Modding: ext. audio being affected by xl sounds
2010-11-22 by Nico Liukko
first of all i would like to know if there are any hardware schematics for the xl 7.
second is that i wanna mod the xl 7 with external audio in so the external audio could be affected by the crazy stunts this machine can pull off.
as it is now, i can use the sub outs for external audio use but the external audio isnt affected by the effects or crazy stuff this machine can do by soft routing.
any thoughts?
Re: [xl7] Modding: ext. audio being affected by xl sounds
2010-11-24 by Aaron Eppolito
The returns on the sub-outs are summed with the mains in the analog domain.  All of the XL-7's processing is in the digital domain.  There is no A/D.
In short:  it can't be done.
-Aaron
> any thoughts?
Re: Modding: ext. audio being affected by xl sounds
2010-11-24 by scodoha04
That seemed intuitive but good to hear it from the source.
A better question is are there any equivalent external effects boxes which can mimic the z-filters?
For speculation, what sorts of things can't the z-filters do that can be performed with external effects?
> -Aaron
> > any thoughts?
Re: [xl7] Re: Modding: ext. audio being affected by xl sounds
2010-11-24 by Jack Pratt
I suppose that anything is possible...
Would anyone be interested in a 'SIMM' that had a usb interface and a 2.5mm
audio plug which allows you to have audio input directly from the outside and/or
from a computer as a USB audio device? It would give you four audio channels (2
stereo channels) which are just passed to the module for processing live.
This is not sampling just making a 'wave' available from outside the box.
The only problem [?] is that the waves would only be available while the module
is playing a note. That is, the SIMM is configured with four 'waves' which can
be put in presets, and the SIMM offers up 'live audio' instead of something from
ROM. You can create your own presets with those waveforms so that you can select
the filters/effects that you want to apply. [but sound only comes out when you
play a note]
How much would you pay for such a thing?
I was thinking of implementing such a thing in any case, but I can raise the
priority if there's sufficient interest.
Sent: Thu, November 25, 2010 12:12:29 AM
Subject: [xl7] Re: Modding: ext. audio being affected by xl sounds
> -Aaron
>the xl 7.
>routing.
> > any thoughts?
2010-11-25 by Atom Smasher
> box.
<<snip>>
> the priority if there's sufficient interest.
i'll be the first to say no, thanks.
i've got plenty of outboard effects. what i'm lacking is a hardware
sampler that's as good as a p2k/xl7. really, the p2k filters are nice
(despite some limitations), but the effects are easily outdone with
outboard modules... quadraverb, se-50, vf-1, etc... these things are now
*really* cheap.
if anything, i wish the p2k/xl7 had more/better effects. as it is, i'm
pushing it to the limits and still using outboard gear. audio inputs on a
p2k/xl7 to make use of the effects just seems like trying to stuff ten
pounds of $h|t in a five pound bag.
         ...atom
  http://atom.smasher.org/
 	"Who controls the past controls the future.
 	 Who controls the present controls the past."
 		-- George Orwell
 	1) Culture always builds on the past.
 	2) The past always tries to control the future.
 	3) Our future is becoming less free.
 	4) To build free societies you must limit the control of the past.
 	      	-- A Remixer's Manifesto
2010-11-25 by steve_the_composer
(1) What would the usb interface do?
(2) With the audio plug, would the external audio in appear as a ROM Instrument?
(3) With the audio plug, would there be 4 external audio ins (possibly appearing as 4 discrete ROM instruments)?
(4) Is there any risk that the levels of the uadio ins would damage the E-Mu?
Thanks.
Steve
> play a note]
> From: scodoha04 <scott.d.harvey@...>
> To: xl7@yahoogroups.com
> > -Aaron
> >the xl 7.
> >routing.
> > > any thoughts?
2010-11-25 by Jack Pratt
The USB interface is so you can plug it into a PC and it will look like a USB
audio device (a pair of speakers) so that any sound you can get your computer to
make can be 'played' into the E-mu module and through its effects.
The external audio (as well as audio from a computer through the USB interface)
would be 'waveforms' on a ROM. You could have any number of presets ('ROM
Instruments') that have a particular filter setting using these waves, but to
get the exact set of patch cords that you want to have [unless the ROM presets
do __exactly__ what you want] you would probably need to create user patches
using these waveforms. [for example, you could have a patch/preset that has all
four waveforms turned on ("being played") when a single note is played, or break
up the keyboard into different regions each with a separate group of waves being
played using overlays]
Essentially the idea is that when the E-mu module accesses a certain memory
range in the SIMM's waveform ROM region then it actually returns the latest
sample from an audio source. You could theoretically have many audio sources
being made available this way but there are practical limitations... THe preset
memory on this SIMM tells the module where the 'waveforms' are and the module is
none the wiser - the waves are dynamically generated rather than ROM encoded. It
also has some patches/presets to get you started but when it comes to effects
every one has different (IMO bad) taste so there will be user presets/patches
using those 'waveforms' that will have the effects being used in your favorite
way ;-)
Since all the processing on the module is done digitally, its very (VERY)
unlikely that the module would be damaged in any way. However if you put
something harsh (at high volume) into your speakers - then that's another
matter.
Turning this into a sampler is not a big deal (just need some memory). You could
even have audio downloaded into the memory through USB and stored in FLASH (kind
of like the other SIMM I'm making). However, making it a useful sampler is
difficult short of creating a new version of OS to handle the stop/start and
edit of it all.
My investigation (with a P2K) module showed that the OS does not access the
SIMMs after boot. This is probably just a software thing to give maximum
bandwidth to the voices (pushing the limits of ROM access as it is).
However changing that would be necessary to make a useful sampler of the E-mu
modules
Sent: Fri, November 26, 2010 2:53:18 AM
Thanks.
Steve
>and/or
>(2
>from
>select
> play a note]
>All
> > -Aaron
> >the xl 7.
>external
> >routing.
> > > any thoughts?
2010-11-26 by duncan
>>The external audio (as well as audio from a computer through the USB interface) would be 'waveforms' on a ROM......<<
this does all sound.... kind of cool.... if you wanted to process another midi module's audio through the emu's filters, you could just send them both the same midi note at the same time... I wonder if midi latency would come into play here.... but for processing a drum machine, say, through the p2k's filters & effects, this would be pretty useful.
I suppose.... thinking out loud for a second... if you had a p2k with both midi busses & the extra outputs (I think all p2ks & some of the other proteus modules were thus equippped), you could run a midi-through-loop from the A side to the B side of the p2k, & send the sub audio outs back into the live-audio input, & thus run some of your favourite proteus sounds through the filters twice.
not sure how this would work with an XL7 or similar... what happens if you feed midi out back into the input?
duncan.
2011-08-14 by Nico Liukko
Would it not just be possible to jack in the ext audio somewhere alonig the audio signal path inside the xl7? Send it in there just after the sound comes from the source? And in that way being able to mod an realtime audio in.
Fuck this shit give me the necessesary info like schematics and so on ill figure this one out my self
> way ;-)
> matter.
> edit of it all.
> modules
> From: steve_the_composer <smw-mail@...>
> Thanks.
> Steve
> >and/or
> >(2
> >from
> >select
> > play a note]
> > From: scodoha04 <scott.d.harvey@>
> >All
> > > -Aaron
> > >the xl 7.
> >external
> > >routing.
> > > > any thoughts?
2011-08-15 by steve_the_composer
I have never seen schematics or service notes on line. I suppose you could try e-mu. I believe you can send external audio from an EIV/EOS Ultra Emulator with the RFX-32 module and process it through the synth engine as if it were a sample. I am not sure if EmulatorX3 software has this capability.
On e-bay, there is a guy who sells circuit bent command stations. You might try to contact him either for a schematic (if one is available)or for ideas on where on the circuit you >>might<< be able to introduce external audio. I am guessing, but I assume you'd have to build your own A to D circuit if using analog in. If using digital data, I am guessing you'd have to get it into a form that the E-Mu circuit can use. I don't know; these are just guesses.
Steve
> > way ;-)
> > matter.
> > edit of it all.
> > modules
> > From: steve_the_composer <smw-mail@>
> > Thanks.
> > Steve
> > >and/or
> > >(2
> > >from
> > >select
> > > play a note]
> > >All
> > > > -Aaron
> > > >the xl 7.
> > >external
> > > >routing.
> > > > > any thoughts?
