sequencer / software question
2010-12-16 by James Ulibarri
I know I can import midi files through E-loader and I know it works as I have successfully been able to get it to work in the past but only for one Pattern.
I just picked up another PX-7 and I hope I can achieve what I am trying to do here this time.
What I want to know is... was there ever a soft version of the sequencer available for the Command Stations? Can a user mirror their programming on screen with
files imported and dumped to the Command Station or vice versa? My main concern at this point is to honestly and full heartedly use the CC to build whole entire songs, not just a pattern.
With other Emu sequencers such as the SP1200 you get Segments or basically patterns. You make a Segment and then simply tie them together to build an entire song.
Obviously this has to be the same strategy with the CC's right? All hardware sequencers have to be based upon this principal or you wouldn't get anywhere. It just didn't reach
out and grab me on the Command Station. And spending the money (again), I am forcing myself to make sure this machine will do that. But the more I think about it I am thinking
that a linear software sequencer may be the solution. But I am not a software sequencer type of guy at all. Totally hardware. But when you pin my back against the wall and I hear
half of these trax that I listen to I swear that it can't be done on a hardware sequencer, or not very easily. I guess in the hands the CC's will do anything that a software sequencer
can do if you know what you're doing right. Does anyone out there work with a linear software sequencer and simply dump that midi data down to the Emu? I think that would be kinda cool.
Thoughts? Just something about building entire songs on this thing is stopping me. I think it's operator error. It's got to be.
