page 157
2011-01-18 by scodoha04
Can someone elaborate on the midi footswitch assign and the tempo controller on page 157.
2011-01-19 by steve_the_composer
What are you trying to do? (1) You can set the foot switches to different CCs. Think of the footswitches as Continuous Controllers that have two states: on and off. You can program them to do different things based on these states. (2) You can use midi controllers (CC = 0 -> 31, Mpr, or PWh)to change the base tempo. For example, you can use one CC to step the tempo up and a different CC to step the tempo down. If you set "UP" to PWh, the center = your base tempo, up = tempo up, and down = tempo down. If you set "DOWN" to PWh, the center = your base tempo, up = tempo down, and down = tempo up. You can do the same thing if you set UP and DOWN to the same CC. For example, I used a slider on a usb keyboard set to transmit CC = 25. The mid point of the slider = the base tempo. Moving it down makes the tempo go down; moving it above midpoint makes the tempo go up from the original base tempo. When I set UP to CC = 25 and DOWN to CC = 26, moving the slider set to transmit CC = 25 from 0 to 127 increases the tempo from the base tempo. Conversely, moving the slider set to transmit CC = 26 from 0 to 127 decreases the tempo from the base tempo. Just don't ask me how to set the range of the tempo increase and decrease. I never did anything with tempo controller before, but a quick test confirms that it works. Thanks for asking. I have thought about trying the tempo controller thing out, but never had a reason to do so. I hope this helps. Steve --- In xl7@yahoogroups.com, "scodoha04" <douglas.harvey@...> wrote: > > Can someone elaborate on the midi footswitch assign and the tempo controller on page 157. >
2011-01-20 by scodoha04
Thanks. Just trying to understand it. Footswitch 3 must come in from externally as cc data but 1 and 2 must be an internal mapping. The tempo controller is confusing because any cc regardless of its function can be set as a slider so I guess its more akin to footswitch 3. --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...> wrote: > > What are you trying to do? > > (1) You can set the foot switches to different CCs. > Think of the footswitches as Continuous Controllers that have two states: on and off. You can program them to do different things based on these states. > > (2) You can use midi controllers (CC = 0 -> 31, Mpr, or PWh)to change the base tempo. For example, you can use one CC to step the tempo up and a different CC to step the tempo down. > > If you set "UP" to PWh, the center = your base tempo, up = tempo up, and down = tempo down. If you set "DOWN" to PWh, the center = your base tempo, up = tempo down, and down = tempo up. > > You can do the same thing if you set UP and DOWN to the same CC. For example, I used a slider on a usb keyboard set to transmit CC = 25. The mid point of the slider = the base tempo. Moving it down makes the tempo go down; moving it above midpoint makes the tempo go up from the original base tempo. > > When I set UP to CC = 25 and DOWN to CC = 26, moving the slider set to transmit CC = 25 from 0 to 127 increases the tempo from the base tempo. Conversely, moving the slider set to transmit CC = 26 from 0 to 127 decreases the tempo from the base tempo. > > Just don't ask me how to set the range of the tempo increase and decrease. > > I never did anything with tempo controller before, but a quick test confirms that it works. Thanks for asking. I have thought about trying the tempo controller thing out, but never had a reason to do so. I hope this helps. > > Steve > > > > > --- In xl7@yahoogroups.com, "scodoha04" <douglas.harvey@> wrote: > > > > Can someone elaborate on the midi footswitch assign and the tempo controller on page 157. > > >
2011-01-20 by steve_the_composer
See below. --- In xl7@yahoogroups.com, "scodoha04" <douglas.harvey@...> wrote: > > Thanks. Just trying to understand it. Footswitch 3 must come in from externally as cc data Steve: Yes, based on the manual. (I haven't verified it.) Footswitch 3 routes incoming midi data to patchcords. > but 1 and 2 must be an internal mapping. Steve: 1 and 2 are connected to the footswitch jacks. You can: (1) Select the FOOTSWITCH JACK FUNCTION for each (See CONTROLLER submenu system): ---Midi FtSw ---Play/Stop ---Play ---Stop/Return To Zero ---Punch In/Out ---Tap Tempo ---Channel +, Channel - ---Sequence +, Sequence - ---Preset +, Preset - (2) If you have the external footswitches set up as MidiFtSw, you can route them as CCs in the patchcords. > The tempo controller is confusing because any cc regardless of its function can be set as a slider so I guess its more akin to footswitch 3. Steve: I am not sure what you mean here. To me, any slider or knob or switch can be set to various CCs. Also, you are limited to CCs 1 to 31 for the tempo controller on the E-Mu Sequencer. Steve: More importantly, if you assign one (or two) of the programmable knobs to one (or both) of the tempo controller settings [Up/Down], using the same channel, you will see the tempo go up and down--the same as I described with the use of my usb/midi keyboard. It will take about a minute or two, and when you turn the knobs, it might be less confusing than trying to explain it. Hope this helps. Steve > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote: > > > > What are you trying to do? > > > > (1) You can set the foot switches to different CCs. > > Think of the footswitches as Continuous Controllers that have two states: on and off. You can program them to do different things based on these states. > > > > (2) You can use midi controllers (CC = 0 -> 31, Mpr, or PWh)to change the base tempo. For example, you can use one CC to step the tempo up and a different CC to step the tempo down. > > > > If you set "UP" to PWh, the center = your base tempo, up = tempo up, and down = tempo down. If you set "DOWN" to PWh, the center = your base tempo, up = tempo down, and down = tempo up. > > > > You can do the same thing if you set UP and DOWN to the same CC. For example, I used a slider on a usb keyboard set to transmit CC = 25. The mid point of the slider = the base tempo. Moving it down makes the tempo go down; moving it above midpoint makes the tempo go up from the original base tempo. > > > > When I set UP to CC = 25 and DOWN to CC = 26, moving the slider set to transmit CC = 25 from 0 to 127 increases the tempo from the base tempo. Conversely, moving the slider set to transmit CC = 26 from 0 to 127 decreases the tempo from the base tempo. > > > > Just don't ask me how to set the range of the tempo increase and decrease. > > > > I never did anything with tempo controller before, but a quick test confirms that it works. Thanks for asking. I have thought about trying the tempo controller thing out, but never had a reason to do so. I hope this helps. > > > > Steve > > > > > > > > > > --- In xl7@yahoogroups.com, "scodoha04" <douglas.harvey@> wrote: > > > > > > Can someone elaborate on the midi footswitch assign and the tempo controller on page 157. > > > > > >
