On Dec 28, 2010 1:20 AM, "James Ulibarri" <
jamesulibarri@...> wrote:
> Sounds crazy. But I know what you're saying. I'll try triggering my
> Emulator II+ tomorrow that way from the PX-7. Sending different velocities
> from different notes in a 3 note chord may sound pretty interesting
> actually. As you said, new timbers can be created this way.
> This box is totally bananas (this is good).
> On Tue, Dec 28, 2010 at 2:12 AM, nenad.lonic <
nenad.lonic@...> wrote:
>> Yes you can only grid record one note at a time BUT once you've got your
>> first note laid out, you can change the note value on the screen and dial in
>> whatever velocity you want manually, and just keep adding on the same track.
>> So yes you can grid record chords just one note at a time. This is awesome
>;> for experimenting and you can come up with some insane robotic grooves that
>> you simply can't play in real time.
>> Hope this makes sense.
>> --- In
xl7@yahoogroups.com 40yahoogroups.com>, James Ulibarri
>> wrote:
>> > Steve,
>> > Great information!
>> > Grid Mode won't allow a person to do a chord right? It's basically for
>> > drums.
>> > Am I correct or is it something I am doing wrong? It only picks up one
>> note
>> > for me at a time.
>> > On Sat, Dec 25, 2010 at 9:56 AM, steve_the_composer wrote:
>> > > James (and others),
>> > > This discussion has gotten my curiosity up. I have never systematically
>> > > explored step mode or done much (if anything) with it, though perhaps
>> years
>> > > ago, I may have played with it a litte bit.
>> > > For the fun of it I did some systematic playing around. You probably
>> know
>> > > this, but I thought as long as I took the time, I may as well share
>> what I
>> > > learned. Perhaps this will interest others and perhaps others will add
>> to
>> > > the understanding of how step mode works and can be used. Also, please
>> > > correct me if I have it wrong. (For this, I used a usb/midi keyboard
>> >; > connected to a P2500, using >>only<< midi in. I would be interested to
>> know
>> > > if using the Command Station keys and knobs perform differently.)
>> > > Auto = Y
>> > > 1. After entering step mode, you can press/hold down as many notes as
>> you
>> > > want.
>> > > 2. After >>>all<<< notes [keypresses] have been released:
>> > > ---(a) only the first instance of the first note played [keypress]
>> > > (including its velocity) will have been recorded into the sequencer;
>> > > ---(b) the duration of the first note played/recorded will be based on
>> the
>> > > Gate setting (a percentage of the resolution time);
>> > > ---(c) the sequencer time ["now" time] will advance based on the
>> resolution
>> > > you have chosen [Res];
>> > > ---(d) CC values can be set for the current time for as many different
>> CCs*
>> > > as you like; and
>> > > ---(e) only the last CC value (for each CC*) will be recorded at the
>> > > current time.
>> > > (*includes channel pressure and pitchbend)
>> > > Notes: I haven't fully explored Auto = N. However, in both conditions,
>> you
>> > > can simultaneously move a CC knob or slider and advance the sequencer
>> time
>> > > (manually with the encoder) and record a sequence of CCs.
>> > > atom smasher's suggestion are cool. If I were to use step mode, I think
>> I
>> > > might prefer to record CCs in real time after the stepped notes have
>> been
>> > > generated.
>> > > Anyhow, I hope this helps someone. I know I learned alot; so thanks for
>> > > starting this topic.
>> > > Steve
>> > > --- In
40yahoogroups.com>, Atom Smasher
>> > > wrote:
>> > > > On Fri, 24 Dec 2010, James Ulibarri wrote:
>> > > > > Ok, tried it. A CC can change value but only on a Note On message
>> from
>> > > > > the CS. Mixed results.
>> > > > pattern edit -> event list editor -> continuous controller edit
>> > >; > that might not be what you're looking for, but it might do what you
>> want.
>> > > >; you can also record CCs into an arbitrary track, thin the data if
>> needed,
>> > > > copy/merge to another track if needed...
>> > > > ...atom
>> > > > ________________________
http://atom.smasher.org/
>> > > > 762A 3B98 A3C3 96C9 C6B7 582A B88D 52E4 D9F5 7808
>> > > > "We cannot simply suspend or restrict civil liberties until
>> > > > the War of Terror is over, because the War on Terror is
>> > > > unlikely ever to be truly over... September 11, 2001,
>> > > > already a day of immeasurable tragedy, cannot be the day
>> > > > liberty perished in this country."
>> > > > -- Judge Gerald Tjoflat, 16 Oct 2004
