> On the Mopho I turned off Sysex - no difference. I also tried changes which parameters were being recieved (NRPN, CC, ALL, OFF). I also tried limiting what midi the PX7 was sending.
> --- In xl7@yahoogroups.com, Aaron Eppolito <synthesis77@> wrote:
> > Hmm, I wonder if you had the Mo:Pho responding to song start/stop, causing the internal arps/beats stuff to activate...
> > ----- Original Message ----
> > From: Rob <awol9000@>
> > To: xl7@yahoogroups.com
> > Sent: Mon, March 8, 2010 3:56:24 PM
> > Subject: [xl7] Mopho Lock Up Issue (was Re: Newbie: understanding Hex & SysEx??????????????
> > I did sell the Mopho last week
> > (1) twice, one is fine
> > (2) no
> > (3) PX7 midi out A to Mopho
> > (4) The Command Station is providing the clock. I thought you couldn't use the PX7 as a sequencer and use the Mopho as the clock.
> > (5) I don't know how to send bank changes from the PX7 but I send bank & pattern changes from my Novation Remote and the Mopho is fine.
> > If I hold the "push it" button on the Mopho (causes it to sound) while pushing stop twice (on PX7) the Mopho doesn't freeze. I did sell the Mopho last week.
> > --- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > > I just took a quick look at the Mopho manual (v1.2 I think). Some diaghnostic questions:
> > > (1) Does the lock-up occur when you press stop once or only when you press stop twice?
> > > (2) Does the lock-up occur when you dial up a new pattern before pressing play, or stop?
> > > (3) How are the two wired in terms of midi i/o?
> > > (4) Which is providing midi clock? Are you using one as a slave? Do you have the right clock settings in the PX7 and the Mopho to do what you want?
> > > (5) Does sending bank switching/program change commands to the mopho cause it to lock up?
> > > I am not sure of your answers to these questions, but if I had the gear, I would try to isolate the cause of the problem by first setting the PX-7 as clock master and the Mopho as slave. Depending on whether or not the lock-up happens, I'd switch the two and retest.
> > > I would be surprised if the Mopho was confused by the E-Mu sysex data. If that is the source of the problem, I assume DSI would be interested to know that. I'd rule out other possible cuases first.
> > > It looks like a nice module. Hope you can get it working right with your Command Station.
> > > --Steve
> > > --- In xl7@yahoogroups.com, "soundcrafter_23320" <aurastar@> wrote:
> > > > Rob,
> > > > I might be too late here, but I would say DON'T sell your Mopho just yet! The Mopho is a relatively new piece of hardware, and you may be experiencing a bug in the OS. The XL7 spits out a lot of MIDI data when you press stop twice (as I'm sure you're aware from looking at MIDIOx...) It may just be "confusing" the Mopho.
> > > > Look around for a Mopho / DSI group or forum, they may be able to verify and help you out.
> > > > HTH
> > > > DTK
> > > > --- In xl7@yahoogroups.com, "Rob" <awol9000@> wrote:
> > > > > Hitting stop twice on my PX-7 causes my Mopho to freeze- stops all sound until I unplug it. Frustating trying to write tunes. Midi ox didn't uncover anything unusual. I was hoping to be able to send a command to fix it, that's what got me into the whole sysex or whatever it's called.
> > > > > I've since decided to sell my synth module
> > Yahoo! Groups Links
