HELP: FX RAM failed error
2010-03-16 by steve_the_composer
Does anyone have a solution for an FX RAM failed error?
I have a backup P2500 that hasn't been used in several years. It used to work flawlessley. However, when I went to test it, there was an awful noise coming through the headphones. Everything testable in diagnostics passes, except FX RAM.  I cannot imagine it would would have failed from lack of being used, but who knows. Any thoughts, suggestions? Is it possible to replace the FX RAM? If so, how? Thanks.
--Steve
Re: HELP: FX RAM failed error
Footnotes:
(1) Since only the main outs are connected to the FX system, I suppose I could always use it was a non-FX E-Mu/sequencer/controller using the sub outs. Still, it would be nice to have the FX working.
(2) Putting FX into bypass mode does not get rid of the noise.
> --Steve
RE: [xl7] Re: HELP: FX RAM failed error
2010-03-16 by Andrew
Somebody told me once (so I don't know if it's true or not since it was a software sales person) that on older rom based equipment, that there is a small battery on each card and when it dies, the card is done. Maybe someone on this list who is more in the know than me can shed some more light... but it's the only thing that comes to my mind.
> To: xl7@yahoogroups.com
> From: smw-mail@...
> Date: Tue, 16 Mar 2010 09:31:21 +0000
> Subject: [xl7] Re: HELP: FX RAM failed error
> Footnotes:
> > --Steve
>; <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/xl7/
> <*> Your email settings:
> Individual Email | Traditional
> <*> To change settings online go to:
> http://groups.yahoo.com/group/xl7/join
> (Yahoo! ID required)
> <*> To change settings via email:
> xl7-digest@yahoogroups.com
> xl7-fullfeatured@yahoogroups.com
> <*> To unsubscribe from this group, send an email to:
> <*> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn More.
Re: [xl7] Re: HELP: FX RAM failed error
2010-03-16 by Jack Pratt
Hey steve.
If the P2500 mother board is identical to an XL7 motherboard (I suspect so, but...) FX RAM is the SOJ28 (the one with missing central pins) package to the front left of the motherboard - U35; right next to the ROM slots. This is not memory used by the microcontroller (which is towards the right and back on the motherboard in a TSOP 54 package).
The FX RAM (81C4256 = 256kBit) is used to produce a pipeline by the large IC next to it "IC405" (U34) for sound effects (not the FX bus) so that you'll probably find that any sound that has any effect (eg chorus) will be bad.
It is unusual that a DRAM would fail, but if you have access to a hot air solder rework station you could try reworking the solder joints (which may have become dry). You also need to consider the bypass capacitors next to it and solder joints on U34 (with which it communicates). If the DRAM has not failed (and its not just a dry joint or two) then U34 could be failing which means that you're unlikely to ever get good sound out of the thing wihtout stipping all effects [making the sound output very bland].
If you are not competent to do the rework yourself, then you probably need to find someone who is to avoid damage to your unit [not something you should attack if the soldering iron is not your friend].
Unfortuantely 81C256's are not common at all these days, and the package makes removal a challenge without a solder rework station [and then its trivial]. So if you wanted to try replacing it...
Sent: Tue, March 16, 2010 7:31:21 PM
Footnotes:
(1) Since only the main outs are connected to the FX system, I suppose I could always use it was a non-FX E-Mu/sequencer/ controller using the sub outs. Still, it would be nice to have the FX working.
> --Steve
2010-03-16 by massimo
Just an aside but isn't the chorus done with doubling and detuning?
--- On Tue, 16/3/10, Jack Pratt wrote:
Subject: Re: [xl7] Re: HELP: FX RAM failed error
Date: Tuesday, 16 March, 2010, 20:15
Hey steve.
Footnotes:
> --Steve
It depends on the implementation as to how the 'frequency blurring' of the chorus is done (and there are a wide variety of choruses - a simple delay line can give a chorus of sorts). That may or may not involve the pipeline, but something like a reverb certainly does (this is just 'frequency blurring' with a low pass filter). Since I don't have any information on the 'IC405' part from EMU I'm just indicating the type of effect that may be subject to pipeline...
Sent: Wed, March 17, 2010 6:22:19 AM
2010-03-17 by Aaron Eppolito
There's two different choruses - one that's done at the voice level (by detuning an additional voice - which is why it eats polyphony) and one that's done at the effect level (by using the tank RAM as Jack mentions).
The FX RAM will mess with pretty much any signal coming through the box.  The G05 chip uses this memory for just about everything.  It may even use it for routing signals.  Did you try the subs?  I would imagine that even though they're dry, they might still be affected by the bad RAM.  Also note that it might be the interface to RAM that's suspect, not just the chip itself.  You could go physically pushing chips on the board to see if you hear anything change.  It's actually kinda fun to debug audio circuits...
-Aaron
----- Original Message ----
Sent: Tue, March 16, 2010 3:36:28 PM
Yahoo! Groups Links
2010-03-17 by steve_the_composer
Thanks for the details, Jack. Such repairs are definitely beyond my skill set. I might be able to find someone else who can do it. I will look at the motherboard for the chips to see what I can find.
--Steve
--- In xl7@yahoogroups.com, Jack Pratt <woodsworth1@...> wrote:
> Hey steve.
> From: steve_the_composer <smw-mail@...>
> Footnotes:
> > --Steve
Fw: [xl7] Re: HELP: FX RAM failed error
not quite sure where this message went - it's not in pending...
----- Forwarded Message ----
Sent: Tue, March 16, 2010 7:37:38 PM
-Aaron
Yahoo! Groups Links
2010-03-17 by Jack Pratt
Just incidentally, the same basic circuit is used for the sound generation in all P2K series units and command stations [The command stations have a different micro & the FLASH/SDRAM chips (it has an SDRAM chip instead of a DRAM SIMM) are different] So if you have a P2K module that's dead it could be the source of spare parts. I noticed that on a P2K the FX RAM is right next to the micro [U29] with 'IC405' beside it.
The FX RAM will only have an interface to the FX chip  ['IC405'] next to it, so only the DRAM, that chip and the nearby passives are going to be contributing to a FX RAM error.
I'd look at it for you, but I doubt that its worth the trip to Australia...
Sent: Wed, March 17, 2010 8:15:11 PM
--Steve
--- In xl7@yahoogroups. com, Jack Pratt <woodsworth1@ ...> wrote:
> Hey steve.
> It is unusual that a DRAM would fail, but if you have access to a hot air solder rework station you could try reworking the solder joints (which may have become dry). You also need to consider the bypass capacitors next to it and solder joints on U34 (with which it communicates) . If the DRAM has not failed (and its not just a dry joint or two) then U34 could be failing which means that you're unlikely to ever get good sound out of the thing wihtout stipping all effects [making the sound output very bland].
> ____________ _________ _________ __
> From: steve_the_composer <smw-mail@.. .>
> To: xl7@yahoogroups. com
> Footnotes:
> > --Steve
2010-03-19 by Aaron Eppolito
FYI: the E-Mu signal path is as follows:
G chip --> H chip --> G05 chip --> outputs
The G chip, of which there is 1 per 64 channels, is the sound generation chip. It reads directly from sample ROM/RAM, and does 7-point Gossett-Smith pitch shifting with fully ramped pitch per output sample.
The H chip, of which there is 1 per 32 channels, is the filtering chip. It can process a 6-pole filter per channel, or can steal a voice and cascade two sets for 12-pole filters. It has a morphing buffer which can interpolate between two complete sets of coefficients automatically per output sample. I believe gain is also done here.
The G05 chip, while also containing 64 channels of pitch shifting and 64 channels of 2-pole filters, is used only for the DSP section that creates the two master effects. It also handles routing of signals.
Post H chip, the arrows go through an FPGA for signal routing and interleaving. Furthermore, all the ASICs are controlled by a ColdFire CPU which handles envelopes, LFOs, control signals, note queueing, UI, etc.
-Aaron
PS. the Emulator series adds an option to use the R chip, a DSP behemoth that did 16 simultaneous stereo high-quality FX.
Sent: Wed, March 17, 2010 1:51:19 PM
--Steve
--- In xl7@yahoogroups. com, Jack Pratt wrote:
> Hey steve.
> If the P2500 mother board is identical to an XL7 motherboard (I suspect so, but...)Â FX RAM is the SOJ28 (the one with missing central pins)Â package to the front left of the motherboard - U35; right next to the ROM slots. This is not memory used by the microcontroller (which is towards the right and back on the motherboard in a TSOP 54 package).
> Â
> Â
> Footnotes:
> > --Steve
The good & the bad....
2010-10-25 by Jack Pratt
Well I have some good & some bad news...
Good news first.
I did the schematic and the PCB layout for the base (programmer) board [attached]. This board allows the user to read and write ROM & FLASH SIMMS including the ones that I'm making; and program the FLASH SIMMs and the new ones that I'm making. It also allows the programming of the CPLD and micro on the SIMM [through the second SIMM socket with the SIMM inserted upside down]. This was an easier work than the SIMM so I was able to complete it with 8 mil track and space. That means it will be relatively inexpensive to make (compared to the SIMM) but will be more expensive than the SIMM because of the size [5.4" x 3.8" cf 4.25" x 1.1"]. I will also save some $$ by not having the bottom screen printed. Components on the bottom layer are some 100uF caps and some 10K resistor packs (and a single zero ohm link) - but there's nothing on the bottom layer that needs to be identified by the screen print.
I need to make at least one to read my ROM SIMMs to determine the format, and to develop the software for the CPLD and micro. No one else really needs one but if anyone's interested in getting one. The cost would be around USD200. Please note that although these boards can be used to (re)program the CPLD and micro, once the SIMM has the mini-USB connector attached it won't fit into the SIMM socket. So if you want one of these please give me some indication. Otherwise I'll just make a couple for my own use.
Just on that, I have 22 of the 23 ROM SIMMs that EMU produced. I don't have a copy of the Composer ROM from a proteus 2500. If anyone has such a beast and is willing to part with it, then I would be happy to pay a reasonable price for it or come to some other arrangement. It would have a sticker on it with the number AP-20 where is one of 638, 10172, 10498, or 12068 [probably the latter one]
Now the bad news.
I thought that I had some SAM7SE micros that I purcahsed earlier. However, I can't find any. So I looked online and the parts seem to be on long lead time allocation [around four months]. I will order some ASAP and might be able to get hold of some samples, but it will probably four or five months before I can make quantities for sale. :(
Oh well. we do what we can...
Re: The good & the bad....
2010-10-29 by joe.dalton16
I think you deserve some encouragement !
Keep up the good work :)
We'll wait it doesn't matter.
> Good news first.
> AP<xxxxx>-20 where <xxxxx> is one of 638, 10172, 10498, or 12068 [probably the
> latter one]
> Now the bad news.
2010-10-30 by duncan
We'll wait it doesn't matter.<<
agreed. :-)
duncan.
