XL-7 newbie question - connecting to keyboard + rack synth
2009-07-25 by sdorange
I'm just getting started with the XL-7 and want to use it to generate beats as well as sequence a Waldorf Micro Q (rack), which is connected to an Ensoniq EPS keyboard.
Can I control the Micro Q using the Command Station, and still use the keyboard to play the Micro Q?  I'm going around in circles trying to figure this out.
Many thanks!
Re: [xl7] XL-7 newbie question - connecting to keyboard + rack synth
2009-07-25 by massimo
Yes.
Best thing to do probably is to connect the OUT from the EPS to the IN on the XL-7. Then connect one of the OUTs from the XL-7 to the IN on the Micro-Q. If you also want to control the EPS with XL-7 you could simply connect the other OUT to the IN on the EPS. Or alternatively the THRU from the Micro-Q to the IN on the EPS.
You might want to turn the 'LOCAL' keyboard setting on the EPS to OFF if you don't want it to always play from it's keyboard unless you have selected an appropriate channel on the XL-7. That way it can act as a controller and also be controlled from the XL-7. If you select a channel on the XL-7 that the EPS is set to recognise, it will play.
Hope that makes some sense to ya.
Massimo
--- On Sat, 25/7/09, sdorange wrote:
Subject: [xl7] XL-7 newbie question - connecting to keyboard + rack synth
Date: Saturday, 25 July, 2009, 6:47 AM
Many thanks!
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/xl7/join
(Yahoo! ID required)
; mailto:xl7-digest@yahoogroups.com
mailto:xl7-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
Re: XL-7 newbie question - connecting to keyboard + rack synth
2009-07-26 by sdorange
Massimo,
Thanks for responding!  That does make some sense, but need a little further help:
I've connected MIDI cables as you suggested and can play the EPS to get notes out of the Micro-Q.  However, when I press any of the standard beats from the XL-7 they play thru the Micro-Q using the Micro-Qs sound set.
What I would like to do is: 1) play the Micro-Q through the EPS as a proper synth (already doing that now); 2) Play XL-7 patterns using the XL-7 sound set, and 3) use the XL-7 to sequence patterns & souns from the XL-7 and the Micro-Q.  Can that be done within my current setup?
Much thanks,
--Scott
--- In xl7@yahoogroups.com, massimo <massenmedium@...> wrote:
> Yes.
> Massimo
> --- On Sat, 25/7/09, sdorange <scott.orange@...> wrote:
> From: sdorange <scott.orange@...>
> To: xl7@yahoogroups.com
> Many thanks!
2009-07-26 by woodsworth1
The problem that you have is that you're wanting to merge two MIDI sources to a single destination. Unless you have two MIDI inputs on the MicroQ that's not possible with your current setup. A number of manufacturers have made products capable of merging MIDI traffic from multiple sources to a single output (eg roland A550/A880 or kawai MM-16). They show up periodically on ebay and that would be your best bet.
--- In xl7@yahoogroups.com, "sdorange" <scott.orange@...> wrote:
> Massimo,
> Much thanks,
> --Scott
> --- In xl7@yahoogroups.com, massimo <massenmedium@> wrote:
> > Yes.
> > Massimo
> > --- On Sat, 25/7/09, sdorange <scott.orange@> wrote:
> > From: sdorange <scott.orange@>
> > Many thanks!
> > Yahoo! Groups Links
Re: [xl7] Re: XL-7 newbie question - connecting to keyboard + rack synth
2009-07-26 by massimo
Yes absolutely it's possible.
I don't know about the standard beats or preset patterns as I don't really use them but what you'll want to look at first is the 'channel assign' setting for each track of the pattern you are using. You'll find this in the pattern edit mode (press the pattern edit key). The MIDI channel each track uses can be changed and (crucially) each track can be set to play internal sounds (the beats), external devices (like the Q or the EPS), or both at the same time, if you like.
You also might want to look into the MIDI settings on the XL-7. Usually with a setup like that, the 'rechanelise input' setting will be on 'always' so the keyboard only plays the device the track you have selected is assigned to. There might be a couple of other settings in there you need to pay attention to, like the thru and merge settings. but actually I think that should do it for now.
To summarise, the important thing is setting the tracks in the pattern to play on the right MIDI channels either internally or externally or both.
Massimo
--- On Sun, 26/7/09, sdorange wrote:
From: sdorange Subject: [xl7] Re: XL-7 newbie question - connecting to keyboard + rack synth
Date: Sunday, 26 July, 2009, 7:21 PM
Massimo,
Much thanks,
--Scott
--- In xl7@yahoogroups.com, massimo wrote:
> Yes.
> Massimo
> From: sdorange
> Many thanks!
Yahoo! Groups Links
<*>; To unsubscribe from this group, send an email to:
2009-07-27 by sdorange
Are you sure this needs a MIDI "hub" ?  MIDI Thru on the Micro Q would not take care of this?
--Scott
> --- In xl7@yahoogroups.com, "sdorange" <scott.orange@> wrote:
> > Massimo,
> > Much thanks,
> > --Scott
> > > Yes.
> > > Massimo
> > > Many thanks!
> > > Yahoo! Groups Links
2009-08-04 by steve_the_composer
Hi, several days ago I started a reply, but decided to test the solution before posting. I ran into some snags because of the flexibility of OS2.0--basically, you can set things up in a variety of ways.
The bottom line is this: depending on what you want, you might not need a "hub" [thru box, midi router]. There are some settings in the CS/P2500 MIDI menu system to transmit various midi data, including a MERGE MIDI IN TO OUT. This setting might be helpful to you, depending on your midi wiring.
Also, the MicroQ may have a midi out/thru you can use. (I looked at the manual a few days ago, but forgot the details.)
If most of your CS tracks will be external or both, you will probably want to set up a pattern template and store it at slot 000^0. You will need to store "dummy" data on the tracks so that the channel destination for empty tracks don't default to internal." [Search the archives for "dummy" for more discussion of this.
If you have figured out a solution already, great. Let us know how you decided to set it up.
--Steve
> --Scott
> > > Massimo,
> > > Much thanks,
> > > --Scott
> > > > Yes.
> > > > Massimo
> > > > Many thanks!
> > > > Yahoo! Groups Links
2009-08-05 by sdorange
Hi Steve,
Thanks for your reply.  I still haven't got this figured out.  Here's where we left off - I'm able to play the patterns on the XL-7 through the MicroQ using MicroQ soundsets; unable to play XL-7 patterns using XL-7 sounds.
I have a small set-up - MicroQ (with In / Thru / Out), XL-7 (In / Out / Out) and Ensoniq EPS (In / Thru / Out).  I want to be able to play MicroQ sounds using the keyboard, create & play beats using the XL-7 and its soundset, and sequence 4-6 tracks on the XL-7 which could either be beats from the XL-7 or sounds created using the MicroQ.
Appreciate your suggestions around merging MIDI in & out; unfortunately I don't have enough of knowledge to make use of it.
I've been through the XL-7, MicroQ and EPS manuals, and there is not enough info for me to figure out this stuff.  I am inexperienced using MIDI, and the books I have on MIDI routing, the diagrams on vintagesynth.com, etc. just don't seem to cover my specifics.  FWIW, I am still trying to learn the XL-7 and don't even have the hang of beat-making via grid recording.  So that's where I'm at - I can use the XL-7 by itself (sort of), I can use the MicroQ by itself, but I am not in Command of anything as of this writing.
Suggestions are most welcome!
Best,
--Scott
2009-08-05 by Aaron Eppolito
So here's the deal.  Think of the MIDI routing like you'd envision audio cables.  The main difference, however, is that instead of routing sound, you're routing note/event instructions (i.e. "Play C# now" instead of "Here is the sound of a C# playing").
The XL-7 has a few sources and a few destinations.  The sequencer, the keypads, the MIDI In jack, and the knobs all generate MIDI events.  The sequencer, internal synth, and the MIDI output jacks are the destinations.
You'll want this:
EPS MIDI Out  -->  XL-7 MIDI In
XL-7 MIDI Out A  -->  EPS MIDI In
XL-7 MIDI Out B  -->  MicroQ MIDI In
Then, you'll need to do a few things in software.
On the EPS, turn "Local Control" OFF.  Since you're routing MIDI notes back to itself, you should break its internal connection between its keyboard and synth.  This is akin to making sure not to record a tape deck's outputs back into its inputs.
On the XL-7, turn "Rechannelize MIDI In to Out" ON.  This will make it such that the notes you play will go to where the current track is going.
For each pattern (or song) there's a setting for each track which determines where the data on that track will go.  It's one page back from the end of the pattern menu entitled "CHANNEL ASSIGN".  For each track, you'll have two things to choose, channel and destination.  Destination is the interesting thing here - you can choose from none, int(ernal), ext(ernal), or both.  Internal plays the XL-7's internal synth, external plays only the MIDI jacks, and both, well, plays both.  If you've routed things as described above, here's what you'd set to assign a track to a particular device:
EPS:  Channel: 01A-16A   Dest: ext
MicroQ:  Channel: 01B-16B   Dest: ext
XL-7:   Channel: 01A-16A,01B-16B   Dest: int
I'd stay away from both (for now) as there's program change implications (when set to both, program changes are stripped from the MIDI ports).
In this configuration, whatever you play on the pads or the EPS will play whatever sound the current track would play, internal or external.  The reason you're hearing the XL-7 patterns playing the MicroQ is because the built-in patterns' tracks are all set to "Both".  Why we did that, I don't know.  Seems pretty dumb in retrospect.  Even worse, is there's no way to mass-modify them.  If you're not hearing XL-7 sounds *as well* it's likely because you have the volume down or audio cables not plugged into the XL-7.
My solution to the MicroQ playing along is to turn down the volume on the MicroQ when playing the factory patterns, or, simply make your own patterns!
-Aaron
PS. as a tip, if you have OS 2.00, hold Tap and press a track mute button to select that track!
----- Original Message ----
Sent: Tuesday, August 4, 2009 7:04:08 PM
Hi Steve,
Best,
--Scott
2009-08-05 by steve_the_composer
Excellent explanation, Aaron.
Let me add a few things, Scott. Aaron can correct me if I miss something important; I usually test solutions out before posting them, but haven't done that yet with the one I was working on.
First, I assume you have OS2.0 for the XL-7. If not, I highly recommend it. Also, I assume you have the latest XL-7 manual.
Second, get the basic setup hooked up; Aaron's solution should let you do everything you want (and possibly more).
You probably know this, but I have to mention it just in case: each midi cable connection (5 pin din cable) is only one way. (Some newcomers to midi think that because it has 5 pins, it is two-way.)
Third, if you haven't read about the XL-7's multisetups yet, you may want to. Multisetups let you store and recall various settings--including the MIDI settings. I specifically have in mind the MERGE MIDI IN TO OUT settings.
As you are mastering your new setup, it might be helpful to have setups which let you target your focus, such as:
IN->A only [set up so the EPS is only going thru the XL-7 to the EPS--with local off]
IN->B only [set up so the EPS is only going thru the XL-7 to the MicroQ]
IN NOT MERGED [set up so EPS will only be going to the XL-7]
IN-->A & B [set up so that the EPS will control the XL-7 and be sent to both the EPS IN and the MicroQ IN.
[Note: I am using the same ports as in Aaron's example.]
Once you master each device and develop fluncy with your set up, I assume you would primarily be using both A & B outs.
Having said that, you might not want to do it this way, since multiseups also save channel preset assignments [which preset is on which channel] and if you have presets set up in a certain way, when you switch multis, you will lose those channel preset assignments!!!!
So, you could just have the MIDI button set up the the MERGE MIDI IN TO OUT PAGE and switch manually as needed. (Hopefully, the explanation give you some insights about the XL-7's ability to switch merged outs on and off as well as multis.)
I hope I mentioned in a previous reply about setting up pattern templates with dummy data to preserve channel assignments in all 16 tracks.
As for grid recording, I never use that, but I believe there are discussions about grid recording in the archives (search for "grid"). Also, I believe there are some users around here that could give you some tips.
Hope this helps.
--Steve
> You'll want this:
> -Aaron
> Hi Steve,
> Best,
> --Scott
2009-08-08 by sdorange
Aaron,
Thank you for such clear, well-described instructions.  I've done the MIDI cables & am working on the software side this morning.  Will let you know how it goes.
--Scott
> You'll want this:
> -Aaron
> Hi Steve,
> Best,
> --Scott
Hi Steve,
Thanks for the tip about Multisetups.  I agree it sounds like a good way to quick-reference instrument setups.  As soon as I have a decent working setup, I'll definitely explore this.  The setup of pattern templates sounds interesting, I'll let you know when I get to that point.
Many thanks for all the help.  It's great to have such a supportive group for this instrument!
Best,
--Scott
