Swing question
Swing question
2011-01-11 by James Ulibarri
Is there a way to slightly delay the even numbered 16th note beats in a pattern? That is step 2,4,6, etc will play a little later than normal.
Anyone have any feedback to get this shuffly feel I am after.
Basically offsetting notes right? Not sure how one is to drill down on a specific note though, verses the whole pattern track? Is this possible?
Re: [xl7] Swing question
2011-01-12 by Atom Smasher
> possible?
XL7-OpMan-G.pdf - pg 79-80 (pdf pg 91-92) - Quantize & Swing
if you want to edit individual notes you can use the event editor, but i
think the quantize/swing is what you're looking for.
         ...atom
  ________________________
  http://atom.smasher.org/
 	"There was a time when the American people roared like lions for liberty,
 	 now they bleat like sheep for security."
 	     -- Norman Vincent Peale
2011-01-12 by James Ulibarri
Thanks, Atom. I knew all the quantization stuff and use it often. But I was trying to go into microscopic mode and shift individual notes (push/pull).
It's cool though. You can get pretty crazy with the CS as it is. No other box I've owned lets me get this crazy if you know the parameters to toy with.
And if you trigger dirty samplers and not internal sounds you can really get some sick techy stuff quickly.
thanks for your response
>; Basically offsetting notes right? Not sure how one is to drill down on
> possible?
...atom
";There was a time when the American people roared like lions for liberty,
> (push/pull).
then you're looking for the "Note List Editor" (did i call it the event
editor? that's for non-note events)... XL7-OpMan-G.pdf, pg 99 (pdf pg
111). you can get in there and move notes around, one at a time.
         ...atom
 	"Microsoft shouldn't be broken up. It should be shut down."
 		-- Bruce Schneier, 15 May 2000
I've studied shuffle for almost 3 years ore more and I swear it has to do more with attack and sometimes even velocity for more esoteric groove templates.
In Step Mode the gate parameters allow you to adjust those individual steps Gate time. I'm not seeing that parameter though anywhere else. Maybe I overlooked it. I've heard shuffle that's so good, that I swear half the note/step is almost chopped off at the beginning of the sample/tone. Sounds sooo good.
Almost to the point of it being so incredibly bouncy and almost choppy. More experimentation tonight!
> (push/pull).
...atom
> templates.
it's an inexact science ;)
> sample/tone.  Sounds sooo good. Almost to the point of it being so
i don't spend time in step mode, but in "Grid Record" you can edit the
gate time for each note. pg 70-71 (pdf 82-83).
what you're describing, though, about cutting off the beginning of the
note/step... you might want to experiment with synced LFOs or clock
divisors "patched" into SStart (sample start)... with or without a
"regular" shuffle, that could certainly add some spice. once you're
editing patch cords, you can really come up with some new ways to spice up
every other note... think about volume, filter, env times, x-fades, etc.
let us know what you find...
         ...atom
 	"Unthinking respect for authority
 	 is the greatest enemy of truth."
 		-- Albert Einstein
another sampler/sequnecer (almost OT)
2011-01-12 by Szőnyi András
Sorry for a new non-E-MU question but I've just found an old machine for a
reasonable price.
Does anyone know the Ensoniq ASR-X Pro? - btw it looks like a prototype of
the E-MU Command Stations. :)
(http://www.vintagesynth.com/ensoniq/asrxpro.php)
I'm especially curious about the sound of that, not the sequencer
capabilities. (The CS's sequencer or a DAW is good enough for me.)
I know it is difficult to objectively talk about the sounds,
I try to give an example what kind of sound I'm looking for:
Until now I owned two samplers: E-MU ESI32 and an AKAI MPC 4000,
to be honest I felt the ESI has a much better sample playback.
(Unfortunately both machine had to be sold...)
Do I think right the ASR-X Pro has an ESI32-like sound or better?
Andrew
Re: [xl7] another sampler/sequnecer (almost OT)
That is my next machine. I'm waiting for a good one to pop up and not beat up like so many are out there.
I think Emu took everything from this machine and the SP1200. Notice the obvious visual similarities.
The ASR-X accepts wave and .aiff files which is a serious bonus. It has the ESP-2 chip from the DP4 processor too (but not the same serial configurations in the DP/4).
I've read the CS and ASR-X are really good combination since the ASR-X gets so much slack for the sequencer,
which I am convinced that it's not that bad. Will see though. I'm also thinking the ASR-X has a much warmer sound
than any CS rom which I am not a fan of.
I think it would be a great addition to your setup. Do it!
reasonable price.
Andrew
2011-01-12 by Matt
He's right. This is amazing machine it is the groove box version of asr-10 amazing rare sampler.
On Jan 12, 2011 2:16 PM, "James Ulibarri" <jamesulibarri@...> wrote:
>; That is my next machine. I'm waiting for a good one to pop up and not beat
>> reasonable price.
>> Andrew
2011-01-12 by Matt
Pro model is red and had lots of upgrades.
>> reasonable price.
>> Andrew
2011-01-12 by Matt
>> reasonable price.
>> Andrew
>> templates.
I really like to play wit the CS's sequencer, but this is that point,
when I upload/download the pattern to a computer, and edit it visually in a DAW.
Jumping between the parameters of the notes in the CS's
submenus kills the groove and the musical idea. Or I am too impatient...
a
2011-01-13 by James Ulibarri
That's what I was afraid of. Atom is dead on when he says it's not an exact science. Nice. I'm yet to find a magic shuffle box.
I think the Europa from Analog Solutions has 9 settings of shuffle, and MAB's little drum machine do a decent little job.
This thing is cool too but I think it's just for Sync 24 machines.
http://www.youtube.com/watch?v=90VuRR7ctt0
Even if I do find the magic settings in the CS, how can I keep using that setting without having to drill down on each note again and jack settings, gate, etc?
The clipboard? Or does that take all the notes and steps with it? Basically I would want to make my own CS groove template(s).
I've gone full circle and sold my first PX-7 and purchased other sequencers and that didn't really suffice either. (MV-8800, MPC-3000, etc)
But my methods in the CS are working, but I want more and I wish it were easier. I want a magic shuffle button or knob! Wishful thinking over here I know.
>> templates.
a
2011-01-13 by Szőnyi András
> this one too.
> http://www.youtube.com/watch?v=FR6sbVRHlOU&feature=related
If I hear the gist, it's only a shuffle with higher resolution
with constant delays at particular parts.
I'm talking about "groove", which sometimes delays, sometimes hurries(?),
and even more plays with the accents and releases (of course depending on
samples).
I mean "human feeling", like this: http://www.youtube.com/watch?v=6FX_84iWPLU :)
OK, I never try to enter such nuances into a drum machine,
but somewhere between this and a shuffle.
(But if I could do it, I would like to be able to copy and paste that
groove to the bass channel, that's why I use a DAW on computer.)
Andrew
2011-01-13 by Atom Smasher
a lot of people think there's "magic" in the TR-909's shuffle.
> settings, gate, etc? The clipboard?  Or does that take all the notes and
> template(s).
a long time ago, i used an MC-50mk2 as my #1 sequencer. my bandmate wanted
it to do shuffle, but officially it doesn't support such a feature. so we
recorded the MIDI from a TR-909 into it... a few bars with each of the
909's different shuffle settings. with a little bit of editing, we could
play anything using the 909's shuffle.
you could do the same thing with a CS, but the editing might be a chore.
maybe use software and then load the sequence into the CS...?
         ...atom
 	"I am committed to helping Ohio deliver its electoral
 	 votes to the president [Bush] next year"
 		-- Walden O'Dell, CEO of Diebold
 		August 2003
How Music Works
  http://www.howardgoodall.co.uk/presenting/HMW.htm
  http://www.channel4.com/programmes/how-music-works-with-howard-goodall/episode-guide/series-1
episode 2, rhythm, spends quite a bit of time on this topic, from the
perspective of "How Music Works".
         ...atom
 	"That the only purpose for which power can be rightfully
 	 exercised over any member of a civilized community, against his
 	 will, is to prevent harm to others. His own good, either
 	 physical or moral, is not sufficient warrant. He cannot
 	 rightfully be compelled to do or forbear because it will be
 	 better for him to do so, because it will make him happier,
 	 because, in the opinion of others, to do so would be wise, or
 	 even right... The only part of the conduct of anyone, for which
 	 he is amenable to society, is that which concerns others. In the
 	 part which merely concerns himself, his independence is, of
 	 right, absolute. Over himself, over his own body and mind, the
 	 individual is sovereign."
 	 	    -- John Stuart Mill, On Liberty, 1859
i often hear it in my head, then tap it out in real-time-record.
         ...atom
 	"Everyone thinks of changing the world,
 	 but no one thinks of changing himself."
 		-- Tolstoy
You are right!
And tap it out with the same timing on the the bass channel too. :)
And if you can already do it anytime you want, you don't need to use
a midi sequencer anymore. That is all about. :)
Andrew
>         ...atom
> 		-- Tolstoy
Great information guys. Thanks for the links. Cool on taking the groove from the old Roland sequencer and kinda importing the shuffle to other boxes. Way cool. That's great idea to use a midi monitor of the 909 into a DAW. Great idea.
After some experimentation tonight I'm getting the right amount of shuffle out the SP1200 at 54% and 58% shuffle. Any more than that and it sounds like horses trotting and too much like triplets. And that's not the sound I'm looking for. I don't want a jazz feel or anything like that.
To me shuffle can't exist without static notes/steps behind grooved stepts that arrive early and late. If everything is colliding into each other without any type of static backdrop of on- time notes than you have a mess. Some notes need to be in place without any push or pull. That's just my thoughts on it.
Also whoever said to do stuff by hand is brilliant. I think some of my best shuffled stuff has came by playing pads by hand and letting the track breath a little, and then doing post-quantization and then listen to the magic. I never use 100% rate either. For some read reason I get the best stuff at about 54% and 54% with the CS. Also, another trick I learned was to record at 1/4 style and split the tempo in half. So if your goal is to play at 1/16th's, you are gonna now only have 8 steps and your tempo is at 64 verses BPM verses 128 bpm. I learned this in the SP1200 forum. I don't even know why this works but it seems to work well... at least for me. But when I go back and crank it back to normal I get different results. It could be a happy accident by someone and I copied their trick, or maybe it's just a placebo effect and nothing really cool is going on there. I don't know, but I like the end result.
You are right!
Andrew
> ...atom
> -- Tolstoy
2011-01-14 by Matt
Did u get it and how do u like it? I am thinking of asr-x from ebay or of electribe esx. I already have rs7000 sampler too but thinking of selling since it sits in the corner for difficulty of use and also I can't seem to program it on the fly. Or maybe I just need to spend more time with the manual.
> reasonable price.
>; I know it is difficult to objectively talk about the sounds,
> Andrew
2011-01-14 by James Ulibarri
Matt,
dude.. you already know my thoughts on the korg electribes and ensoniq stuff. honestly if i saw someone at a gig and i saw them with an electribe performing i would be like "wuss!". total cheese, dude. first of all the sequencer blows on the es-1. no swing, and no quantization, no shuffle. not sure if you're using any of those facilities but that's a big no no for me. how boring sounding. plus no real filters or LFO's. big deal if it says "filter". gee thanks. what kind of filter? lp/bp/hp at the very minimum let alone all the esoteric types in between must be implemented. no LFO's and no selectable waveshapes for those LFO's for the filter, pitch, etc. the ASR-X would allow you individual outs too if you bought the 8 output board. you can add a scsi board too for $100 from thesoniq.com
also the electribe effects are absolute cheese. that';s not an effect engine... not sure what that is. but ASR has the same chip in the DP4 for the most part. that's a real effects mainframe. one is a workstation and one is a toy. you can make music with the korg but it's really really limited.
don't waste your money bro on an electribe. get the ASR-X.
> reasonable price.
> Andrew
2011-01-14 by Szőnyi András
I've just called the guy, who's selling it, and he said he may want to
keep it, which I don't really mind now because ~yesterday clavia has
announced they release Nord Stage 2 with sampler functionalties.
I have a Stage Classic, so I will spend my saving to that upgrade...
(I know it's not the same as an Ensoniq sampler, if I could afford,
I would buy both of them.)
Meanwhile an other ASR-X PRO appeared on the same Hungarian
instrument-forum (http://www.absolute.hu/apro/apro.php?type=1&sel=1),
the price is 80.000 HUF. (http://www.xe.com/ucc/convert.cgi?Amount=80000&From=HUF&To=USD)
If anyone interested, I'll try to help in communication with the seller,
nerogalaxy@.... (I tried to call him too, but he didn't pick it up.)
Andrew
> manual.
>> reasonable price.
>> Andrew
2011-01-14 by Scott Solmonson
James, there's a fair other bit of musicians around that would say the same thing about your reliance upon swing, quantization etc- I myself don't want to program them, they get built naturally because I input them with drumsticks :)
IMO there are two kinds of samplers- phrase samplers and reproduction samplers.
When combined with a capable sequencer, a phrase sampler becomes an awesome drum machine.
And the Korg Electribe ES-1 and ESX are the most directly-useful phrase-samplers I've ever used.
-SS
NUNQUAM NON PARATUS
V: 408.718.6290
On Jan 14, 2011, at 12:28 AM, James Ulibarri wrote:
> Matt,
> also the electribe effects are absolute cheese.  that's not an effect engine... not sure what that is.  but ASR has the same chip in the DP4 for the most part.  that's a real effects mainframe.  one is a workstation and one is a toy.  you can make music with the korg but it's really really limited.
> > reasonable price.
> > Andrew
Re: another sampler/sequencer (almost OT)
2011-01-14 by duncan
>>honestly if i saw someone at a gig and i saw them with an electribe performing i would be like "wuss!".  total cheese, dude.<<
that's rather simplistically judgmental, james, if you don't mind me sticking my opinion into "your thread" :-)
doesn't it depend on how they're using it?
I've used the ES-1 for years now as a live sample playback machine for daft noises (i.e. I hit the pads on the thing & strange noises come out through the minimal lo-fi effects engine). it's smaller than anything else with the same capability, & doesn't need a hard-drive to load from.
+ as I mentioned before, I can load samples into it real quick using the memory card.
I also use it as a tap-tempo clock source to run other sequencers from, because that works best with a real drummer. & sometimes the pedestrian-sounding metronomic sequencer engine makes a rhythm that works /because/ it doesn't swing. if you play other (live) instruments against a rigid, non-swinging beat like that, you can still swing against it.
you probably don't like anything made with the early roland rhythm boxes either then? or the moog 960? just asking.
duncan.
Re: [xl7] Re: another sampler/sequencer (almost OT)
i've had all the xox's. but i would not put any electribe in the same league as any roland classic drum machines.
anyways, guys. i'm not being passive aggressive here... but if you like the electribes than more power to you. don't let me wreck your fun. matt brought it up again and he was talking to me directly about the asr-x and the electribe esx-1. i told him my opinion.
me, personally, i feel too many people have them and usually artists who are just getting into electronic music (ie, kids). i'm not talking out of my ass as far as being a back seat driver and just shooting from the hip and not owning them in the past. i've had like 3 of them. the er-1 (the original, not the MK1) has the most amazing rubbery minimal kick. and i know for a fact that they are powerful in the right hands. but just the sight of them makes me cringe tho. is it true that Emu made 100,000 CS's?
duncan.
so you're are using it like a sound module? so if you input your notes with sticks how do you over ride the internal sequencer when all the unit can ultimately do is 4/4, 16 step sequences? so let me get this straight.... you but the electribe in Record Mode and then you beat some sticks, and somehow the korg ignores that it can only receive on 8 or 16 steps? oh and it's nothing but whole notes too right?
i'm not being a smart ass. i just don't get what you9;re doing..
-SS
NUNQUAM NON PARATUS
V: 408.718.6290
> Matt,
> dude.. you already know my thoughts on the korg electribes and ensoniq stuff. honestly if i saw someone at a gig and i saw them with an electribe performing i would be like "wuss!". total cheese, dude. first of all the sequencer blows on the es-1. no swing, and no quantization, no shuffle. not sure if you're using any of those facilities but that';s a big no no for me. how boring sounding. plus no real filters or LFO's. big deal if it says "filter". gee thanks. what kind of filter? lp/bp/hp at the very minimum let alone all the esoteric types in between must be implemented. no LFO's and no selectable waveshapes for those LFO's for the filter, pitch, etc. the ASR-X would allow you individual outs too if you bought the 8 output board. you can add a scsi board too for $100 from thesoniq.com
> > reasonable price.
> > Andrew
Although no one has written an interest in,
I got the answer: the (second) ASR-X Pro has been sold... :(
By the way, what the average price for an ASR-X pro on ebay?
The 80000 HUF (~390 USD) was a good price?
Andrew
On Fri, 14 Jan 2011, Szőnyi András wrote:
> I've just called the guy, who's selling it, and he said he may want to keep
> it, which I don't really mind now because ~yesterday clavia has announced
> Meanwhile an other ASR-X PRO appeared on the same Hungarian instrument-forum
> Andrew
>> manual.
>>> reasonable price.
>>> Andrew
that's about the going rate, but you can get them cheaper on craigslist or used music stores too here in the states.
2011/1/14 Szőnyi András <andras@...>
Andrew
> nerogalaxy@gmail.com. (I tried to call him too, but he didn't pick it up.)
> Andrew
>> manual.
>>> reasonable price.
>>> Andrew
Re: another sampler/sequnecer (almost OT)
2011-01-14 by Jarlath Hynes
The electribes DO have LFO's with selectable waveshapes, and swing. Yes, it is limited, but it's fast and fun, and can sound great with some work. A lot depends a lot on the style of music you are making and how much hands-on you want.
I have a Korg esx-1 and it compliments the CS nicely. It can be used as a sound module sequenced from the CS, with all the associated benefits, and they do respond to velocity from midi-in. Load-up your samples and you have an enormous amount of hands-on control straight away. Fast, and great fun. You can still use it's crappy sequencer to lay-down motion sequences. This guy seems to sequence all his flash gear from an esx - with pretty decent results - http://www.youtube.com/user/muzik4machines
You can even bus a CS stereo output into the electribe and go haywire on it.
Oh, and that little arpeggiator strip is really nice - it even sends midi out.
http://www.youtube.com/watch?feature=player_embedded&v=DzHBhPrxhJo
More than the sum of it's parts. I'm sure the ASRx is nice too (but where are all the knobs?) :)
--- In xl7@yahoogroups.com, James Ulibarri <jamesulibarri@...> wrote:
> Matt,
> limited.
> > manual.
> > a
> > > reasonable price.
> > of
> > > Andrew
Re: [xl7] Re: another sampler/sequnecer (almost OT)
2011-01-14 by Narcissus
Be careful with the ASR-X : the sound generation and the FX are cool, but the sequencer is NOT, and it has some serious timing / stuttering problems.
We used to have one of those, and the sequencer was an absolute pain in the ass, it kept glitching over and over.
If you plan to use it just as a module, then you`ll have no problem.
2011-01-14 by D F Tweedie
Recent ones have sold on eBay for $240 to $350 according to the "completed listings" information for 2011. There were two listed yesterday ... one for $270.00 and one for $449.00. The more expensive one had a SCSI drive packaged with it.
The price depends also on how much RAM is installed, whether the internal drive options are there, whether it has the 8 analog out card, whether some SCSI stuff is included, whether the sale includes sample disks and the condition.
DF
CONFIDENTIALITY NOTICE: This communication with its contents may contain confidential and/or legally privileged information. It is solely for the use of the intended recipient(s). Unauthorized interception, review, use or disclosure is prohibited and may violate applicable laws including the Electronic Communications Privacy Act. If you are not the intended recipient, please contact the sender and destroy all copies of the communication.
--- On Fri, 1/14/11, Szőnyi András <andras@...> wrote:
Subject: Re: [xl7] another sampler/sequnecer (almost OT)
Date: Friday, January 14, 2011, 2:16 AM
Andrew
> Andrew
>> manual.
>>> reasonable price.
>>> Andrew
Thanks for the answer!
"Completed listings", that's a very useful feature.
Now that I know this feature, I promise, it was my last
question about average prices on ebay. :)
Andrew
> DF
> From: Szőnyi András <andras@...>
> To: xl7@yahoogroups.com
> Andrew
>> Andrew
>>> manual.
>>>> reasonable price.
>>>> Andrew
Yeah they are a definite restore project. New pads, memory, scsi cards, and the 8 out cards are still available.
The LFO's fortunately clock to midi with note values. The effects are ok for a groovebox. You can still get pars from Syntaur and Thensoniq.
DF
Andrew
> Andrew
>> manual.
>>> reasonable price.
>>> Andrew
Glad I could help!
Have to laugh at myself ... I was close to buying the one for $270.00 yesterday ... and a MOTU Midi Timepiece AV Parallel that the seller had.
I bought the MOTU last night. Today I got a 'search' e-mail from eBay telling me there was a new ASR-X listed for sale for $320.00. I went to take a look.
The $270.00 listing had expired and the guy relisted for $320.00 for 30 days. I guess I helped him pay his rent so he could up the price a bit.
DF
Date: Friday, January 14, 2011, 2:10 PM
Andrew
> DF
> From: Szőnyi András <andras@c3.hu>
> Andrew
>> Andrew
>>> manual.
>>>> reasonable price.
>>>> Andrew
2011-01-14 by Matt
This is what I was talking about when I was asking about trying to do with the cs arpeggiator and pitch strip in another thread this week.
--- In xl7@yahoogroups.com, James Ulibarri wrote:
> Matt,
> limited.
> > manual.
> > On Jan 12, 2011 2:06 PM, "SzÅ`nyi András" wrote:
> > > Sorry for a new non-E-MU question but I';ve just found an old machine for
> > a
> > > reasonable price.
> > of
> > > Andrew
2011-01-14 by Matt
I think he's recording phrases into the phrase sampler then using those as audio loops.
i'm not being a smart ass. i just don't get what you're doing..
-SS
NUNQUAM NON PARATUS
V: 408.718.6290
> Matt,
>; > reasonable price.
> >; to be honest I felt the ESI has a much better sample playback.
> > Andrew
Matt,
bro, nuke that RS7000 and get an ASR-X. Pro or non pro. It doesn't matter. I have the black one here now and I may pick up a red one in LA this weekend, but it's the same main board.
Also, tonight I am picking up a Novation Bass Station rack and Drum Station. Totally wicked with the CS. Strong strong (non-thin) voices. Add an A-Station rack later and that would be a wicked minimal setup with the PX-7... something fierce. Totally portable too with a small SKB rack.
something to think about.
> Matt,
> limited.
> > manual.
> > a
> > > reasonable price.
> > of
> > > Andrew
2011-01-14 by Matt
Maybe this will affect everyone's opinion. Originally years ago I used to play with reason a bit. then I got out of making music and played guitar for a couple years even though I'm horrible. I used to play with an electribe ea-1 with a roland tr-505. I did not know how to write my own sequences or save with the electribe, but I would slow the stock sequences down and tweak them out while playing drums sequenced with live parts on top. This got boring. I bought a sp-808ex. This was fun to hook a cheesy 80s keyboard up to and make a couple tracks, but I felt that it was difficult to play live. Then I bought the CS. The cs is freaking awesome. I currently play mostly with the CS and possibly with a kaoss pad kp3 hooked up in sync. Occasionally I invite other musicians to come jam and I loop them with the kp3. I heard things about rs-7k and had some money to burn 6 months ago so i watched the mailing list and so i bought one with all the accessories for a good price. I have no idea how to work this monster and the 4 inch thick manual I recieved with it is completely overwhelming.
So far I really love the CS but it is huge to bring out to all shows. Sometimes I don't want to bring a ton of gear especially if i'm not getting paid and taking the bus or bike. I am hoping for something I can use live with or without the cs and not to subject cs to going all around gigging.
That said i dig the esx arpeggio feature but find it difficult to program. I love the cs and wish it was 10 lbs lighter.
On Fri, Jan 14, 2011 at 12:28 AM, James Ulibarri <jamesulibarri@...> wrote:
Matt,
>; reasonable price.
>; I'm especially curious about the sound of that, not the sequencer
> Andrew
2011-01-14 by Matt
yea i need to nuke the rs7
On Fri, Jan 14, 2011 at 3:37 PM, James Ulibarri <jamesulibarri@...> wrote:
Matt,
> Matt,
>; limited.
> > manual.
> > a
> > > reasonable price.
> > of
> > > I try to give an example what kind of sound I9;m looking for:
> > > Andrew
2011-01-14 by Matt
I also have reason 5 and macbook pro but i hate computer machines now lol because i fixed them for a living for years and years up until 2009.
Matt,
> reasonable price.
> Andrew
2011-01-14 by Matt
what is so bad about asr-x sequencer?
Matt,
> reasonable price.
> Andrew
i didn't know you're on your bike. the asr-x is too big then also.
if i were to go micro like what you need, i would get the electribes (paint them!), or the MFB boxes.
this one is so sick.
http://www.mfberlin.de/Produkte/Musikelektronik/MFB-522/MFB-522e/mfb-522e.html
Matt,
> reasonable price.
> Andrew
2011-01-14 by Matt
how big is asr-x? like same as cs?
Matt,
> reasonable price.
> Andrew
they say the black one is glitchy. but i'm not convinced yet. so far i am just triggering mine from the px-7.
i think people trip them up with effects and trying to do too much.
On Fri, Jan 14, 2011 at 3:51 PM, James Ulibarri <jamesulibarri@gmail.com> wrote:
So far I really love the CS but it is huge to bring out to all shows. Sometimes I don't want to bring a ton of gear especially if i9;m not getting paid and taking the bus or bike. I am hoping for something I can use live with or without the cs and not to subject cs to going all around gigging.
Matt,
> reasonable price.
>; Andrew
2011-01-14 by Matt
I have a car but i mean it's good to have something u can take around without the car and jam on at starbucks or buddy's house or whatever.
i didn't know you';re on your bike. the asr-x is too big then also.
Matt,
> reasonable price.
> Andrew
2011-01-14 by Matt
maybe i should get mpc-500 lol
Maybe this will affect everyone';s opinion. Originally years ago I used to play with reason a bit. then I got out of making music and played guitar for a couple years even though I'm horrible. I used to play with an electribe ea-1 with a roland tr-505. I did not know how to write my own sequences or save with the electribe, but I would slow the stock sequences down and tweak them out while playing drums sequenced with live parts on top. This got boring. I bought a sp-808ex. This was fun to hook a cheesy 80s keyboard up to and make a couple tracks, but I felt that it was difficult to play live. Then I bought the CS. The cs is freaking awesome. I currently play mostly with the CS and possibly with a kaoss pad kp3 hooked up in sync. Occasionally I invite other musicians to come jam and I loop them with the kp3. I heard things about rs-7k and had some money to burn 6 months ago so i watched the mailing list and so i bought one with all the accessories for a good price. I have no idea how to work this monster and the 4 inch thick manual I recieved with it is completely overwhelming.
On Fri, Jan 14, 2011 at 12:28 AM, James Ulibarri <jamesulibarri@gmail.com> wrote:
Matt,
also the electribe effects are absolute cheese. that's not an effect engine... not sure what that is. but ASR has the same chip in the DP4 for the most part. that's a real effects mainframe. one is a workstation and one is a toy. you can make music with the korg but it9;s really really limited.
> reasonable price.
> Andrew
same size but deeper from front to back
Matt,
> reasonable price.
> Andrew
or akai S-20, even smaller!
Matt,
> reasonable price.
> Andrew
2011-01-15 by Matt
oh man why do i feel like i just got trapped in a game of pokemon.
Matt,
> reasonable price.
>; the E-MU Command Stations. :)
> Andrew
2011-01-15 by Szőnyi András
http://futuremusic.com/blog/2011/01/13/roger-linn-dave-smith-unveil-tempest-analog-drum-machine/
OMG!
Is this that beast which was almost ready in the last 3-4 years
(as boomchik) ? :)
... and it seems to fit into a backpack for carrying it by bike.
BTW, I'm a biker, and I often carried my Stage Compact (73keys) on my
back, so a "heavy" ~rack-sized machine wouldn't be a problem. :)
Andrew
On Fri, 14 Jan 2011, James Ulibarri wrote:
> Sick ass.
2011-01-15 by James Ulibarri
No it's not the boomchik/Linn Drum II.  In the article it said that's
still in the works.  Yeah right!
> OMG!
> (as boomchik) ? :)
> Andrew
> > Sick ass.
Sorry, I wrote the answer before reading the article,
and I didn't know that they have parallel drum machine projects.
Andrew
> No it's not the boomchik/Linn Drum II.  In the article it said that's still
> Sent from my iPhone
>> OMG!
>> (as boomchik) ? :)
>> Andrew
>>> Sick ass.
Neat to look at and they sure are pretty. But if if I were to drop kind of cash I would get a Sequential Studio 440 and have wine country do the resonant filter mod.
I got the Novation Bass Station rack tonight. I don't like it. Too acidic and too many lead sounds. ; All I wanted was some good sub bass tones. (Matt, it does have sick wobble) But I am not doing Dub Step. Off to Ebay this one goes..
Andrew
> Sent from my iPhone
>> OMG!
>;> (as boomchik) ? :)
>> Andrew
>>> Sick ass.
2011-01-21 by James Ulibarri
anyways.
Atom - "i don't spend time in step mode, but in "Grid Record" you can edit the
gate time for each note. pg 70-71 (pdf 82-83)."
actually messing with that parameter just changes the duration of the note/step. i was talking offsetting or initiating delay or pre-delay or pushing and pulling that particular track. no you cannot drill down on a note and move that actual step. it';s not possible on the CS.
but if you want to shift a whole entire track you can, but not one step in particular.
my PX-7 is having some surgery done and it won't be back in my paws till next weekend. so I'm remembering playing with Shift and then having all the parameters parameters to move the track back or forward. i guess it's cool that it's so finite, but i wish there was a way to be able to move it 1/32nds or 1/16th's in delay verses having the whole bar:beat:tick parameters in front of me.
this is how you create shuffle if you program on even notes, such as 2,4.6, etc by track shifting (or delaying the track). so my question is.... what actually are the values when playing with the data encoder? i hate it when i cannot figure stuff by myself quickly. so pushing an entire measure would be equivalent to what? does anyone have a break down of what the CS is doing? sorry, i wouldn't have to ask if my unit was next to me.
This filter allows you to either scale (multiply by a value) or shift (add a
value to) the start times of notes. This effectively shortens or lengthens the
selected section without changing the tempo. The scale function is
performed before the shift value is added.
Scale - Multiplies all note start times by a percentage from 0% to 800%.
Scaling by 100% would leave all note start times untouched.
Scaling by 50% would shorten the section by one half.
Shift - Adds or subtracts a specific offset in quarter notes and ticks to
note-on events in the selected tracks.
Events shifted past the end of the sequence will be deleted on
save only. That is, if you change your mind, you can slide
events back into the playing loop. Events shifted earlier than
tick 0 for notes and tick 1 for events will clip at that tick, possi-
bly bunching up events.
Tips & Tricks
• In addition to the percentages, certain exact ratios are provided and are
displayed as fractions. (2/3, 4/3, 5/3, 8/3, 10/3, 20/3) These ratios are
To Scale or Shift Note Start Times:
1. Select the pattern you wish to edit.
2. Press the Pattern Edit button.
3. Scroll to the Scale/Shift Start Times screen shown below using the data
entry control.
4. Select the amount of note start time scaling or shift (offset). The
Home/Enter LED will be flashing once the cursor is moved to the lower
line of the display.
Scaled by 50%
Before…
Scale Start Time
D-F shifted by +1 quarter note
Before…
Shift Start Time
SCALE/SHIFT START TIMES
Scale: 100% Shift: +00.000
Quarter NotesTicks
Ok, I got all that. but shifting 00.000 say to 01.000 would be equivalent to what? pulling at 1/16th's?
this is more of a music theory question verses a question on the CS.
anyone know what i am talking about?
On Fri, Jan 21, 2011 at 3:44 PM, James Ulibarri <jamesulibarri@...> wrote:
anyways.
actually messing with that parameter just changes the duration of the note/step. i was talking offsetting or initiating delay or pre-delay or pushing and pulling that particular track. no you cannot drill down on a note and move that actual step. it's not possible on the CS.
2011-01-22 by Szőnyi András
Excuse me for this rude question, but are you editing your
patterns on stage, in a live-perfomance-situation or
you just want to realize everything by the CS?
I mean, isn't it easier to edit these bits/notes in a DAW
and download/upload back the pattern to the CS?
If the CS is the only "sequencer" part of your setup (without any
computer), I understand the thread...
...And one more thing I really sorry about: to jump in step or grid
recording mode, the sequence must be stopped. :(
Andrew
On Fri, 21 Jan 2011, James Ulibarri wrote:
> anyways.
> the
> particular.
2011-01-22 by James Ulibarri
It's not a rude question :)
Anyways, oh god no.  Not live, just my studio.
I don't use software sequencers.  I don't even know how use one single
app besides Ableton and Kontakt.  I'm a hardware guy.  And when I say
Ableton, all I am saying is Simpler.
Besides all I am trying to do is nudge the track forwards and
backwords (in the studio) by a fixed amount with intent.
But in the Schaltwerk you can delay a track by 1/16ths and 1/32nds.
But that machine is gone.  Although I may have a lead on another.
And that's what I am after here.  How to nudge/push a CS track in the
same way.   I will just mess with it next weekend but the CS's Shift
section is all I am trying to sort through in my head.
What value with the data wheel will achieve a 1/16, 1/32,  1/64 nudge
backwards (delay) in Emu's way of working?
In this case it is an exact science, but i'm banging my head against
the wall.  It does work but what values equal what?
> Andrew
> > anyways.
> can edit
> > the
> the
> delay or
> down on a
> step in
> > particular.
> paws till
> having all the
> it's cool
> it
> as 2,4.6,
> is.... what
> it when
> measure would
> CS is
What about to cut and paste that track?
You can define where (which track, which bar - you may have to alter the
length of a bar) to paste.
http://www.emu.com/support/files/storage/XL7Op-F.pdf
82. cut / 84. paste page (by the PDF).
Andrew
> Besides all I am trying to do is nudge the track forwards and backwords (in
> And that's what I am after here.  How to nudge/push a CS track in the same
> way.   I will just mess with it next weekend but the CS's Shift section is
> In this case it is an exact science, but i'm banging my head against the
> Sent from my iPhone
>> Andrew
>>> anyways.
>>> the
>>> particular.
>>> the
>>> 2,4.6,
>>> would
dude, why would a cut and paste utility help me nudge a track to play early or late?
anways, i called Forat in LA and he said he knows what i am talking about. on an MPC you can swing notes both early and late. and i think there is different levels of this. i don't remember on my mpc-3000.
ok, narrowing down further on my original question. in the Shift section of the CS, when a person is looking at the Bar:Beat:Tick section....Forat said what i am try to do has to do with the sequencer's timing resolution (ppq). and it takes a little math to figure out how to delay a track to the values i am trying to do.
ok, i just found it online. i knew i wasn't smokin crack!! i'm a little surprised that this has never been discussed before. what the heck are you guys doing out there with your command stations? :)
here is what i am saying to a tee...
http://www.logicprohelp.com/viewtopic.php?p=274872&sid=8805545cd5cea257a2764d43d8539a0c
bingo. figure this out and you have shuffle for days.
2011/1/21 Szőnyi András <andras@...>
Andrew
> Sent from my iPhone
>> Andrew
>>> anyways.
>>> the
>>> particular.
>>> the
>>;> that it's so finite, but i wish there was a way to be able to move it
>>> 2,4.6,
>>> would
Ok, let's figure this out..
the PPQN is 384 on the CS.  (which is 4 times the resolution of the
schaltwerk or a TR-909 by the way) at 96.
On page 77 of the PX-7 the Scale/Shift utility shows...
Anyways, I'm just talkin to my self at this point.
2011-01-22 by Atom Smasher
> possible on the CS. but if you want to shift a whole entire track you
the note event editor can do that.
         ...atom
 	"Your password must be at least 18770 characters and
 	 cannot repeat any of your previous 30689 passwords.
 	 Please type a different password. Type a password
 	 that meets these requirements in both text boxes."
 		-- Microsoft takes security seriously in
 		Knowledge Base Article Q276304.
> or late?
Sorry, it was a dumb idea,
but I thought, if you have 16th long bars (I don't know if it
possible, my machine is not with me till Monday) you can
cut and paste the whole track with a 16th (one bar) later or earlier.
Andrew
> on an MPC you can swing notes both *early* and *late*.  and i think there is
>> Andrew
>> (in
>>> Sent from my iPhone
>>> On Jan 21, 2011, at 4:27 PM, Szőnyi András <andras@...<andras%40c3.hu>>
>>>> Andrew
>>>>> anyways.
>> edit
>>>>> the
>> a
>> in
>>>>> particular.
>> till
>>>>> the
>> cool
>>>>> 2,4.6,
>> what
>> when
>>>>> would
Re: schaltwerk (was: Swing question)
2011-01-22 by duncan
> But that machine is gone.  Although I may have a lead on another.<<
james, unless the schaltwerk you have a lead on is under $300, don't bother. save up & buy a real sequencer. just saying.
I have three maqs here, & I have used regelwerk, so I've got nothing against doepfer per se....
but my schaltwerk failed quite spectacularly to deliver, especially there were no s/w upgrades that could've done something with that interface.
but even simple stuff like chaining two patterns together left a tiny gap, which threw it out of lock with other sequencers, besides being out of rhythm.
I sold mine for $300 & lost a lot of money on the deal, but I was glad it was gone.
for that type of stuff (i.e. big grid of buttons in front of me), I use the octopus. mucho mejor. I also have two P3s, three notrons & a cirklon. & an XL7, obviously.
so you could say I'm pretty much a h/w sequencer type too.
hey- you want to buy a zeit? got one of those here.... :-)
duncan.
Re: Swing question
2011-01-22 by steve_the_composer
I haven't read all of the nitty gritty details in this thread, but I  something is unclear. Correct me if I am wrong, originally the goal was to shift only certain notes (e.g., even numbered notes) by a set amount. Then, the goal was to just shift an entire track forward or backward. Is this correct?
If its the latter, I would think that SCALE/SFIT START TIMES would be the correct tool. If that it, it looks like the E-Mu sequencer uses 384 divisions ber measure or 96 ppq, 48 pp8th, 24 pp16th, 12 pp32nd, 6 pp64th, etc.
If you want to just shift some notes (e.g., every other note, I do believe you'd have to do that by hand. It may be time consuming to scroll through all the notes in a pattern and tweak them individually, but it can be done with near microscopic precision.
Again, I am not sure I understand the current goal, but I hope this helps.
Steve
> or late?
> 2011/1/21 Szõnyi András <andras@...>
> > Andrew
> > (in
> > > Sent from my iPhone
> > > On Jan 21, 2011, at 4:27 PM, Szõnyi András <andras@...<andras%40c3.hu>>
> > >> Andrew
> > >>> anyways.
> > edit
> > >>> the
> > a
> > in
> > >>> particular.
> > till
> > >>> the
> > cool
> > >>> 2,4.6,
> > what
> > when
> > >>> would
Re: Swing question
Ooops. I thought it was 384 ticks per measure, not per 1/4 note. So, just multiply the numbers in my previous post by 4. (I have been  developing a live performance modality and have not been painstakingly micro-managing sequencer ticks.)
Steve
Re: [xl7] Re: schaltwerk (was: Swing question)
duncan,
good points here. i will be brief so i don't bore the rest of the group. (even more than normal).
the schaltwerk i have a lead on will be $1200 to $1500. not cheap by any means.
"chaining two patterns together left a tiny gap, which threw it out of lock with other sequencers, besides being out of rhythm."
dude, you just saved me a buck or two by dialing down the middle. i know that bug very very well!! wow, i'm glad you brought that up. you're 100% right. it did do that. it has that hiccup there, and i thought i was the only one who noticed it. that's not gonna work for me. you just saved me a lot of casheesh.
yeah i had the black sea octopus. most expensive machine ever. at 4 grand i was pretty disappointed. no LCD to know where you were at. and the thing was huge. too big.
i mean it was ok, and it had all the schaltwerk bugs worked out, but i don't miss it. just something about it. i know it's powerful and it's all spec'd out to the gills. but the work flow was uninspiring. i'm glad it's gone to be honest
OK, now that i am talking to someone who knows than what i am talking about. all that my thread was about is how to achievethe Track Delay functionality on the Schaltwerk.... but for the Command Station? remember that trick? you had all those values... 1/32...7/32. the bottom line is that Command Station will do, it too but it's in the Bar:Beat:Tick format. there has got to be a semi elegant way of doing the same thing on the CS. what field should I be messing with to get 1/32nd's of delay on the CS, etc. is it the tick section?(the last set of numbers) And if so... what values in the CS format would be equal the kind of values in the Schaltwerk? I know there is a lot more control there on the CS, but the Schaltz had the delay values pre-sorted. you just scrolled and picked 1/32 to 7/32 to choose from. Now those values you had there to scroll through... What would be the equivalent on the Schaltwerk for Track Delay in the Scale/Shift section on the Command Station?
So my question is more of like a translation question... adjusting ticks on the CS would be equal to 1/32 of track delay on the Schaltwerk, etc. The Schaltwerk had fixed amounts, and the CS doesn't. But they do the same thing. I was just looking for a translated chart or something, etc.
Ok, now that's as clear as I can make it. :)
Hopefully, Duncan, you can help answer this one. actually it's more of a math question at this point or even dipping into basic time signature theory. although, it's not jumping out at me.
thanks
duncan.
Re: [xl7] Re: Swing question
Steve,
thanks for the feedback. yes, we're on the same page now. originally, yeah i had asked about certain notes, but the conversation morphed into track delay actually. sorry, that was my fault. and i was learning along the way as i started my rapid fire of questions.
ok the ppqn stuff really does my head in to be honest. maybe you could break it down if you read my response that Duncan started called Schaltwerk. you don't have to know the total ins and outs of that machine, but just the theory behind it. it had Track Delay, just as the CS has Scale/Shift start time adjustment. now the Schaltwerk had delay values ranging from 1/32 up to 7/32... and you had a large data wheel to scroll through to select those values. ok... pretty straight forward. Now... say one of CS users what's to do the same thing right? but the CS is set up in the Bar:Beat:Tick format right? So how would we translate that kind of fixed delay in our Command Stations? that';s all my question is.
On page, 78 of the .pdf for the PX-7 for the Scale/Shift start time facility it mentions the Scale parameters... and it has adjustable ratios. now to make things even more convusing it has weird parameters such as 2/3, 4/3, 5/3, 8/3,10/3, 20/3. i don't even remember seeing those. that must be available by scrolling past 100% or before 0.
my PX-7 is having surgery so i don't have it in front of me.
let me know if you have any feedback, or a translation of those values since you have the ppq thing down
thank you
Steve
> or late?
> >; You can define where (which track, which bar - you may have to alter the
> > Andrew
> > (in
> > > Sent from my iPhone
> > > On Jan 21, 2011, at 4:27 PM, Szõnyi András 40c3.hu>>
>; > >> Andrew
> > >>> anyways.
> > edit
> > >>> the
> > a
> > in
> > >>> particular.
> > till
> > >>> the
> > cool
> > >>> 2,4.6,
> > what
> > when
> > >>> would
2011-01-22 by Bruno
2011/1/22 James Ulibarri <jamesulibarri@...>
CSes have resolution of 384 ticks per quarter; since 1/32 is the 1/8
of quarter, it's equal to 48 ticks. If you want more, you have to
multiply, so 2/32 = 96, 3/32 = 144, 4/32 = 192 and so on.
HTH
Bruno
bruno,
ok, great. it's starting to make sense.
what about triplets? 1/32T is equal to 72 ticks? half of 48 is 24, and you add 24 to 48
now, the only thing i wish the CS did like the Schaltwerk/Octopus/Zed is to have different step lengths for patterns within a track.
pattern #1 - 16 steps
pattern #2 - 8 steps
pattern #3 - 12 steps
all at different tempos too like the above. now that would be sick. but there are work-arounds, and if you have another sequencers doing different things, than it's one in the same.
i run the px-7, asr-x, sp1200, and now trying the emulator II and emax 1 sequencer but it's just getting overkill at that point. it's just fartin around in the studio for experimentation's sake. but my permanent setup in the studio will be the 3 desktop boxes. it sounds sick enough already
HTH
Bruno
2011-01-22 by Bruno
> bruno,
Glad you found it useful.
Not exactly. A full triplet of 1/32T is equivalent to two 1/32 = 1/16.
Then 1/16 = 96, so 1/32T = 96/3 = 32. Go forth and multiply (by 2) to
get 1/16T and so on.
As a side note: I just love the way Rei Harakami mixes doublet-based
beats with triplet-based ones...
Cheers,
Bruno
2011-01-22 by dutchbeats
to shift certain notes you can duplicate the track. on the copied track real time erase the notes you don't want to shift by holding the notes down etc and on the original track erase the notes that were kept on the copied track
while the sequencer is playing you can scale/shift the track with the aforementioned equations and experiment with different settings before pasting back to the original.
maybe make a chart with all ppq/note values and print it on the panel for reference :)
> > bruno,
> Cheers,
> Bruno
Ahh cut and paste... That was Andrew's idea.  Sorry there bud :)
Anyways, so your idea behind cutting and pasting would be because of
what?   Is the Scale/Shift destructive?  So once I add track delay,
then I am commited to it like quantization?  So have a few variations
with different delay settings.  Although won't those trax have
different midi channels associated to them?  So I will have to
constantly have to change my target midi channel to what I originally
was trying to trigger.  Right? Am I understanding you correctly?
Ah yes I'm making a chart.
> > > bruno,
> 1/16.
> to
> > Cheers,
> > Bruno
2011-01-23 by James Ulibarri
yeah all this is kind of doing my head in until my unit is back in my hands next weekend. thanks for the info. seriously good stuff
On Sat, Jan 22, 2011 at 5:15 PM, dutchbeats <dutchbeats@yahoo.ca> wrote:
scale/shift is destructive like quantize but it's just moving things forward and backward. so if you move forward 24 ppq you can move back 24 to the original placement and try a different setting. also you can duplicate the duplicate track just in case. i may have spoken too soon about keeping the sequencer running, have to try it now..
i have two templates saved called start and start2. one has the bottom row assigned to external a, and one has the bottom row assigned to external b. so when i turn the machine on i just call up one of those and hold the erase button and slide my finger across the bottom row of tracks to wipe out the single place holder note that you have to have in each track(or event) for it to save the track routings. as long as my external samplers are on i am ready to make a beat. i can copy and paste between those tracks without needing to change routing and if i run out of tracks on the bottom, assigning the top ones is quite simple as you know. maybe i will make more templates in future as my
sampler collection increases. internal tracks are the same way, you have to call up the same preset on the track you paste to if it hasn't already been saved there.
keep rechannelize input turned on also of course!
edit: just read that with scale/shift to keep the scale (note duration) at 100% for the notes to be unaffected. shift +/-'s the note-on events.
> Sent from my iPhone
> > > > bruno,
> > 1/16.
> > to
> > > Cheers,
> > > Bruno
2011-01-23 by dutchbeats
why do i always delete my post to edit and in that time there is a reply?! psychic connection woah...
the deleted and only slightly edited for the third time post:
i have two templates saved called start and start2. one has the bottom row assigned to external a, and one has the bottom row assigned to external b. so when i turn the machine on i just call up one of those and hold the erase button and slide my finger across the bottom row of tracks to wipe out the single place holder note that you have to have in each track(or event) for it to save the track routings. i am ready to make a beat now. i can copy and paste between those tracks without needing to change routing and if i run out of tracks on the bottom, assigning the top ones is quite simple as you know. maybe i will make more templates in future as my sampler collection increases. internal tracks are the same way, you have to call up the same preset on the track you paste to if it hasn't already been saved there.
> > saved there.
> > --- In xl7@yahoogroups.com <xl7%40yahoogroups.com>, James Ulibarri
> > > Sent from my iPhone
> > > > --- In xl7@yahoogroups.com <xl7%40yahoogroups.com>, Bruno <brunorc@>
> > wrote:
> > > > > 2011/1/22 James Ulibarri <jamesulibarri@>
> > > > > > bruno,
> > > > 1/16.
> > > > to
> > > > > Cheers,
> > > > > Bruno
this week has been life changing for me thanks to this group. the door to modular sequencing has been opened and there is no turning back. setting sights on USB docking with the motherDAW in T minus 10, 9, 8, 7, 6, 5(night flight to venus intro would be good right now)4, 3, 2, 1...
> > saved there.
> > > Sent from my iPhone
> > > > > > bruno,
> > > > 1/16.
> > > > to
> > > > > Cheers,
> > > > > Bruno
Re: Swing question
2011-01-23 by steve_the_composer
I have a full day planned, but will try to look at the Schaltwerk thread and break down the ppq thing. It is a simple concept that once it clicks. I will explain more later, but here's the basic concept:
Measures are broken down into beats/note lengths/etc.
--e.g., there are four 1/4 notes per measure
Quarter notes are broken down into parts (also called ticks)
--e.g., there are 384 parts (or ticks) per 1/4 note.
384 is a nice number. (Basically it divides up nice for various note durations. I can explain more later.)
Also, this morning I was looking in the OS addenda (which I assume are embedded in the most recent editions of the manual). It struck me, in scaling or shifting start times, you can limit the range. Thus if you have a paticular drum on C2 that you want to make earlier in an entire track, you can do that. Then if you want to delay the start of an particular drum hit on E2, you can do that.  I am not sure if that might be useful, but I thought of this thread when I read that.
Hope this helps.
Steve
> Steve,
> Schaltwerk.
[snip]
CS via USB
2011-01-23 by Szőnyi András
Although I have successfully installed the USB driver
(on an XP) and the EMU device is recognized after connecting it,
the E-loader software can't communicate with the CS, only via the MIDI port.
Anyway The USB MIDI device is the same as the standard MIDI device
in the CS? I mean, If the computer could communicate via USB using
E-loader, the standard MIDI ports would be still opened?
Andrew
Re: [xl7] CS via USB
OK, I have found something related in an earlier post:
http://launch.groups.yahoo.com/group/xl7/message/19486
"As for the e-mu's usb port, you cannot use that as a substitute for
midi. You either need a midi interface or a device such as a usb
keyboard that has a selectable midi port.
--Steve"
Thanks for the answer Steve! :)
Andrew
> Andrew
Andrew,
I know it sucks doesn't it. I don't think they were far along with USB at that point when Emu released it. A hack would be pretty cool but I have no clue what is all involved to get USB connected to a DAW for knob control, etc.
I experience a lot of midi latency and reaction time with my knobs. Which has been discussed before. A full 1/2 second or so before I see any knob movement on the computer. I sure hope it's my computer, or drivers, and not the CS with a DAW in general. Well when doing regular CC tweaks to other hardware there is no midi latency that I can remember. So it's my slow computer. I will get a new laptop in a few months. Too much other stuff to get right now. It never ends.
2011/1/23 Szőnyi András <andras@...>
--Steve"
Andrew
> the E-loader software can9;t communicate with the CS, only via the MIDI port.
> Andrew
2011-01-24 by Szőnyi András
On Sun, 23 Jan 2011, James Ulibarri wrote:
> Andrew,
> etc.
As far I understand for that hack the USB part of the CS OS should be reprogrammed.
Yes, I think that latency is because the PC environment.
The MIDI standard is fast enough to transmit CC messages with (almost) 0 latency.
Andrew
>> --Steve"
>> Andrew
>> port.
>>> Andrew
2011-01-24 by James Ulibarri
Steve,
Great information. I'll have to compile all the information from you and Bruno's input on timing resolution. I won't be able to mess with it until this weekend.
But a chart would be nice for those interested in this kind of thing.
The CS is one of the most slept on sequencer's out there I feel. It gets more interesting all the time.
Hope this helps.
Steve
> Steve,
> Schaltwerk.
[snip]
Re: CS via USB
2011-01-25 by steve_the_composer
To me, the usb port's function is the high speed transfer of patterns between the E-Mu sequencer and the PC. I seem to recall when I did a time comparison, the usb transfer was around 6X faster than midi transfer. If you have lots of patterns and you like to back them up, the usb wlll save time.
Steve
> --Steve"
> Andrew
> > Andrew
2011-02-12 by Matt
I just purchased esi2000 and it came with external cd and jazz enclosure. only $100 yay! so i am playing with it and i am wondering if you have any info for me or tips i should figure out. I have kind of figured out how multi mode works and how to mount the drives and load sample banks from the cd. would love to be able to figure out how to process better and use filters and such. I ask you since you had emu esi32 which is predecessor, right?
-matt
reasonable price.
Andrew
