Black Command Station
2011-01-12 by James Ulibarri
I think Matt new about this, or I meant to tell him.
My quest for a black Command Station continues.
I've been working with StyleFlip to do a few Emu skins for the Command Station, Emulator II, and Drumlator.
Here is my Ableton/Command Station skin done in black and white. It's not 100% lined up correctly but I fixed it and it looks better.
It is removable and you can reply it as many times. They use a special type of 3M adhesive that doesn't supposed to hurt the original finish.
You can have one done in several different colors or even put photographs and different fonts and clip art.
I wanted to keep mine really minimal. You will have to lose your PX-7, MP-7, or XL-7 clear badge tho... It is just held on with glue
and removing it with an exacto knife in a corner will lift it up or you can gently punch it threw the other side if you take off the cover and remove the LCD
that's held on with two screws at the risers.
The one pictured is just a spare MP-7 cover and my plans for my boutique black PX-7 goes a lot further than this. This is just to hold me over... :)
PS. I am working with two other companies also for a couple more little surprises. Not a big deal, but still sorta cool.
James
James
