thanx -
seems key range for ALL layers does not affect arp range.
that is seperate in menu. and I finally found it.
--- In xl7@yahoogroups.com, Atom Smasher <atom@...> wrote:
> On Sun, 2 Jan 2011, emuxl7 wrote:
> > I am using controller C-1 to B-2 to trigger only sampler- and want to
> > play xl7(synth) on controller only from C-3 to C-6 I set KEY RANGE in
> > layers and all is fine until I turn arp on- and the keys from C-1 to B-2
> > play xl7...
> > is there seperate arp range that I miss?
> top of pg 255 of the manual (XL7-OpMan-G.pdf).
> "Notes inside the range will arpeggiate while notes outside the specified
> range will not arpeggiate. Use the Extensions parameters to exceed the
> upper boundary of the Key Range (see the information about Extensions
> beginning on page 251)."
> the pictures shows "MASTER ARPEGGIATOR" but "the preset and master
> arpeggiators have the same parameters".
> ...atom
> ________________________
> http://atom.smasher.org/
> 762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
> "The enemy is anybody who's going to get you killed,
> no matter which side he's on."
> -- Joseph Heller, Catch-22
