CC messages with the push of a button?
2010-09-04 by bobsvitilla
Using the command station to control external gear:
Is there any way to send a midi CC value with a button or pad push?  Or can a note value be routed to send a midi CC?  If that is impossible, can the knobs be programmed to send CC values on a limited range, so that twisting a knob is like pushing a button?
Thanks in advance,
Bob
Re: CC messages with the push of a button?
2010-09-05 by steve_the_composer
Can you use a footswitch (routed to one of the footswitch CCs)?
Also, if your receiving device is just receiving on/off, it might be that CC=0->63 will be interpreted as off and CC=64->127 will be interpreted as on.
I don't think we can limit the range out outgoing CC data and the trigger buttons cannot be set to send CCs. I don't know about the pads.
--Steve
> Thanks in advance,
> Bob
