Anyone work with a Command station like this?
2010-08-02 by bobsvitilla
I was considering a new work flow method and was wondering if anyone tried something similar and found strengths or difficulties with it.
I am trying to improve my ability in producing a freeflow/improve workflow with my XL-7 than just bring tracks in and out of a pattern flowing between patterns.  I mainly consentrate on live performance.  I was think of organizing patterns where all the tracks are a paticular part.  Couple of just kick patterns, other paterns each with just: snares, tuned percution, untuned percussion, basslines, pads, sound effects, ect.  Then use the Xmit function to build sequences on the fly.
Thanks for any input.
Re: [xl7] Anyone work with a Command station like this?
2010-08-02 by massimo
that sounds like a good idea.
one thing i noticed with xmix that's a bit annoying is that there isn't a way to revert to the original part, but that shouldn't be a problem with this method. good stuff, let us know how you get on.
massimo
--- On Mon, 2/8/10, bobsvitilla <bobsvitilla@...> wrote:
> From: bobsvitilla <bobsvitilla@...>
> Subject: [xl7] Anyone work with a Command station like this?
> To: xl7@yahoogroups.com
> Date: Monday, 2 August, 2010, 21:26
>     xl7-fullfeatured@yahoogroups.com
2010-08-02 by Mauricio Balma
Of course.  Command station is a instrument to explore.  Patterns from 100-127
Bank 0 are made for this on mine.
I also sample a lot of sounds from the command station.  I have several synths
with line in, so sampling several synths into  a single sample is v something I
do a lot.
So I also have MIDI triggering specialized patterns, that bring sounds from the
engine, and also activate patches on other synth.
Also a test pattern, witch keeps c2 and several notes , during 4:000 length..
This is specially useful for sampling command station chords.
I don't need to press any note, just turn on and off triggers to create chords.
I also have a pattern for control changes. For example, a progressive increase
on sound made by a change of volume, can be overwrite on other track without
erasing its data.
Have so much working with them. If you look on the web, I have invested a lot of
time making "propaganda" for the command station.  Is maybe my favorite synth.
With a faster LFO, it will be by sure my favorite with no question at all
I n fact, CS is like chilli.  It goes good with everything.  There's no task
where the command station is useless.
This instrument is conceived in such a brilliant way.....
Sent: Mon, August 2, 2010 2:26:20 PM
fly.
