun.
> they *love* to break.  if you get one Matt, sample the Emax with another
> > until I
> > 5",
> > > >> 20lbs.
> > > >> --- In xl7@yahoogroups.com <xl7%40yahoogroups.com> <xl7%
> > > >> wrote:
> > > >> > How big is it
> > > >> > >> > I want a emax rack.
> > cheating
> > > >> and
> > > >> > very
> > > >> > >> > >> boring.
> > > >> while.
Re: [xl7] Emax and other old samplers ... Re: DAW w/ CS
yeah it's called EMXP and you need to get a hardmounted floppy drive on your PC (not USB external kind) and use the Omniflop driver and you're good to go.   also the HxC floppy drive emulators are out that turn your floppy drive into a a SD card reader to store like 1000 voices on one card.   crazyness
i haven't dug into any of all this yet.   there isn't enough time or enough cash.
i'm kinda burned out too
>; they *love* to break. if you get one Matt, sample the Emax with another
> > >; finger. i must have missed something. I find the unit to be pretty small
> > until I
> > 5",
> > > >> 20lbs.
> > > >> --- In xl7@yahoogroups.com 40yahoogroups.com> > > 40yahoogroups.com>, Matt
> > > >> wrote:
> > > >> > How big is it
> > > >>; > > --- In xl7@yahoogroups.com 40yahoogroups.com> > > 40yahoogroups.com>, James Ulibarri
> > > >> > >> > I want a emax rack.
> > > >> Ulibarri wrote:
>; > > >> > >> > >> yeah that was fun for about 3 days and now it's almost
> > cheating
> > > >> and
> > > >> > very
> > > >> > >> > >> boring.
> > > >> while.
2011-02-04 by Zsolt Szabó
I mainly use it to lay down quick beats & loops as basis for
songs to work on. I use multi mode, almost exclusively pattern
sequencing, rarely song mode to try out different arrangements.
Ususally I use Logic 5.5 on PC to hyper edit the loops. It just
doesn't get any better than this. Then the output is recorded in
Nuendo as WAV.
I could use Nuendo for midi sequencing as well, but
I'm so addicted to hyper edit in Logic - the very best interface
for drum sequencing, ever.
For non-percussive sounds I don't use the XL7 at all - but I have only
the XL7 ROM, which is not very compelling to me.
Whean I assembled a partially OK song in Nuendo, then the MIDI
is transferred to the XL7, separated to tracks/channels.
Then I can experiment with the loop/song - I make the XL7
the master, which sends MIDI to my 8x8 setup - 2 x Waldorf mW1,
AKAI MPC-42, Yamaha FS1R, Lexicon MPX-1, Oberheim Matrix 1000,
and some routinly changing samplers and effects boxes.
I know, it's somewhat complicated, but then I can go live everywhere
with just the XL7 and still can precisely edit in the computer.
The biggest headache is to correctly setup the MIDI Local On/Off
and channel assignment through different songs and arrangements.
Oh yeah, keeping everything tidy and consistent unfortunately is
not an easy task with the XL7. What I really miss in it, is a "Save All",
which would assign & save everything as it is. I was seriously
disappointed when I found out, that there's no such thing in it. :(
How many times did I forgot to save a preset? Too many...
especially when parallel editing several ones.
> to keep a consistent sound across each of the 16 tracks, so I could fly
that's the way to do it.
lately i've been using XMIX as a quick way to edit patterns... copy a
track from one pattern to another, edit as needed, save the new pattern. i
think i could "copy" (pattern edit) but this seems quicker, for me.
         ...atom
 	"It's unfair to the American public not to be honest."
 		-- Steven Parrish, Senior Vice President,
 			Philip Morris (Tobacco)
 		Wall Street Journal, 14 August 1995
2011-02-04 by stimresp
Interesting post.
FS1R here too ;) I'm looking to rack it and the XL-7 with a Waldorf pulse in a midi loop. Just waiting for this new rack case to become available: http://www.skbcases.com/music/products/proddetail.php?f=&id=646&o=pop&offset=1&c=78&s=78
XL-7 tracks 1-8 are reserved for Drums, Track 9 for Pulse, 10,11,12 for 3 parts FS1R, 13 for internal sounds (from the Vintage keys rom, mostly). Tracks 14, 15 and 16 are the MultiA/B automation tracks for buildups, fills, etc. There's also a blofeld in there - using the multi mode I can replace or layer any of the other tracks with a blofeld part. TBH I haven't used song mode - just x-mixing between patterns. I'm comfortable with this now.
Only problem is, my current soundcard (X-station) has only 2 inputs and I have no mixer. I've been using the XL-7 itself as the line mixer, but this is a crime. I want seperate outputs. Now hoping to soon snag an ESI ESU1808 - 18 input usb2 card, so I can  multitrack directly into Reaper and apply VST fx per track. Not sure if latency will allow this in realtime, but on paper it's a nice recording/mixer setup. Eventually I'll fill the lower slots with a proper mixer, eq/compressor so I can be CPU independent.
Workflow-wise I like to grid-record the core drum pattern - Hats, then BD, snare directly on the CS using the knobs - this is a great feature of OS2. I also like the swing and offset controls on the CS - pity that they are 'destructive'. Saving regularly is a necessary habit, aquired here via much cursing and gnashing of teeth:)
For everything else it's a mixture of playing it realtime via the x-station or using custom sequencers in Reaktor. Record everything onto the CS, mix and match, etc.
> Nuendo as WAV.
> Regards,
i'm unloading some pretty fierce stuff...
Roland TB-303 - $1800 - Mint
Emu Emulator II with Mac SE running Sound Designer w/ 1100 SD4EII voices on CDR
$1800 - Great condition
Emu Emax SE rack - Great condition  $500
Ensoniq ESQ-M rack $350
No pets.  No kids.  Never gigged.
wanted:  I want a 3rd pair of Emu PM5 monitors.  email me if anyone is selling some.  Must be mint or close to it
email me if anyone is interested
oh man!  took my idea :)
i am also gonna get an SKB case for my CS..  a similar one.
http://www.skbcases.com/music/products/proddetail.php?f=&;id=443&o=pop&offset=1&c=103&s=78#
with the same laptop shelf.   i'll mount a A&H Xone 92 behind the CS.  but i am worried that I may be reaching too far back and kill my shoulder blades.   i already have that pain going for some weird reason.   but it's only 14 spaces.   6 spaces for the CS and 8 for the mixer.  it should be OK.
i'm really stoked on this.   kick ass mobile setup.  it's gonna be sick functionally and look sick also
On Fri, Feb 4, 2011 at 3:24 AM, stimresp <stimresp@...> wrote:
Interesting post.
FS1R here too ;) I9;m looking to rack it and the XL-7 with a Waldorf pulse in a midi loop. Just waiting for this new rack case to become available: http://www.skbcases.com/music/products/proddetail.php?f=&id=646&o=pop&offset=1&c=78&s=78
> Nuendo as WAV.
>; the master, which sends MIDI to my 8x8 setup - 2 x Waldorf mW1,
> not an easy task with the XL7. What I really miss in it, is a ";Save All",
> Regards,
2011-02-04 by Matt
just found a emax se rack on craigslist for 250...
that's a good deal if everything works.  lcd could be faint if it hasn't been replaced and make sure the drive loads and saves.
i';m unloading some pretty fierce stuff...
2011-02-04 by Matt
Wow sold already 2 hours after ad posted.
>;>> on CDR
matt,
don't worry about those old machines.  they're are cool.  but they're more hassle than they are worth.  i am letting mine back in the water for an influx of casheesh for some other things in the studio i would rather have right now.
honestly if you're gonna get an old sampler it would make more sense to get an ASR-X.
2011-02-07 by James Ulibarri
Two Emax's left.  Keyboard and SE rack. $300 and $500.
is looking thin.
TB-303 - sold
Emulator II - sold
Novation Bass Station rack - As is.    (will turn on but no sound).  $75
Matt, any leads on an ASR-X?  I know where two are mint for around $300.
On Fri, Feb 4, 2011 at 2:46 PM, James Ulibarri <jamesulibarri@...> wrote:
matt,
2011-02-08 by just john
I've offered my old Emax SE keyboard to somebody at the Deep Listening Institute, for free.  (A 40 mile drive.)  I just can't bring myself to charge money for something I don't even know works any more.
So I asked 'em if they knew of any electronic musical instrument scrapyards.
        -- jj
> is looking thin.
> TB-303 - sold
> Emulator II - sold
> On Fri, Feb 4, 2011 at 2:46 PM, James Ulibarri <jamesulibarri@...>wrote:
> > matt,
> > right now.
> > an ASR-X.
2011-02-08 by Matt
I'm interested in an asr-x... I want a sampler of some sort.
I have an sp808ex but that's more of a long phrase sampler.  Can';t use it for one shot drums or it will disk read error on your hi hats unless you bounce them to a phrase.  Can't use it for synth unless I bounce to a phrase because no midi, so can't transpose sounds.  It really is less of a sampler and more of a remixer.
If I don't get something soon I'm going to buy an electribe.  Although now that I have grid mode figured out on the cs, buying an electribe seems a little senseless.
I also had a lead on a maxed esi2000 for $100 or an mpc500 for $280.  However I really know nothing about the esi or the mpc.
is looking thin.
TB-303 - sold
Emulator II - sold
On Fri, Feb 4, 2011 at 2:46 PM, James Ulibarri <jamesulibarri@gmail.com> wrote:
> matt,
2011-02-08 by James Ulibarri
"Can't use it for one shot drums or it will disk read error on your hi hats unless you bounce them to a phrase."
that's really ghey right there.   yeah you need a real sampler, bro.
do you need filters and LFO's?  if not, then don't forget the Akai S20, or Akai Remix 16 (hard to find) or the Akai Remix 88 (even harder to find).  or even the Yamaha SU200 or even the Yamaha SU10 as it sounds like you're needing just a simple one shot drum sampler.
Emax 1 rack drums sound filthy dirty in a good way by taking the sampling rate all the way down.  You have to choose before hand though.  You can't Resample like the Akai's.
If you're looking for the ULTIMATE drum sampler for the CS than find a Forat F16.   Eight individual outs with 8 analog chips on each output.  That's what I am after myself.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&hash=item43a34c66b8&item=290502502072&nma=true&pt=Keyboards_MIDI&rt=nc&si=4e5F5VywEc%252BFKfstzKqFyq6hbWY%253D
I have an sp808ex but that's more of a long phrase sampler.  Can't use it for one shot drums or it will disk read error on your hi hats unless you bounce them to a phrase.  Can't use it for synth unless I bounce to a phrase because no midi, so can't transpose sounds.  It really is less of a sampler and more of a remixer.
is looking thin.
TB-303 - sold
Emulator II - sold
> matt,
2011-02-08 by Matt
Whoa for that price u can get machinedrum or dsi tempest in june
On Feb 7, 2011 7:12 PM, "James Ulibarri"; <jamesulibarri@...> wrote:
"Can't use it for one shot drums or it will disk read error on your hi hats unless you bounce them...
> I'm interested in an ...
eeew, machine drum.   cold, cold, cold.
yeah, the F16 is expensive.  and rare.
2011-02-09 by Matt
http://www.facebook.com/topic.php?uid=380626645914&topic=16455
Possible reissue of sp1200 as well
On Feb 8, 2011 6:17 PM, "James Ulibarri" <jamesulibarri@...> wrote:
the problem with those ROMS is that you'll never get that dirty warm sound out of them.  it's all glistening clean all the time.  boooooo.....   sounds really nerdy to me.
the ASR-X and SP1200 get this dirty, Matt.
Drop something like this at one of your shows..
http://www.youtube.com/watch?v=phzGyVjZZ7A&feature=related
2011-02-09 by Scott Solmonson
"dirty" "warm" blah blah- this is sounding audiophilic-
That said I agree with James' statement, but a solution is much nearer and cheaper: analog VCAs on your way out from the master mix, be they tube or transistor.
My own choice is a Peavey solid-state unit made for guitars :)
-SS
NUNQUAM NON PARATUS
2011-02-09 by James Ulibarri
"analog VCAs on your way out from the master mix, be they tube or transistor."
those too.   Throw a genuine tape echo in there for good measure too!
-SS
On Tue, Feb 8, 2011 at 6:17 PM, James Ulibarri <jamesulibarri@gmail.com> wrote:
NUNQUAM NON PARATUS
2011-02-09 by Matt
What is the device called?
-SS
On Tue, Feb 8, 2011 at 6:17 PM, James Ulibarri <jamesulibarri@...> wrote:
> the proble...
NUNQUAM NON PARATUS
I don't remember- (my stuff is all packed up in bins at the moment)-
It's a fairly old Peavey FX stomp box that I don't use any of the FX on, but which provides a transistor gain section meant to create tube-like distortion for guitars.
Behind my 303 it created the most ripping acid lines ever.
Nowadays I use it behind my devices without distortion (SQ80 and TX81Z)
If you're lacking "warmth" then all you need is something with an adjustable analog gain circuit.
This can be something as simple and cheap as a Sansamp: http://www.tech21nyc.com/products/sansamp/classic.html
Or an optical compressor: http://www.joemeek.com/threeq3.html
Or as sophisticated as a Sherman: http://www.sherman.be/
"warmth" = even-harmonic distortion, and I'm guessing you already have a few things laying around that are capable of doing it in pleasing ways-
-SS
-SS
> the proble...
NUNQUAM NON PARATUS
NUNQUAM NON PARATUS
you can also use an RSP Saturator or SPL Charisma for a similar result.  But i don't think that this is the same effect as SSM analog chips and low bit depth and low sampling rates, although they all seem to have a very colored sound or decimated effect, but i think there are many variances of these aural textures.  the 1200 tends to have a lot of ring mod that the other samplers do not have.
-SS
-SS
> the proble...
NUNQUAM NON PARATUS
NUNQUAM NON PARATUS
