WHAT?!? Circuit bent MP-7
2010-05-12 by joeyjoejoemagee
http://www.youtube.com/watch?v=BKIDokPVqvc and its on ebay right now.... http://cgi.ebay.com/circuit-bent-e-mu-mp7-command-station-emu-mp-7-px-xl-/290434223336?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item439f3a8ce8 I thought it couldn't be done.... and whats all this about midi controlled bending?!?!!? I love the future....
2010-05-12 by Atom Smasher
i'm highly suspicious. knobs on a command station doesn't mean that the
command station is bent; only that knobs have been added. i think the
knobs are controlling a box that sits next to the command station... in
which case, why not put the knobs on the other box? it seems like they've
drilled holes in a command station to mount knobs for their home-made
effects box... this should only *decrease* the value of both units, since
they become partially useless without each other.
if that's not the case, i'd be interested in hearing a rebuttal.
also, they refer to their module as being an "mm1 midi module", but the
picture shows something that looks like a DB-25 connector, not MIDI...
this implies that the knobs are just connected to their kit with long
wires... further limiting usefulness and flexibility because it requires
both units to get functionality from their unit[1]. a better approach
would be putting all knobs on their unit, and then using it with *any*
synth.
maybe their knobs are also wired "in parallel" with the command station's
knobs... in which case it would again be better to keep all knobs on their
unit and send MIDI to the command station to represent knob movements.
i've got nothing against garage mods, but this one seems like it's not
being represented accurately. i'd stay away based on lack of details, and
what i can infer from their info isn't looking good.
no thanks...
1) loose or beak the command station, and either you loose the knobs to
control their box or you're stuck with a very big and heavy control
surface. loose or break their box and you're left with a command station
that has a lot of useless knobs.
...atom
________________________
http://atom.smasher.org/
"The VCR is to the American film producer and the American
public as the Boston Strangler is to the woman alone."
-- Jack Valenti, MPAA2010-05-12 by josh loughrey
---------[ Received Mail Content ]----------
Subject : Re: [xl7] WHAT?!? Circuit bent MP-7
Date : Wed, 12 May 2010 22:14:32 +1200 (NZST)
To : xl7@yahoogroups.com
synth.
no thanks...
...atom
On Wed, 12 May 2010, josh loughrey wrote:
> The knobs on his command station do not send to the control box; in fact
> it works the other way around. The control box is essentially an
> expansion for his circuit bent devices. In the first segment of the
> video, he's not using it (though it is plugged in); all the knob twists
> and manipulations are on the modded command station.
if the box is required for this to work, i still have to ask: why drill
holes in a command station? why not put the knobs on the box? the fact
remains that if it's a two-part kit; either part getting lost or broken
renders the others part of little or no value.
> Anyway, neat bit of kit. I'd like to know more about exactly what he's
> doing with these, and how he's doing them. Anyone here know much about
> circuit bending?
i'm also interested in knowing more, and i can't claim to have any
authoritative knowledge on this particular bit of kit... but i can infer
quite a bit from the info provided. although after checking out the demo,
the results don't seem any more impressive than running the outputs
through a kaoss-pad or similar (which i would do long before drilling
holes in a command station and connecting a box that claims to "circuit
bend" the CS).
also there's a certain romanticism about "circuit bending" and no info
about whether they're bending or doing something more intentional. having
a background in electronics i would say it's cool and fun to bend a
speak-n-spell or a casio that you found at a garage sale for $1... but
bending (as opposed to intentional modification of) a command station...
that's just dumb. intentional modification should never result in broken
gear; circuit bending is the dismissal or disregard of electronic
principles in favor of "random exploration" and often results in broken
gear.
when i modify gear i study the circuit that i want to modify, plan and
understand what i want to happen, then start experimenting. circuit
bending is more "lets connect these two pins and see what happens"; often,
what happens is the machine dies with a puff of smoke.
...atom
"The difference between common-sense and paranoia is
that common-sense is thinking everyone is out to get
you. That's normal -- they are. Paranoia is thinking
that they're conspiring."
-- J. Kegler
