Song Mode Strangeness
2011-01-16 by dutchbeats
Is it normal when I load up a song for it to have different mute settings than when i saved it? Also, after the first pattern in the song passes, is it normal for all 16 tracks to unmute where none had been before and the original pattern only uses a couple tracks? Then when you delete just the 'unmute 1st channel' event it goes back to normal?
Finally, is it normal for there to be a bunch of random track mutes recorded in song mode that i didn't even press? I sound sarcastic but these are very real problems with song mode in my xl-7.
Re: [xl7] Song Mode Strangeness
2011-01-17 by James Ulibarri
I've experienced this kind of file corruption too. Have you swapped ROMS lately?
Me, personally, I am constantly doing a reinitialize for the CS. I would get in the habit of backing up your stuff as much as possible. Because I think resetting the unit is something that one has to get to used to. I would not rely on this unit as your sole sequencer. There is no removable data storage on the unit, unfortunately, unlike other sequencers out there. So it's a crap shoot all the time for the data to stay clean as it's always gonna stay on board internally.
Anyone want to sell me a Studio 440 they're not using??
Re: Song Mode Strangeness
2011-01-17 by dutchbeats
i backed up my sequences but is there a way to backup user presets or are they stored on the sound rom? i haven't changed rom's yet and it just has the xlead rom. i didn't do a reset when i got it either and so far it has defragged once in two years of casual use.
i need new buttons but it is weird in song mode how random track mutes show up after real time recording the mutes. it's like it responds to velocity with the track mute buttons and throws in extra ones in the event list. which makes it all but torture to try and sift through and edit.
i think my days of dreaming about using song mode for any kind of arranging are over and i'll just keep recording on the fly mixes for as long as it takes to get the parts right then splice out the errors in daw.
worst part of song mode though is where the track mutes reset every 32 bars when the next pattern starts, making it impossible to render a live mix. micro-editing the errors at the 32 bar turnarounds is nothing short of advanced nuclear physics and involves sifting through a bunch of extra track mute events.
i could suck it up and get an mpc which i've never used and pre-arrange all of the change ups and break downs and choruses and then string them together. but that is why i chose the command station! so i can do everything on the fly. the 32 bar limitation in song mode is like tripping right at the finish line and kills what would have been a really 'perfect sequencer'.
i still love my xl-7 though
> lately?
Re: [xl7] Re: Song Mode Strangeness
2011-01-17 by Matt
Hi I think you might be arranging the pattern in step mode on song mode? I found when i do this each time the pattern is stepped the tracks will mute or unmute to match the original pattern. I can get around this by stepping it once and then recording. It will continue tto repeat the pattern without adding track mutes unmutes etc.
>> lately?
2011-01-17 by Matt
People have said cs is glitchy but whenever I have ever found the cs to be glitchy it was always found later to be user error. Lol. Like when I thought song mode was crap because I couldn't figure out how to repeat a pattern in a song without the track mutes. Or when I would save over a patch and it would break a pattern making it sound horrible. Or when it would get stuck in audition. Mode because I didn't know what it was and would have to reboot it to get it to stop lol.
> arranging are over and i';ll just keep recording on the fly mixes for as long
>;> worst part of song mode though is where the track mutes reset every 32
> mute events.
> sequencer'.
>>> lately?
>;>> would not rely on this unit as your sole sequencer. There is no removable
> there.
> settings
> is
> the
>>;> > original pattern only uses a couple tracks? Then when you delete just
> the
> these
yeah I hear ya. i won't be selling my px-7 anytime soon. i';ve tried everything under the sun too and there is nothing else that midi's up to laptop so quick and has all those knobs that throw's CC';s. the command station, sp1200, and a laptop is all i really need to do a live dub techno set all piping through an allen and heath zed 14 mixer. too easy!
> lately?
> > ';unmute 1st channel' event it goes back to normal?
2011-01-17 by steve_the_composer
Several years ago I used song mode twice (other than playing and listening to the factory demos): once to chain a sequence of patterns, and once to test overdubbing in song mode.
I am wondering if you tested the various EVENT SOURCE settings. Specifically, I am wondering if the mix setting affects track mutes.
This is just a shot in the dark, but I thought I'd mention it. Unfortunately, I don't think I will have time to explore song mode.
Steve
> > lately?
ah ha! so you say that in song mode after the first pattern passes and no other patterns are programmed, it will continue playing indefinitely the most recent pattern without reloading the mutes from the original pattern each pass after that? and, it will still record notes and events along the time line for as long as the song can accept data? so basically the length of the song is determined by either pattern length or note/event data, whichever is last in the time line. matt if this works i will buy you a cake with lots of rum in it!
i will also look into the event source menu again and try some different settings. thanks steve and james!
> mute events.
> sequencer'.
> >> lately?
> there.
> settings
> is
> the
> the
> these
2011-01-17 by Matt
If I understand you correct then yes. :)
>> mute events.
>> sequencer';.
>> > --- In xl7@yahoogroups.com, James Ulibarri <;jamesulibarri@> wrote:
>> >> I';ve experienced this kind of file corruption too. Have you swapped ROMS
>> >> lately?
>>; >> think resetting the unit is something that one has to get to used to. I
>> there.
>> settings
>> is
>> the
>> the
>> >> >; recorded in song mode that i didn't even press? I sound sarcastic but
>> these
dang now i have to find a baker who uses lots of rum. matt and group thank you! i did some testing and will try to make it simple.
things i learned today about command station song mode:
1) you can place a stop event or none event anywhere in the song. there could be a stop event first thing in the song, in which case the play button will appear to be broken ;) or there can be a none event anywhere in the song and set from 0-99 bars(max 99 bars in a step), in which case the sequencer will keep running and all note/event data still recordable and playing back in time on the midi track on through to the next pattern.
2) ending a song with stop vs none event: with a none event the sequencer will keep playing/recording note/event data indefinitely but no pattern will be playing. with a stop event the sequence will stop at the end of the last step.
3) ending a song without either of these will let the last pattern play indefinitely with no pattern reseting(yay!). this is the option to use when recording a live mix, just put one pattern in the song and let it play through the first cycle and then record track mutes and play notes etc forever.
4) about #3. another option besides recording over the indefinite loop is to make the patterns or 'steps' 99 bars in step edit. this is almost the same thing as above but with a pattern reload/mute reset occurring every 99 bars. one strange thing though is a 99 bar step will leave a blank in the bar field. a 98 bar step will say 98 but 99 will just have a dash. no big deal since 3 x 32 is 96 which would be an easier number to work with. also should mention that if you delete a 'none' step in step mode, the step before it will increase in length
the same amount of bars that the deleted none step was.
5) if you record note/event data past the last pattern and into the indefinite loop phase it will continue to record. if you then place a stop event at the last bar after recording, the song will be chopped off at wherever the last pattern ended and your work apparently lost. however, removing the stop event and letting the sequencer play through will let you hear the notes again. so the data track and the pattern order/orientation are on separate yet equal time lines!
lastly, hopefully fixable, after doing some overdubs and listening to the song again, the channel that i recorded notes with has been changed so it is playing the same midi data but using a different track with other sounds on it! yet i only get a choice between multi a and multi b so i don't know what went wrong or how to switch it back. this is in the box though for this test. i hope to sort it out for when i use it with my samplers.
cheers
> Song length determined by when the stop event is inserted I believe
2011-01-18 by steve_the_composer
Nice! Maybe I can find a use for song mode after all these years. Thanks for all the details!
Steve
> cheers
> > On Jan 17, 2011 9:13 AM, "dutchbeats" <dutchbeats@> wrote:
