Sent: Monday, March 04, 2002 11:02 AM
Subject: Re: [xl7] Timing issues
After spending more time with the XL-7 over the
weekend, I have the following results:
1) The box cannot accurately sync to external MIDI
clock. It reports the wrong tempo coming from the
external device (either an Electribe or RM1X in my
case) and won't start or stay in sync. Gets way out
when I change patterns while "locked" to ext. MIDI
sync.
2) The box is much happier when acting as the MIDI
clock master. Outgoing clock signals drive the 'Tribes
and RM1X flawlessly, although changing patterns on the
XL-& while playing can still result in slight audio
hiccup under certain circumstances. Not terrible
though. Also, the output timing seemed better for some
reason when I switched the MIDI clock out to MIDI port
B.
I'm just starting to create my own patterns and
sounds. All the above occurred with the factory
patterns/sounds.
This is going to present a problem when I hook it up
to my Yamaha AW2816 disk recorder and want to use the
MIDI clock out from the recorder to sync the XL-7.
Will try that tonight and hope for the best.
Any assistance or insight would be appreciated, as I
really love the overall quality and features of the
XL-7 and would hate to return it at this point.
Forneau
--- erik_magrini@... wrote:
> That's weird that you guys are still getting timing
> errors. I have some
> pretty intense patterns and they always change fine,
> never seen any
> glitches. If you have a lot of Controller info, be
> sure to use the Thin
> events function, that might help! Also, maybe erase
> any aftertouch
> (channel/global) too?
> rEalm
> I just got an XL-7, updated the OS to 1.18, and am
> experiencing the
> MIDI sync/pattern change glitches referred to in
> other messages.
Do You Yahoo!?
Yahoo! Sports - sign up for Fantasy Baseball
http://sports.yahoo.com
