I've been dealing with this awhile, its not a major problem, more of an inconvenience.
I use my Mp-7 to control a novation super bass station rack. When I set midi sequence info to EXT for some reason it stops recognizing midi note off while i'm playing around.
It sounds fine after its recorded. but it throws me off when I'm trying to loop bass lines live in real-time
It works perfect when midi sequence info is set to INT, just doesn't send the recorded sequence to the bassStation. I have to go back and forth in the menu, which i won't be able to do live.
any suggestions?
