Dealing with unquantized notes.
2002-03-01 by nifflas
I have problems when working with the grid editor. It has problems with some of the unquantized notes - I can't remove them by pressing the erate button / setting the velocity to zero. If I would change the velocity of the note-on, it doubles into two notes by no reason... This only happends to some (not all) unquantized notes tho. If you don't know what I mean, just set set up an empty pattern, record something (Turn quantize OFF), then go into grid editor and you'll see that there's some notes you can't remove by pressing the erase button or setting the velocity to zero... //Nifflas
