> From: Aaron Eppolito <synthesis77@...>
> Subject: Re: [xl7] Re: some q's
> To: xl7@yahoogroups.com
> Date: Wednesday, 15 July, 2009, 2:24 AM
> Actually, #1 is "no" and "yes". No, it will not
> record sysex. Yes, it will play back sysex! I
> know that sounds stupid (and it is) but what it does allow
> you to do is load a sequence up to your computer via
> E-Loader, add the sysex to it with your favorite sequencer,
> then download it again. Lame, but it's a workaround.
> Furthermore, #2 is yes, though not through
> passthrough. MIDI Clock is stripped from "Soft-Thru"
> but it WILL regenerate clock while slaved.
> #3 yep, with OS 2.0 you can RT record pattern changes and
> mutes.
> #4 not sure which one you're talking about, but there's at
> least one empty socket for OS updating via EEPROM chip
> instead of MIDI.
> -Aaron
> ----- Original Message ----
> From: MadjacK <got_hatchet@...>
> Sent: Tuesday, July 14, 2009 5:26:24 PM
> Subject: [xl7] Re: some q's
> Well I know the answers to #1 and #2
> Yes it will record sysex from external devices make sure in
> the midi page it is set to do so tho first.
> And you can select a midi thru option to send the clock
> thru to the other devices.
> I haven't tried much in song mode yet sorry and I never
> noticed an empty socket unless you mean for additional sound
> chips.
> --- In xl7@yahoogroups.com,
> massimo <massenmedium@...> wrote:
> > Hello, mew list member here.
> > I've got a few questions about the Command Stations
> (OS 2.0) that you folks might be able to help with. Here we
> go -
> > 1. Will it record and play back sysex data for other
> synths?*
> > 2. Does transmitting MIDI clock while slaved to
> another MIDI clock work properly?**
> > 3. Can song mode really not record pattern play events
> in realtime?
> > 4. What's the empty chip socket on the main board?
> > Cheers!
> > * I've tried sending stuff from a controller but it
> doesn't seem to be recorded or passed through. CCs work fine
> of course.
> > ** Have tried slaving it to Cubase and it doesn't seem
> to pass the MIDI clock through.
> mailto:xl7-fullfeatured@yahoogroups.com
