Heads-Up - Prodatum Patch editor updated
2011-01-15 by stimresp
See:
http://prodatum.sourceforge.net/
I sent a bug report to the developer, Jan, last week and he's been busy updating with some new features. Testers needed!
I've been experiencing crashes on Win7, mainly when changing channels/presets or multisetups. Anybody else?
An a side note - does anybody still use the USB connection on their Command Station, and if so, have you a working driver for Win7?
Re: [xl7] Heads-Up - Prodatum Patch editor updated
2011-01-15 by Elektrofunkenstein
Great! I've been experiencing some random crashes recently on win XP,
but I've added new roms so I wanted to set it up corecltly first on
CS(cleaning usless presets, ordering paterns and setups etc.) before
tackling the problem. I'm gonna try it and check how it works.
On 15/01/2011, stimresp <stimresp@...> wrote:
> See:
Re: Heads-Up - Prodatum Patch editor updated
2011-01-15 by steve_the_composer
I spent a lot of time testing earlier versions. Somewhere along the line, I started having lockup crashes of Prodatum on the same XP PC I had pervious success with. The problems you have might be related to Win7, but not necessarily.
For years I had problems with E-Mu usb drivers on XP, then somewhere around XPSP2 or SP3, they started working. I read somewhere that MS did something with usb enumeration that made the XP drivers work at long last. I believe I documented the issue in the group.
I know nothing about Win7, but don't expect E-Mu to release drivers for their legacy gear. However, don't give up--perhaps several years down the road there might be a Win7SP that solves the problem. It was years after I made the switch from Win98 to XP before the E-Mu drivers worked!
Steve
--- In xl7@yahoogroups.com, "stimresp" <stimresp@...> wrote:
> See:
