Polyphonic aftertouch in command stations
2009-08-21 by nordmod23
Has anyone here worked with this? I have a PX-7, and was hoping that it could generate poly AT for my gear that responds to it. The manual says that it can generate Poly AT but not respond to it. From what I can tell, you can only insert/edit Poly AT in edit event mode, and not from the keypads. Haven't looked into this all the way, but I was hoping the keypads would generate it. The midi spec says no for respond, and generate is left blank. Any opinions welcomed.
Just got a Fizmo and looking to control it with the PX-7.
--James
Re: Polyphonic aftertouch in command stations
2009-08-22 by steve_the_composer
You probably checked this already, but in case not:
Is poly on or off in the AFTERTOUCH CURVES menu?
> --James
2009-08-24 by nordmod23
Thanks! I was looking in the manual index, and that isn't listed at all. Now I see it listed in the table of contents. DOH! I'm still not getting polyAT to affect the Fizmo, but at least I am further along towards my goal.
> > --James
2009-09-05 by nordmod23
Still no luck. I have emailed Emu for suggestions and not heard back. Any other suggestions appreciated!
> > > --James
2009-09-06 by steve_the_composer
I don't think Creative/E-Mu provides any support whatsoeever for legacy gear except what's on the website. Don't expect a reply and don't bother to call. We are very lucky to have this group and some very knowledgeable members.
I am surprised however, that no one else tested their command station for this issue. I'd do it, but mine's a P-2500--no keypad. Good luck.
--Steve
Re: [xl7] Re: Polyphonic aftertouch in command stations
2009-09-06 by Aaron Eppolito
I just tried it on mine and it works fine, though I did find a bug!
The screen you want is 3rd in the Controllers menu: "AFTERTOUCH CURVES".  For each style message (channel or poly), you can choose from "off", 1, 2, 3, or 4.  The bug I found is that when I went into this page, they both said 100!
I verified that with them both off, I saw the MIDI out light blink upon note press, but not aftertouch.  If I turned either on, I'd get lights with pressure.  My computer's not connected to the device at the moment so I can't verify that it's actually sending the right message, but I'd bet it is.
-Aaron
----- Original Message ----
Sent: Saturday, September 5, 2009 11:23:53 AM
Subject: [xl7] Re: Polyphonic aftertouch in command stations
> > > --James
Yahoo! Groups Links
2009-09-06 by Bob S.
Wow...that's great ! A feature we (or at least I) never knew about....and I love poly AT ! (I have 2 poly AT keyboards)
Bob
El Segundo, CA
Sent: Sunday, September 06, 2009 2:05 PM
Subject: Re: [xl7] Re: Polyphonic aftertouch in command stations
-Aaron
> > > --James
Yahoo! Groups Links
2009-09-07 by nordmod23
Please try this and let us know if you can get it your device to respond the Poly T. Thanks!
> Bob
> El Segundo, CA
Where to find the new software (donwload0 for the Command stations
2009-09-08 by Mauricio Balma
Hi!
Bob, Aaron, where I can download the new tool for the command station ?
Sorry bor bothering you
Balma
Sent: Sunday, September 6, 2009 3:47:07 PM
Bob
El Segundo, CA
-Aaron
To: xl7@yahoogroups. com
> > > --James
Yahoo! Groups Links
