As for patterns, there are two things that I can think of (1) factory patterns and songs that needed to loaded into your E-Mu sequencer using e-loader and (2) riffs.
I believe there are copies of the factory patterns and songs in the files section for the XL-7 and possibly some of the others. However, since these are set up with program change (preset/patch) commands for ROMS that you don't have, you would have to manually reassign the presets to point to presets in the ROMS you do have.
As for riffs, some of the ROMS have special bts riffs that contain multi-track sequences that are triggered by audion or the trigger buttons. The original P2000 ROM doesn't have bts riffs. I don't know if the beat garden ROM does.
To find out if the sequencer is working, I would record somthing and play it back. If that works, take a sequence already in your box and reassign each channel to a preset that corresponds with ROMS that you do have installed.
You can reset all data, but that will probably just wipe out user presets and/or all sequences. You would still have to either record and then play a new pattern, or upload patterns and set them to point to your presets.
Hope this helps.
Steve
--- In xl7@yahoogroups.com, "Paul Thompson" <bilbo33@...> wrote:
> hi all ,. ive just bought a second hand emu mp7 command station . i recieved it in great condition and with no roms inside ..ive bought and fitted the beat garden and prot 2000 roms . can anyone tell me if all the roms come with pre set patterns ( programs with several parts , bass , drums , sound effects etc where you can mute out parts etc ) all i can get out of the unit is riff demos when i press the audition button . the sequencer dosent seem to work ? im thinking the unit is faulty ? i did own an xl7 a year or so back , it came with the xl7 rom . it had many pre installed patterns to get me going . this mp7 dosent ???? can anyone help me please .. thanks , paul
