> First place I would check is the push button power switch on top...gently touch or wiggle it while the system is on...if it consistently restarts, the micro switch might be bad and need to be replaced....if not, tap the unit to see if it is a mechanical intermittent. If you gig/travel with the unit, you may have a bad/dirty contact internally or a bad/broken solder joint...
> Bob
> El Segundo, CA
> From: bluetechnics
> To: xl7@yahoogroups.com
> Sent: Saturday, December 26, 2009 2:18 PM
> Subject: [xl7] XL-7 keeps shutting down on it's own
> Hello Group,
> while in use, my xl-7 keeps shuttung down then restarting. Does any one know what is the cause and how to fix it?
> Thanks
