--- In
xl7@yahoogroups. com, "steve_the_composer " wrote:
> "I have midi enable for channels 1b-2b set to off so that the CS sounds don't play on those channels."
> In order to send sequencer data out MidiB, you need to:
> 1. Enter Pattern Edit Mode.
> 2. Scroll to CHANNEL ASSIGN.
> 3. Set the track to ext [for external].
> If you wanted the track to got to both the internal sound engine and external gear, you'd use both.
> MIDI ENABLE (in the MIDI menu system) controls whether or not the CS synth engine responds to data on each channel.
> I have a P2500 (no pads) so someone else will have to tell you what setting to use to make sure the pads get recorded on the CS. I am not sure if you need
to check the settings in the Controller menu subsystem or the MIDI menu subsystem (or both).
> --- In
xl7@yahoogroups. com, "ohnogallo" <;ohnogallo@> wrote:
> > Having a little trouble here. can anyone help?
> > I hooked my Ea-1 up to midi output b. I have it set to midi channels 1&2. I have midi enable for channels 1b-2b set to off so that the CS sounds don't play on those channels..
> > When I select channels 1b-2b I am able to play the EA-1 with the pads on the CS.
> > When I go into realtime recording, it will count in, use metronome, allow me to play the Ea-1 with the pads, however it will not record what I am playing.
> > When I go into grid mode recording, it will allow me to play the pads as if to select the sound
however the on,off info does not change meaning that actually it is not allowing me to sequence with the grid buttons.
> > When ever I try to create patterns in realtime or gridmode using the internal sounds it works fine.
> > The problems I'm having with the external synths happen on both output a and b.
> > I've tried using 3 different synths, all act the same way leading me to believe that I'm just missing some setting that the manual is unclear about. (or maybe my new CS is malfunctioning which would really suck!)
> > Any thoughts?
You probably have your channel assign destination set to "int" (internal). Try pressing the pattern edit button then scroll until you get to the channel assign screen. Use the track selector to select the track you are using then set the channel to match the track then set the destination to "ext" (external). This may
help.
